Old February 27th, 2003, 02:05 PM
TB flow #s
Has anyone here flowed TBs, and if so, are you willing to share the setup and results?
We considering doing some, but would rather not waste time repeating someone else's good work. I realize you would be giving away info that YOU paid for, but we would be publishing what we come up with for you too. We are considering doing the following (as a start) with what we have on hand:
Stock
Stock Polished
Stock "home ported"
62mm
JJ62mm
65mm
PTE70
???90 (need to vfy mfg)
Dean Nelson
86T w/122k+ mile stock engine, T+/3", 21* Extender, PTE52, CAS V2. Fastest run 12.2 @ 115 on a 2.1 60, 100 unleaded at 22psi through a 3" cat.
Life isn't like a bowl of cherries, it's more like a jar of Jalapenos; what you do today might burn your azz tomorrow!
Old February 27th, 2003, 04:01 PM
blackbuick87's Avatar
I would be interested to see this also. Especially since there are a couple of guys who say they are running 10's on the stock TB
Bob D
.040 over block - n/a crank - hypers
stock turbo/IC/blue tops
Yes, I am an alcoholic
http://bobdittmar.tripod.com/blown87combobs1987buickgrandnational/index.html
Old February 27th, 2003, 04:16 PM
BoostKillsStres's Avatar
TIRE-FRYER VIA HAIR-DRYER
On Jay Jackson's site he had a TB customer that had access to a flow bench and tested in both a blow threw and draw through setup. don't quote me on the numbers but I think stk to 62/65mm porting he does picked up 61 cfm on the intake test and 66 cfm on the draw through test. The info is on his site :
http://hometown.aol.com/ygettv8/1index.html
HTH
87GN : Turbo Buick Club of Atlanta:
The Ride
CPT66BB : BA Performance BMF IC : THDP : 60's : SMC Alkyholic : Direct Scan : SMC EGT : Wideband Closed Loop Chip(The WEAPON) : NEW SMALL FMIC TO PLAY WITH
Old February 27th, 2003, 04:19 PM
NCTURBOS's Avatar
All Appears OEM!!
I know of plenty of guys running the stock throttle body that has been bell-mouthed, but still has the stock size blade, and are running high 9's thru high 10's!
K.
NC PERFORMANCE
If You See One of These...
Turbocharged Drivability & Performance!!
In-House Cylinder Head Porting & Computerized Flow-Bench Testing!!
'87 Turbo-T
Sage Green "1 RARE T"
'00 H-D Heritage Softail
S&S 106cui., etc.
'02 2500 24v CTD
Patriot Pearl Blue, 2wd, A/T, QC, BHAF, MIA silencer ring, J-Hook, 5" MBRP, DSS, MITUSA, Smarty, Redline box...
**FOR SALE!!**
Old February 27th, 2003, 04:30 PM
HTH
Wouldnt draw-through be useless for our purposes since the TB is always blow through under boost?
Bob D
Old February 27th, 2003, 05:45 PM
I think, therefore I am??
Wink Uh oh... some more "competition," eh?
I've said it before, and I'll say it again: the porting to 62mm is only a small part of the modifying I do. The bellmouthing of the TB, matching to the upper plenum, and throttle shaft mods increase the QUALITY and QUANTITY of the airflow! Most everyone that is running a "stock" TB and is going fast has done at least some of those mods, even though the blade is the stock size.
Not everybody has the equipment to do it, and at my LOW price (shameless plug! ) you may as well send it to me for a thorough cleaning and "the works" and know it no longer has airflow disruptions or as much restriction as stock!
Yes, Bob, there are not "as many" gains from these mods since we are blowing through the TB instead of drawing through it. It would make a bigger difference on the hot air cars, but I rarely get the '84-'85 TBs from customers.
Jay Jackson
--'87 Buzda... TA61, PI 7 disc, EP Front mount, ought to run!
--'87 WE4 63K ... heads/intake, TA62, CAS V-4 IC, 50# inj., alky, 62/65mm TB, Translator+, Mease DP, PI 9.5" l/u, Jimmy's Trans., best: 11.65, 116.2 mph, and 1.642 60' Gone, but not forgotten: RIP Andy
--'86 gray T-Type 94K... "YGETV8",11.755@117.89 stock long block & on pump gas! SOLD 6/03
--'86 GN "Beater"... stock combo 12.6@111.97 SOLD 8/02
--'03 Cobra, 11.2@128- stock... yeah, right!
Old March 1st, 2003, 12:31 AM
Thanks for the link, Bob.
:-Dean
Old March 1st, 2003, 02:53 AM
Bob,
I imagine the only reasone he flowed it in that direction was just for comparison number purposes to see how things changed in both directions, I mean if ya got the tools, why not, for the data purposes.
I sure liked the work he did on mine he didn't even make fun of me where I'd bellmouthed the opening
The Ride
Old March 1st, 2003, 03:10 AM
Thumbs up Quote from Jay's Website
QUOTE:
"Stock flow was 480 cfm on the intake test, and 398 cfm on the "blow through" test. After being modified it flowed 541 cfm on the intake test and 464 cfm on the exhaust test."
Thumbs-up for Jay, and his very fine work!
Happy to participate, and thanks!
Help Stomp Out Customer Abuse!
Ripped Off? Here's Helpful Info:
http://www.fraud.org/info/contactnfic.htm
http://www.ftc.gov/bcp/conline/pubs/buspubs/mailorder.htm
Old March 4th, 2003, 12:48 PM
No one else??
Dean
Old March 4th, 2003, 12:54 PM
John Wilde's Avatar
I miss Chris Chow's WE4
Dean,
Looks like you might have to do it your self =)
John Wilde
86 T Type Blue - Driver
86 T Type Black - Resting
87 GN Back Halved - Sold
Old March 4th, 2003, 02:23 PM
d0n_3d's Avatar
What's in YOUR wallet!?
Trader Rating: (10)
i was told there are guys running in the 10's with the stock throttle body/plenum unported and unpolished...
i always figured it was an uneccessary mod? especially for a guy like me with a high to mid 11 second combo...
-Don
87' Grand National 2nd owner, owned since 98' with 26k original miles, car now has about 120k
In the process of returning car back to a stock motor combo after destroying original motor, which ran 11.07 @ 125 mph
Old March 4th, 2003, 06:27 PM
<<i was told there are guys running in the 10's with the stock throttle body/plenum unported and unpolished...
i always figured it was an uneccessary mod? especially for a guy like me with a high to mid 11 second combo...>>
My answer to this is: there are guys running mid 11s and faster with stock intercoolers... doesn't mean a modified or bigger one wouldn't help!
Jay Jackson
Old March 4th, 2003, 07:04 PM
Originally posted by d0n_3d
I always figured it was an uneccessary mod? especially for a guy like me with a high to mid 11 second combo...
Don,
Lots of guys do the JayJackson 62/65mm TB & Ported Plenum mods in the beginning, just as they start to mod their GNs/TRs.
It's one of the most affordable (120 w/cores) mods and it will complement most every thing you do to the motor subsequently.
HTH
Old March 5th, 2003, 04:44 PM
Yep, looks like...
Originally posted by YGETV8
<<i was told...
Exactly. If you have a surplus of time, and have an extremely thorough knowledge of the car, you can fine tune the ****ens out of it. The rest of us depend on easy, relatively inexpensive, upgrades.
:-Dean
