Old March 30th, 2003, 08:18 AM
GN wheel caps
Lost another cap while driving on the highway . Gonna order another one this week. Can you put the wheel and tighten all the bolts then just push the cap in? Or better to put the wheel first then put the cap and hold it there while hand tightening the bolts? Thats the way I used to do it but after examining the back of the cap it looks like you can just push it in after all 5 bolts are tightened
87 GN Hardtop(Sold.....miss you)~Stock motor, Mease stock intercooler w/Duttweiler big neck,stock intake, JJ 62mm tb and plenum, RJC plate, 160 stat, TE51 w/.63 housing, 12" 2800 stall TC, MSD 50's, THDP, ATR 3" dual exhaust, big mouth cold air inducition, Turbotweak alky chip, SMC alchy injection and egt gauge, MM boost command, Walboro 340 hotwired, 10 mm Magnecor wires, NGK UR5 plugs @.035, Adjustable regulator, ATR 3" maf pipe, B&M tranny cooler, Deep aluminum tranny pan, Dynotech shift kit, scanmaster 2.1, dual airbags, vdo gauges, autometer boost gauge, front braces and rear seat brace, Bilstein shocks, more mods to come
Old March 30th, 2003, 10:57 AM
dgreene's Avatar
Broke as hell.........
Was the backing still on the car? I used to always loose the cap but the holder would still be on the wheel.
Donnie Greene
'87 Astroroof GN 7.73/ 1.84 60' at 89.8 MPH in the 1/8th on BFG DR's. Combo = TA-49,Stainless THDP, PTE Super Stock IC, Hooker Catback,50# injectors, Accufab AFPR, GS340 FP, FP Hotwire kit, RJC Powerplate, MAF pipe, KN filter, HR mounts, 3200 stall Vigilante convertor, PTS trans parts, brake upgrades, all braces, denso O2, 112 octane Sonoco fuel, 16" BFG DR's and a turbotweak 110 race chip from Eric.
Old March 30th, 2003, 02:51 PM
are you talking about the silver ring that goes behind the cap? IF you are then its not there.
Old March 30th, 2003, 08:52 PM
dgreene's Avatar
yeah, that's it. I've never had a problem with those coming off, just the cap itself. I found if you would take a torch and heat a flat head screwdriver up and mash the plastic tabs that stick through the silver retainer ring flat, that it wouldn't pop off of it anymore........
Back to your problem, are you using the correct lug nuts? Just a thought....
Donnie Greene
Old March 31st, 2003, 10:13 PM
yeah been using the same lug nuts that came with the car ever since I bought it
Old March 31st, 2003, 10:32 PM
d0n_3d's Avatar
What's in YOUR wallet!?
when i was driving with my stock rims i lost a couple center caps and it really pissed me off...you just gotta push the cap and metal retainer all the way in while you tighten the lugnuts and dont let go until the lugnuts are totally tight...the center caps should not budge after that...if they do you need new retainer rings or they need to be bent back into shape
-Don
87 GN 11.07 @ 125 mph (old combo w/ PT67 DBB, GN1 heads, 120k mile stock shortblock, ended up splitting block )
Now running a 44k original mile stock longblock, stock turbo (for now), PTE FMIC, 60 lb inj, TT chip, TA Perf 3" DP, GNX style VDO dash, Vince Janis built 200-4R w/ 10" 3400 n-l stall (can you say NO turbo lag? LOL)
Words of experience: Going fast was nice, but when your car is down every single year because you broke something, it isn't fun anymore and unless money grows on trees at your house, you don't regret going back to stock, and being able to drive and enjoy your car again
