Smoke coming from spark plug hole
For grins, and because I had a day off, I decided to get my GN ready for driving. did an oil change, did some other little cleanup stuff on it.
Started it up, and after about 30 seconds or so it started to smell like smoke. turned it off, popped the hood, whitish smoke is seeping from the rear cylinder on the pass. side (don't know what number it is), from the spark plug hole. Any ideas what's causing this?
87 GN. It's mostly stock... for now. |
Probably not from the hole..
Make sure where the smoke is coming from. If oil ran down onto the head, near the exhaust, it will smoke for a few minutes, then quit. Shouldn't come from a spark plug hole if you didn't have the plugs out/don't have one loose.
George W |
Check if your rocker cover is leaking oil. My leaks on to the head and finds its way to the spark plug hole and starts to smoke for a while. If your rocker covers aren't leaking then I have no idea what's going on.
Re: Probably not from the hole..
It might be pretty simple...
It could be just some "Substance" accumulated in or around the #6 spark plug area and is in the process of burning off. The substance could be water/coolant mixed with a little oil. Is the #6 plug tight? It is the hardest one to get installed. Other possibilities: Leaky heater hoses (Heater control valve is on that side along with the related plumbing) could be dripping on the header? If it dripped when cold, could be burning off the bottom of the header pipe or flange, making it look like it is originating from the spark plug hole. I realize the oil fill is on the other side, however, valve cover gaskets could be leaking. Oil leaks are very possible. It might be bad however... Exhaust leak near #6. Bad gasket or cracked header. Head cracked near the spark-plug hole venting something or a bad head gaket over there? Hope this helps!
'87 GN Upgrades: Postons Headers, Adj FPR, Walbro 307 FP, 30 lb Inj & Ramchargers 91 Street chip, ScanMaster, TypeII Ign Upgrade, MSD SuperConductor wires. Last edited by 6=8 : February 24th, 2003 at 12:54 PM. |
