Old March 15th, 2003, 01:02 PM
frankg's Avatar
Speed Seeker!!
Angry Failed Emissions Test
Well took car through test today. My EGR is blocked off. Didn't change the oil or anything from sitting through winter. Ran it with 93 octane fuel set at 38psi line off, disconnected fan. Jay carter street chip. Had an old stock cat and downpipe. It was about 200 deg. when test started. It failed!!! I'll try some denatured alky and new oil next time. ANYONE HAVE AN EMISSIONS CHIP TO LOAN FOR 009's??????
--Hydrocarbons-2.26(max 1.8)FAIL
--Carbon Monoxide-22.20(max 30.0)PASS
--NoX-4.00(max 2.8) FAIL
1969 Camaro 82,000 original miles
71 Nova 383 SBC Project
87 WE4 T, TA-49, 212-212, Best-11.36@117.6 1.61 60 ft. 28x10slick, thru exh--SOLD
1988 Monte SS-- 9" Moser rear 390gears, 10 point cage, 4" cowl hood, 406 SBC 10.8@124.8mph 1.56 60 ft.
MAGNA Buick Club Member
204-214 Cam&lifter kits $120 plus shipping--Parts sold seperate too!!!
-----------GARBACZ MOTORWORKS-------------
443-907-2079
Head Porting and Engine Building
Old March 15th, 2003, 01:58 PM
10's here i come
Ive been putting mine off for almost two years now, ithey are making me go next month now, I will be trying ever thing to get mine to pass. What happens when your car falls, how long do you have to fix it before they try to take your tag or something. I am going to try a lot of alcohol in my gas tank when i go.
good luck with it,
Old March 15th, 2003, 02:54 PM
Intercooler's Avatar
Ha Ha
Frank,
You really like the FP eeeeh!
Got a couple of options available to you:
-Do the "sure-fire" technique to the diagnostic port and leave your 009's in.
-Hope that someone has a chip for you to try.
-Change some things and tune it up.
-Borrow my 30's and street chip.
Pay off the inspector
Old March 15th, 2003, 03:05 PM
frankg's Avatar
Speed Seeker!!
Yeah i'll try that stuff now i was just curious to see if it would pass as is?? I got my answer. Frank
443-907-2079
Old March 15th, 2003, 04:09 PM
humberto's Avatar
That egr blocked off will prodoce high nox readings get the egr on and it will also lower hc.Dont forget to change oil just think of all the hcs in that old oil.Low timeing chip is a must,good luck.
86GN Hooker 2.5 ,3"DPw/deltagate,GN1 FT mount Intercooler,TE61wPTE.63exhaust,houseing,GN1aluminu m heads,T&D1.65roller ,rockers,ATR214/208cam,60Zs injectors,Walbro340 Eric Marshal chips,pw plate, SMC kit,RJC pw plate, 3500 9x11 stall ,weld prostars.
Old March 15th, 2003, 09:21 PM
FrankG-
I too have heard if your car is iffy in passing to NOT change the oil. I would reconnect the EGR stuff and you should be good to go. 009's run inherently rich.... Turn the fuel pressure way down and maybe even get a smog chip if you have to for those squirters.
I too will be trying to pass CA emissions with 009's. We'll see what happens.
-GNX7
'87 Mazda RX-7 with '87 GN drivetrain stk turbo/convertor
11.62@114mph R.I.P.
http://www.wrongmotor.com/gallery/mark_c/index.htm.
LS1/T56/RX-7 FD 13" AP brakes, coilovers, 18x10.5 CCW's. 439rwhp/385rwtq 2800lbs/1.13g's 11.42@127.4mph n/a SOLD
http://www.turbobuick.com/forums/sho...d.php?t=195038.
LS7/T56 RX-7 FD project: 575rwhp + 140mph trap speed n/a goal
Old March 15th, 2003, 09:43 PM
They must be considerably less strick here. I've had no trouble passing emissions and that was with my PitBull chip. I usually change the oil and remember to put the cat back on. With the Thrasher I doubt it would pass. It seems to be richer. My plugs were fouling where it never did it with the Bitbull.
87 GN TE-61, ATR DP, Precision Stock-location IC, 208 cam, FAST XFI (Hartline Perf,) Big Mouth CAI, 3200 Coan NLU converter, 60# injs. oh,yeah and a driveshaft loop! G S C A # 90
Turbo Six Buick Club, Louisville KY
Old March 15th, 2003, 11:43 PM
humberto's Avatar
Trust me not changeing the oil will not help i do emission testing everyday unburnt fuel=HC.Dirty oil is full of HC.Our cars would be a perfect example with all the aftermarket fuel pumps and large flowing injectors most of us install.
Old March 16th, 2003, 02:23 AM
J Banning's Avatar
Quench my thirst with C16
I just passed Delaware emissions (idle & fast idle - 2500rpm) with my blocked EGR, 72's, and 218/222 cam...
http://www.turbobuick.com/forums/sho...327#post517327
Carl Ijames made me the emissions chip for my 72's. He's on this board if you want to try contacting him.
-Banning.
Banning Cohen
1986 T-Type WH1
10.62@125.45 (1.43 best 60')
Project GRrrr - 1984 T-Type WH1
$200? Grassroots Motorsports Challenge car
Mid-Atlantic Grand National Association (MAGNA)
Club Director & Delaware State Rep.
Mods: Budget 4.1, PT67 turbo, Bronsonian ported heads w/stock valves, Razor's dual nozzle, Comp 214/214 roller cam, Powerstroke IC, Aeromotive pump, 83# injectors, TurboTweak Wideband, Michael's Auto TH400 w/transbrake, Pat's 9" converter, Moser spool & 33 spline gun drilled axles.
Old March 16th, 2003, 07:42 AM
TurboDave's Avatar
Cell Phone Doc
-Banning.
Ya, but your state doesn't test for NOX does it?? His does.
TurboDave EWCS(SW) USN Ret
Email Us
Sevierville, TN
TranslatorPro MAFless fuel, spark and boost management
86 GN(TranslatorPro/ExtenderPro on speed density w/boost & fuel pump control,PLX-WB) (original owner)
87 GN (second owner)
84 L69 Z28 (original owner)
01 Excursion LTD 7.3L PSD(Power Stroke Diesel), Turbo, 4X2
08 Honda Accord EX-L, 3.5V6, AT
My Photo Gallery
Old March 16th, 2003, 08:01 AM
frankg's Avatar
Speed Seeker!!
Yeah i just noticed that, that sucks. De max for hydrocarbons is higher too 2.20 where MD is 1.80 max. These laws are so stupid. What some states don't need clean air!!! I wish someone had an Emissions Chip for me to borrow. That with new oil and low fuel psi and i think it will pass easy. Is it better for emissions to run colder or hotter plugs? I'm going to get new plugs in it to. Thanks,Frank
443-907-2079
Old March 16th, 2003, 09:21 AM
humberto's Avatar
Idle and fast idle test is called a two speed test,depends where you live, a two speed idle test is only done on cars with full 4x4 and traction controls that cant be manually turned off. For example here in Ontario you have to run car at 40 km then perform idle test make sure the car is not cold,a cold converter will not work properly.Lean the car out until it barely idles,Use a low timeing chip and dont forget fresh oil.Make sure wires and plugs are good, looking at your hc numbers it doesnt look like there is a problem there.and dont forget the egr.Good luck.
Old March 16th, 2003, 09:32 AM
frankg's Avatar
Speed Seeker!!
Yeah it would be easy to get my EGR working again if i have to. I just have to remove my RJC power plate, everything is still in place and hooked up, i just never drilled the hole in the plate for the EGR. They ran mine on a rear wheel dyno type machine, like normal driving at all different speeds. I think part of the problem was the lady doing the test, when it was climbing in speed she's spoolin the turbo up then goes to fast for her so she lets off of it then on it again to try and keep it where its supposed to be. She wasn't to steady on the throttle I think she was a little scared when it shifted hard and spooled up real fast. Frank
443-907-2079
Old March 16th, 2003, 10:23 AM
Frank, i passed the second car in my sig fairly easy. it did fail the first time like you with old oil. i changed it and added GTP and it passed with flying colors. they test all three here in RI.
01 cobra, upr o/r x-pipe, magnaflow cat back, k&n cai, pro 5.0 shifter, tune by Dez racing.
07 acura tl type-s
