Do Not Buy Autozone S-10 wheel cylinders!!!!
They are a cheap replacement and if you look at the part number, it is the same # as the grand national, or any other rear wheel drive car I believe. Check it out on the autozone website. I would check out a better source to buy them at, like maybe Napa.. That'll be another beer Gnergy!! ![]()
84 t type, turbolink, J Carter street chip, 86 ecm, comp cams 212, home ported heads/intake/throttle body, TA-49 turbo, 42.5lb inj., 2.5 ATR DP, K&N air filter, 237 afpr, Walbro 340, oil/water/boost/knock/fuel pressure gauges, adjustable wastegate rod, Nitto 275/50/15 on Convo Pros, bilsteins, rear air bags 67 impala ss, big block, 4500lb 12 sec. 1/4 mile chick magnet 99 Cadillac STS, 300hp daily driver Buick = Built Understanding It Can Kick @$$ |
I have had a set of S-10 wheel cyl. and soft shoes for years with no problems. However I also added a proportioning valve. Without a proportion valve you will lock up on a panick stop.
86 T-Type - original owner Original Block (car sold ) 10.38 @ 131 mph Duramax diesel with power adders for "towing" |
I see what your saying. They WILL lock up on you, but only if you tighten them, (so you can hold more boost at launch) and your front brakes are almost gone (no good). This is what was happening on my car and It went away as soon as I did my front brakes. As long as you have good brakes up front, you have nothing to worry about.
NAPA ones work great. HTH
Jorge P. 1986 GN -->Daily Driver, 168,000 Original Miles High 11's... in both ET and MPG. Shooting for 10's this year "You can have everything in life you want if you will just help enough other people get what they want." Mr. Ziglar |
Ok, thanks G Mcall and Jorge, I'll install them as soon as I get my stainless braided hoses. I had just put new shoes in the front in August.
Tarey D.
87GN Stock Motor 56Kmi. TE-60, #50msds,62mmTB by J Jackson.3.5"MAF,Powerplate,Chip by "BRUCE". Hotwired XP. PTE-FM. SMC-Alky BGC.Elbow&3in.DP.& 2 3/4in.Duals Boxed Uprs&Lwrs Urethane bush. Mike Kurtz Racing Trans. 2800stall.KB.adj FP.reg.GNX braces. Global West Control arms, 12in. Discs. Kirbans chrome M&A valve covers, tranny pan,diff.cover.Cyberdyne Digital dash.BE-Kool rad.Spal dual fans.Spectre Braided Stainless hoses&Aluminum fittings, Translator. Scanmaster 2, Westech EGT Simmons Wheels, Urethane body bushings, ATR bar. |
Here is the Bendix part #33891
Wagner part #F110260 Hope that helps. Tarey D.
One unpleasant discovery I made about the braided stainless brake lines. I bought the Russell set, and I could not get the rear line to seal. I don't know why, but I think the sealing surfaces were incompatible between the new line and the hard line on the car. I ended up using a new rubber line in the rear and just the two stainless lines up front. To me it was still worth it to have the front lines, just something you should keep an eye out for. Maybe the Earl's set is better, I dunno.
SOLD: '83 Malibu wagon, '86 GN drivetrain. |
Larger rear brake cylinders: GM: #18012305 or Bendix: #WC37644T ____________________________________________ Summit Brake proportioning valve: # G3905 ____________________________________________ (Above info from www.gnttype.org 3/14/03) HTH ![]()
Happy to participate, and thanks! __________________ Help Stomp Out Customer Abuse! ----------------------------- Ripped Off? Here's Helpful Info: http://www.fraud.org/info/contactnfic.htm http://www.ftc.gov/bcp/conline/pubs/buspubs/mailorder.htm |
No problems here either, had em for 7 yrs now. Good call on listing the GM #, those are the ones I would get njturbo.
http://www.cardomain.com/id/Gussbuick Optima batteries not allowed beyond this point. Merritt Performance Hartline Performance PTS Xtreme Transmissions RJC Racing Alkycontrol alcohol kits TurboTweak chips G-bodyparts Full Throttle Speed |
Manual transmission
