Stock Exhaust Manifolds
Were the stock exhaust manifolds 'dry mounted' (i.e. no gasket)? I took mine off to get the driver side repaired and there were no gaskets. All help Appreciated!!
1987 T - just starting to get her in shape for the summer! Thanks to all - I've learned quite a bit since I found this site.
87 Turbo T - 9" K&N, 160 Thermo, RJC Power Plate, Walbro 340 hotwired, Adj FP Reg, #36, MAF Trans & Extender chip, Kirban braces, THDP w/Hooker dual exh. |
From the factory they were.
http://www.cardomain.com/id/Gussbuick Optima batteries not allowed beyond this point. Merritt Performance Hartline Performance PTS Xtreme Transmissions RJC Racing Alkycontrol alcohol kits TurboTweak chips G-bodyparts Full Throttle Speed |
Is it better/worse/no difference with no gaskets? Should I get a set or don't worry 'bout it? Thanks.
I would do gaskets, it won't hurt anything. Really sucks if it leaks when your done without em.
the gaskets are not really needed...i replaced my ds header with a replacement postons header and used no gasket...seals perfectly...i also do not use gaskets on the turbo flanges...everything is bare metal to metal...no leaks here
-Don ![]() 87' Grand National 2nd owner, originally bought in 1998 with 26k miles bone stock, car now has about 120k Best E.T. 11.07 @ 125 mph with stock motor combo, destroyed original block Car currently under construction, new stroker 109 combo in the works (again), should be finished for spring
It helps to lap the headers tube faces flat, before you install the headers. I use a 6" sharpening stone I got from bargain depot 8 years ago for $2.50.
UNGN My OOOOOLD Timeslips Page My OOOOOLD G-body Homepage 1986-87 Illustrated Parts Book Wil's Power Wheel Page |
I think the amount of heat produced would kill gaskets and warp flanges
86 GN, THDP, 3" Torque Tech dual. SOLD and in a dealer showroom '84 Monte Carlo SS 88 Corvette Coupe 88 LeSabre T-Type |
A lesser gasket may be susceptible to heat dmg. Also keeping the header bolts properly torqued is important
Bob D .040 over block - n/a crank - hypers stock turbo/IC/blue tops Yes, I am an alcoholic http://bobdittmar.tripod.com/blown87combobs1987buickgrandnational/index.html |
if 2 flat surfaces have always been bolted together then they wont wap
If you do put a gasket in it it will be hard to get them flat again since the gasket will give when you tighten the header up alowing the flange to warp. I also donot run gaskets I just used a strait edge with self stick sand paper to go across the flages to insure they are flat keep in mind you cant blow a metal to metal joint but you can blow a gasket if you really want it right have the machine shop plane the flanges to be perfectly flat
85ttype 87 powered (resting) , 78 elcamino turblo bruick powered Eastern Virginia Turbo Buicks From Stock To Stage All Types of Buick Repairs Or Mods business is closed ... relocating to jax. florida soon
