Old February 5th, 2003, 09:34 PM
Question conversion
Now i was told that all I needed was a TTA vacuum block to convert my brake system over... I ordered a part from ramchargers... this is what they gave me when i told them exactly what I was doin.. Billet Vacuum Block.. Then on the back it says Billet vacuum pod with brake tap.. is that what i need??
Old February 5th, 2003, 10:24 PM
Quick6'n'-K.C.'s Avatar
wana steal it? meet mr9mm
Trader Rating: (8)
yes sir
just make sure that your check valve on the brake booster is in good working order--
its the 90* black elbow part that connects the hose from your new part to the booster-
it should only blow one way---- if not you will PRESSURIZE the booster under WOT boost-
just blow into the check valve on the booster and see if it works correctly
HTH
BW
