What fittings will I require for this install?(I didn't get the install kit as my friend works at a brake shop)
If anyone can give me a list of all the adapters I will need to install the line loc, it would be appreciated. I would like to do it as per NHRA rules so I don't have to install it twice. Thanks!!!!!! ![]()
86 TR Leather,column,astroroof T-netics 66BB S-trim, ME-R Razor dual nozzle alky, 75lbrs, Powerstroke IC 210/215 roller, Forged stroker, TA headers, HR Bar 10.9 at 133mph 3700lbs w/driver |
A couple of 90 degree 1/8 NPT reverse flare fittings, a reverse flare brass T, a 1/8 NPT plug and two pieces of brake line will get you in business. Check out gnttype. There is a good picture on there about doing it the NHRA way (it's the bottom diagram). I mounted mine right on the proportioning valve bracket with two heavy duty 13mm headed screws. Mock up your brake line bends with some coat hanger and then bend them to fit. The left lower control arm bracket provides some shielding to alleviate any fears of it being torn off due to road debris. Good luck!
87 GN: TA-54, stretch big neck, 72s, ATR DP, SMC, 3200 9/11, homemade DP (340s) hotwired, ME-R 64 Grand Prix 389 Tri-Power, loaded, frame-off resto, mild cam, Turbo 350 trans retrofit - SOLD 1/28/05 - a sad goodbye johnkiml@comcast.net Last edited by John Larkin : May 31st, 2002 at 09:29 AM. |
Supposedly the NHRA says it should be after the combination valve. Well, if its after the combination valve, the NHRA won't know you have a line lock anyway, so even that was good enough for me.
The fittings you need to install it at the combination valve is: 2 complete lines with inverted flare males, (6 - 10 inches long) (standard brake line size) 1 inverted flair "Tee" fitting (standard brake line size) 1 male plug for combination valve standard brake line, an as many as required to plug any extra ports in the line lock body. 2 Inverted flare female to npt male fittings (to mate the lines to the Line lock body) Undo the front two brake lines from the combination valve. Slighty bend one and thread them into the inverted flair "Tee". Run a line for the "Tee" to the outlet of Line Lock. Run the other line from the inlet of the line lock to the combination valve. Plug the remaining port on the combination valve. Mount the line lock to the shifter bracket near the combination valve. Bleed the brakes, run a wire to ground and run the power wire through the shifter boot into the console, to the switch, light and fuse box. and you are done.
UNGN My OOOOOLD Timeslips Page My OOOOOLD G-body Homepage 1986-87 Illustrated Parts Book Wil's Power Wheel Page Last edited by UNGN : May 31st, 2002 at 09:26 AM. |
Just where are you installing the line lock? I know mine may not be NHRA legal but if you need any help installing it off the master cyl. let me know. I have had mine on for many years with no problems! Nice thing is no cutting of the original lines.
Dave Here is a pic of it http://www.geocities.com/turbod1987/pics/page20.html
______________________________ 87GN 11.12@120.4mph 87 Regal T 11.73@114.8 TurboD1987's HomePage |
Wow, thanks for the replies guys!
Hmmm.....now where should I mount it......... Under the hood sure looks easy enough, but will it be legal for drag racing? Oh, by the way, i have a vacuum brake setup, not the powermaster, so does this affect which line I connect the line loc to?
Myself and several friends have our line locks (Hurst Roll Controll) mounted just like TurboD1987. As far as I know, the tech inspectors have never said anything.
-Banning.
Banning Cohen 1986 T-Type WH1 10.62@125.45 (1.43 best 60') Project GRrrr - 1984 T-Type WH1 $200? Grassroots Motorsports Challenge car Mid-Atlantic Grand National Association (MAGNA) Club Director & Delaware State Rep. Mods: Budget 4.1, PT67 turbo, Bronsonian ported heads w/stock valves, Razor's dual nozzle, Comp 214/214 roller cam, Powerstroke IC, Aeromotive pump, 83# injectors, TurboTweak Wideband, Michael's Auto TH400 w/transbrake, Pat's 9" converter, Moser spool & 33 spline gun drilled axles. |
86 442 T-tops 307 Accell ignition components, hypertech chip, shift kit, hardened stator support,D5 2400 stall, B&M tranny cooler, 8.5 3:73 posi, T/A cover, 36mm swaybar, ATR rear bar, SCandC frame brace, SCandC stage II, Edelbrock UCA's, currie LCA's, Bilsteins, 5660's/hotchkis, Hooker Aerochambers, tint, monster tac w/ light, Pioneer deh77dh, Pioneer deq-9200 Pioneer 3way 4X10's,2way 3 1/2s' and 2" tweeters 2 10's. 88 LX hatch Ground pounder K member, billet caster camber plates, ground pounder adjustable coil overs, flaming river rack, cross drills. 5 lugs, pro stars gettin a GN drivetrain |
line lock ?
I installed mine on the fender well under the MC using the Hurst install kit. It had everything I needed. Works fine with vacuum brakes (line lock doesn't know the difference).
Chris Campbell Engine Machined @ Jackson Cylinder Head by Geoff Burroughs Engine Built @ Alexanders Automotive by Randy Alexander GN>Girdled 109 , TRWs std bore , 218/212 roller , T&D 1.65s , 70mm TB/plenum , ported irons, intake and exhaust (Randy A) , PTE FMIC , te45a , stuff to make it all work.....10.84/125-stock MAF TurboTweak chips...thanks Eric! 06/01/08 update...CruzMissile in the works.... TTA..."wifes" car |
To answer your question the brake light does come on for about 5 seconds while you are using it to do a burnout.
Goes right out when staging. Installing it up top is relatively painless. Not so sure it would be down below. Here's another pic. of mine on the GN. Hurst Roll Control, mounted on the raised boss near the windshield washer tank. Other mounting end has a spacer on it to raise it to the same level on the fenderwell. http://a3.cpimg.com/image/7F/EB/4189...-02000180-.jpg |
You make or buy two new lines and put only VERY slight bends in the factory lines, so you can put your car back to stock in minutes. No screw holes drilled into those irreplaceable inner fender panels, either.
UNGN My OOOOOLD Timeslips Page My OOOOOLD G-body Homepage 1986-87 Illustrated Parts Book Wil's Power Wheel Page |
heres a pic of mine after the prop valve using the hurst install kit from summit and a little bending
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com Last edited by pacecarta : December 25th, 2007 at 09:58 PM. |
