General Turbo Buick Tech Technical discussions
Old May 3rd, 2003, 12:39 PM
mgmshar's Avatar
High on Boost...
Max. RPM - Stock Bottom End
Just wanted to see what the general consensus was for the maximum RPM the stock bottom end can take on the LC2. When I say stock, I mean bone stock - no girdles, billet caps, etc. For the sake of argument, pretend that the cam can breathe up to whatever rpm.
Thanks,
Mike Mshar
1986 GN, Stock Un-Opened Engine
11.42@119 w/ 100-Octane Unleaded
Sponsored Links
Old May 3rd, 2003, 12:41 PM
Supporting Vendor
Trader Rating: (16)
Mike,
I know someone up in Flint that was shifting at 6800 rpm. He was running a 224 or 230 cam.
Brian
87 Turbo T, Silver with maroon interior, and 35K miles. PTE 61-52E, CAS V-4, 42lb inj, 65mm t-b and HEMCO upper, TINMAN cold air kit. Powered by ALKY control. 11.77 @ 114, 23 psi. With any luck.... soon to be the latest 10 second stock unopened motor!
Need a Hi Perf trans? Email me... hipsibri@cs.com
Old May 3rd, 2003, 01:05 PM
Lightbulb STOCK MOTOR REDLINE LIMIT
Lots of variables, but 5400-5800 range sounds "safe"
HTH
Happy to participate, and thanks!
Help Stomp Out Customer Abuse!
Ripped Off? Here's Helpful Info:
http://www.fraud.org/info/contactnfic.htm
http://www.ftc.gov/bcp/conline/pubs/buspubs/mailorder.htm
Old May 3rd, 2003, 01:30 PM
best longevity at 55-5700........but my car leaves a lot on the table shifting there
Woody
Basic TSM recipe 24 lbs boost
Old March 9th, 2009, 02:46 PM
Jerryl's Avatar
Doing MORE with LESS!
Well, I know this is an old thread but, there may be an “updated point of view” . So, as of March 2009, what is the consensus on RPM limit with a stock bottom end?
Matthew 7:6
Do not give dogs what is sacred; do not throw your pearls to pigs. If you do, they may trample them under their feet, and then turn and tear you to pieces.
Psalm 4:4 - In your anger do not sin
Houston Buick Club Events
Old March 9th, 2009, 06:42 PM
pacecarta's Avatar
Trader Rating: (9)
i dont think you can really compare whats safe based just on rpm , hp has some bearing on whether it will live at high rpm
at a little over 600rwhp ive been shifting and trapping little over 6,000 (129+ on 28" slick) , has been to 6350 a few times on shifts , can tell you i dont feel comfortable running over 6k and with with my hyd flat tappet cam (212/208) im off the power band at 5800 or so , a tighter converter would help a lot more than spinning it up
paul -NJ rep
MAGNAbuick.com NJ,PA,MD DE -GN/TTA club
86 & 87 GN's
A little fun with the GNs at Atco video
my 86 10.4 on 93 with a 2004r on radials through the mufflers
Old March 9th, 2009, 09:05 PM
Slow91z's Avatar
Turbobuick.com Helper
So pauly just to be clear, you say 6k is where you feel comfortable but not more.
I ask because I'm putting in a 218 218 roller now while we're freshing up the motor.
Collin Hundley
87 GN - 10.73@127
Old March 9th, 2009, 10:13 PM
RETIRED
Trader Rating: (28)
I pulled 5750 in 3rd at the drag strip and wasnt comfortable at all.
NO MORE TECH ADVISE. Please do not contact me unless you have a response to parts for sale.
Old March 9th, 2009, 10:38 PM
pacecarta's Avatar
Trader Rating: (9)
colin, stock bottom i like to go no bigger than 212/212
paul -NJ rep
86 & 87 GN's
Old March 10th, 2009, 06:43 AM
Slow91z's Avatar
Too late now, I'll just have too see how the 218 does.
Collin Hundley
87 GN - 10.73@127
Old March 10th, 2009, 08:44 AM
dr_frankenstein's Avatar
Mad Scientist
I think weight and weather it is NA or Huffed is a big factor as well, I would push a stocker bottom past 5750 in a stock bodied car...... or really anything over 3300lbs, with or without boost.
but i have pushed a stocker NA 4.1 rotating assembly to 6500 in a 2500lb body. Kinda scary sounding, but it has held multiple times.... **** - I'll do it on the way home from work tonight!! might beable to grab 7 if i can get somebody to hold the camera.
A.j.
http://www.youtube.com/watch?v=ykgDNjeTa0g
Sometimes I just wish I had a reason to be happy.
Old March 10th, 2009, 09:54 AM
pacecarta's Avatar
Trader Rating: (9)
have to keep in mind that if you're running on chip... most chips have rev limiters that cutoff fuel.
highest they can set them is 6350 ... might be set lower!... you'll have to check by either asking you chip guy or do a breakdown of the chip on a pocket programmer
straight gas or race gas wont have a problem with the limiter , spraying denatured and water mix is not too bad because its not a fuel but meth is and if injectors are cutoff at that rpm under boost meth still sprays and will be lean and go pop and you'll be looking for a head gasket .
make sure your chip has the limiter removed ,
paul -NJ rep
86 & 87 GN's
BB code is On
