Old February 20th, 2003, 07:48 PM
I smell gas
I replaced the TPS and it solved my high rpm stumble. But I still smell gas. No leaks that I can see, no hissing sounds. But I can still smell gas, and now O2mVs get up to 830-840 sometimes. Even just cruising. Could I have a leaky injector?
Keith
Keith Hansen
'87TR
12.3@113
Old February 21st, 2003, 12:11 AM
BoostKillsStres's Avatar
TIRE-FRYER VIA HAIR-DRYER
Sounds like a good time to crawl under and check the fuel lines where they run through the frame below the power steering pump. They have rubber hose covering there but my friends was wearing just past it and was almost through...would've been bad...
87GN : Turbo Buick Club of Atlanta:
The Ride
CPT66BB : BA Performance BMF IC : THDP : 60's : SMC Alkyholic : Direct Scan : SMC EGT : Wideband Closed Loop Chip(The WEAPON) : NEW SMALL FMIC TO PLAY WITH
Old February 21st, 2003, 02:17 AM
T-top87GN's Avatar
The Buick Manual CD Guy
YOU can smell it? Oh......sorry
Couldn't help it!!
Jeremy Wood
Wheeling, WV
1987 Slow Black Car
The Buick Manual CDROM guy http://buickman.r00td0wn.net
Old February 21st, 2003, 06:06 AM
TType84's Avatar
cookin with propane
do you still have the rubber weatherstrip at the back of the engine bay that seals against the hood? i hear if you take that off you will smell everything..
nick b. | turbosix.net
8.6@79 . 13.6@98 . 1.91 60ft - JC93 street chip & 17psi
currently:
hofer trans . pats 10" 3k stall . limit engineering stg 3 cheetah . curb weight : 3125lb
Old February 21st, 2003, 11:25 AM
QuickWE4's Avatar
Fuggedaboudit.
Is your fuel vapor canister still in the car or were those lines plugged (or perhaps that solenoid is bad)? That can cause the smell of gas, but I'm not sure if it would be strong enough to notice while cruising.
Just throwing out ideas...
Rich
Rich Cabelo
1987 WE4, 21k-miles - TA49, 009's, Pro Torque 10.5" l/u 3000 stall and Dynotech Shift Kit, ATR SS 2.5" w/Pitbulls/Test Pipe, 3" THDP, Big Mouth Cold Air, Walbro 307 HW, Accufab AFPR, RJC PP, Mease Big Neck I/C w/alum Scoop, Dynotech Engineering Aluminum Driveshaft, Aluminum Drums, Braced front and rear, Bilsteins, Jim Testa 100 Oct Chip
Old February 21st, 2003, 07:56 PM
Thanks for all the replies. I'll check them all except the "YOU can smell it?" ;-)
Keith
Keith Hansen
'87TR
12.3@113
Old February 22nd, 2003, 04:03 PM
OY! It was the high pressure fuel line under the power steering pump. It was rubbing up against the metal clamp on the power steering line and actually rubbed through the METAL fuel line!!! Aychihuaha! Coulda been nasty--although it was spraying gas on the bottom of the power steering pump, nowhere near a spark. But it don't take much. Thanks for the words of advice!
Keith
Keith Hansen
'87TR
12.3@113
Old February 22nd, 2003, 04:19 PM
WHOA!!! Your welcome, glad you found it before the fireball. Happy motoring
The Ride
Old February 22nd, 2003, 06:59 PM
That's a BIG thanks Mark. I had one car catch on fire before; a fuel-injected VW bus. Fortunately there was a fire truck parked next to us and they put it out, but it was scary.
Again, thanks.
Keith
BTW, see my next post. Low low BLMs (96-128), high O2 volts (777-830), with vac-off fuel pressure at 34psi. What's up with that?
Keith Hansen
'87TR
12.3@113
Old February 22nd, 2003, 07:01 PM
When will it end?
Just for the info
I recently had a fuel smell that was driving me crazy, it kind-of smelled like it was around the drivers door, then like it was around the back of the car, then the whole blasted car smelled! I finally found it! It was one of the rubber lines up on top of the fuel tank. It leaked enough to smell, but as it covered the top of the gas tank, (it was a very small leak), it would evaporate before you could see the liquid. I went ahead and replaced all of the rubber up on top of the tank. BTW there is a DIFFERENCE between fuel injection rubber hose and non-FI. There's a difference in the clamps as well, make sure you ask! Hope that helps. - T
