I just got back from taking the GN through it's dreaded annual inspection. Failed with 553ppm on hydrocarbons, 220ppm limit. CO was 1.5% with 1.2% limit. Outside temp was about 30 degrees. I could only get the car to about 160 - 164 temp. I seem to be having some troubles with running rich at idle. When I first got in line, the BLMs were @ 105. I had to sit in line for about an hour. Over that hour the integrater values were bouncing around 130 to 135, and the BLM worked it's way up to 121 by the time I tested. TPS was .42, IAC was 17 to 19, filtered load variable was in the mid 30s. I thought I had a good chance of passing at that point. I'm running 868 36lb injectors and a mild 93 octane chip burned for the 868s by Joe Lubrant. I've passed the past 2 years with the same chip. The only major change to the car since the last inspection was the OEM MAF went south and I replaced it with an LS1 MAF/Translator. The translator is set to read a "normal" chip. I do run a "high flow (yeah right)" 3"cat with internals intact on a THDP. I'm wondering if either the EGR has ceased to function or my cat has given up. It has seen leaded race fuel 5 or 10 times at the track. I had also just replaced spark plugs (they read rich) CRT43s @0.035", and a new GM O2 sensor.
I guess I'll be checking EGR functionality next, maybe replace the cat and give Turbodave a shout for a "special" chip. Any other ideas ?
Jeff Wasson 87 GN - 60#inj, ported iron heads, T&D 1.6 roller rockers, port matched lower intake, CC 212/206, CC lifters, chromoly push rods, billet double roller timing gear, RJC powerplate, PTE-44, V4 intercooler, THDP, Red stripe converter, 2.5" dual hooker catback, walbro 307 hotwired, Nitto Drag radials, scanmaster 2.1, LS1 MAF/Translator w/extender chip or turbotweak chip, SMC alky kit, TCI rebuilt tranny, TCI valve body kit. GN pics and video: http://home.midsouth.rr.com/wassons/grandnat/gn.html |
What temp is the radiator fan set to come on? Most chips call for the fan by 170*.
You could get another chip programmed to NOT turn the fan on till 195*. Another way is to partly block the radiator with cardboard so it will heat up. You need the engine to be hotter than 180* IMHO. Not saying that there could be other things that needs looking at too. Gary |
leaded fuel through a cat==dead cat. period.
87 GN with dual catback from monte, big mouth CAI, walbro 340, kirban adj fpr/guage, world record slowest car yet with maxeffort mafless, BstC boost controller, DS, msd 50lb/hr squirters, rjc power plate, airbags. best/only run so far: 14.6 @ 87mph @ 25+ psi of (accidental) boost on 93 octane. Just needs paint!!! newest mods: nos fuel sol type 7th squirter, te45a (67mm gt wheel), precision fmic, atr rear sway, lt1 starter, .030" over with forged pistons, billet steel caps (#2/3), 224/224 flat tappet, double roller chain, .010/.010 crank, etc. |
No access to a pyrometer unless I can find one at an exhaust shop. Our emissions here only checks HC and CO. No O2 or CO2 numbers available. I think my fans are kicking on by 170*. Due to odd circumstances, the last 2 years I was testing in April and was able to get the temps up over 190. I'm sure that had alot to do with it, but I also agree the cat is probably gone due to the race fuel. At this point I've some different registration arrangements that will not require inspection..nuff said
Jeff Wasson 87 GN - 60#inj, ported iron heads, T&D 1.6 roller rockers, port matched lower intake, CC 212/206, CC lifters, chromoly push rods, billet double roller timing gear, RJC powerplate, PTE-44, V4 intercooler, THDP, Red stripe converter, 2.5" dual hooker catback, walbro 307 hotwired, Nitto Drag radials, scanmaster 2.1, LS1 MAF/Translator w/extender chip or turbotweak chip, SMC alky kit, TCI rebuilt tranny, TCI valve body kit. GN pics and video: http://home.midsouth.rr.com/wassons/grandnat/gn.html Last edited by JeffW : January 27th, 2003 at 06:35 PM. |
