Old March 20th, 2003, 11:39 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Posi works sometimes and one wheel peel other times
What would cause the rear end to do this ??
Fluid and additive have been changed and it is the same fluid setup I use in my other GN and that did not help.
How hard is changing the clutches out ??
USAF POWER PRO
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe.
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list still has warranty till 2010.FOR SALE
Old March 20th, 2003, 03:47 PM
BOOST SUX MY WALLET
ttt..anyone..??
USAF POWER PRO
05' Harleys
Old March 20th, 2003, 04:13 PM
Odds are the clutches are tired in the carrier. Having it posi, then one legged warrior, then posi again does nasty things to the gears and splines on stock axles. I would pull the cover and inspect everything. Also, bad things happen when that happens with slicks or stickys mounted......expensive things..
Just inspect it before something lets go. FYI
Old March 20th, 2003, 04:23 PM
Turn it UP!!!!
Yep, sounds like the clutches are starting to go in that thing. Better to deal with it now, before it deals with you, and costs even more to fix. Good Luck.
Brad
Old March 21st, 2003, 06:32 AM
BOOST SUX MY WALLET
thanx
USAF POWER PRO
05' Harleys
