| General Turbo Buick Tech Technical discussions |
blown cometic
or just leaking? Putting a little water in #1 and compression is down about 20lbs in that hole. Also leaking out the side of the head. has about 1300 easy miles on it.
'87 GN 1 owner US NAVY '66-'70 USS Proteus AS 19 USS White Sands ARD 20 support ship for the Trieste ll Scorpion Operations Phase ll USS SCORPION SSN 589 on eternal patrol, May 22,1968 http://www.decklog.com/SSN-589.asp ...there's two dates on your tombstone and all your friends will see 'em but the only thing that matter's is that little line between 'em... |
| Sponsored Links |
yes I did. No change.
it did blow. 24lbs, 0 knock showing on the FAST. what gaskets do I use now?
Billy T. gnxtc2@aol.com
1987 GN w/ TA Block and heads Other vehicles - 1997 Ford F250HD Powerstroke (daily driver) - 2004 Mercury Marauder #956 out of 3213 Pictures If you can read this, thank a teacher. If you can read this in English, thank a Vet. ![]()
where heads prepped with RA50....been issues without proper head and block prep
Sean Ryder aka gbsean on all the boards Buick Performance Group Chairman www.buickperformancegroup.com 11.599 @ 119.91..with issues |
ra50 on heads and block. 10.94 A/F, 19 on the timing after 4200rpm, duel nozzle alky. heads torqued at 70lbs ,arp studs. Went to 80 to see if the leak would stop. RJC gaskets on the way. Car still ran pretty good.
several people (myself included) have had to take apart the Cometics and spray the layers with copper coat or hylomar. I have no leakage issues at all. hope this helps.
Jeremy DSR Member #82 http://community.webshots.com/user/jpwalt1987 http://evadaleraceway.com/index.html http://www.swmuscle.com/portal/index.php?action=forum |
It blew the gasket, to late to copper coat it.
+1 on the pics, really interested, take a few macro pics if could. I can pass you my e-mail if it is easier.
Pullin' like a freight train, Flyin' like an airplane, Been drinkin' gasoline, And honey you can make my motor hum... |
no pics right now but to compare to a good gasket , it wont lay flat on the cylinder that let go , the metal stretches and warps
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers |
here you go. head studs, 83lb inj.Number 1. Bad gasket? Bad luck?
'87 GN 1 owner US NAVY '66-'70 USS Proteus AS 19 USS White Sands ARD 20 support ship for the Trieste ll Scorpion Operations Phase ll USS SCORPION SSN 589 on eternal patrol, May 22,1968 http://www.decklog.com/SSN-589.asp ...there's two dates on your tombstone and all your friends will see 'em but the only thing that matter's is that little line between 'em... Last edited by SIXBANGR; July 7th, 2009 at 09:42 AM. |
I would flow test your injectors and have a look at your spark plugs wires.
Mike Ricketts ![]() DLS built 4.1 StageII/ 76turbo/ 44mm Tial/ BG ported intake/ 1.75 T&D jessel style rockers/ FAST system/ TH400/ PTC converter (Thanks Dusty)/ TA heads/ 5" DP/ TA SS 4 bolt Headers/ Champion Racing/ RJC front mount/ 95lb/ Racetronix harnesses throughout the car etc... Cal Hartline tuned........ DLS ENGINE DEVELOPMENT 886 E 900N, Wheatfeild, IN, 46392 219-956-3653 HARTLINE PERFORMANCE 321-722-1563 My Track passes http://www.youtube.com/watch?v=mKEIyppgOr0 http://www.youtube.com/watch?v=6SqbYtfQn8c |
who does the inj., and how much?
Were you using oil or ARP lube when torquing to 70 lbs. If using oil 70 is a little low. Although I doubt that's your problem. As stated have injectors flow checked also check the injector driver in the ECM.
Scott Atkinson / White 87T 109 / 9.56 @ 142.8 / 1.38 60ft. http://www.youtube.com/watch?v=Flmtrjx8hM8 |
ARP lube. Just pm'd Leeper. Using a classic FAST.
I wouldn't be blaming the gasket on that one. It appears you lost clamping force for whatever reason. A tuning issue, most likely. How much has been taken off the head surface? How thin are the deck surfaces?
Donnie 1984 BUICK Grand National 224 cid Stage I BUICK V6 burning CH3OH w/N2O, 91mm turbo. Engine/trans/tuning by me. Latest 1/8 mi. perf. (8/2010) w/FI91X (B/W Airwerks S510-91mm): 5.74@126.21mph, 1.28 60', 290 kPa MAP (27-28 psi boost). 5.27 Bhp/cid. Equivalent to a 500cid V8 producing 2,635 Bhp. My pass @ Pinks All Out qualifying, http://www.youtube.com/watch?v=9AZumqEdMUE "What the h#ll is it?"
Double check the head studs/bolts to be sure they are tightening down properly and not bottoming out,That was not the gaskets fault
Now Precision Turbo,F.A.S.T ,Moser Engineering,Comp Cams,Alky Control and Metco SCT,VMP,RJC Racing dealers Custom built racing transmissions ZDDP in stock at all times |
heads were milled .003. It was a non machined na109 block that I just had done 3 months ago. FAST shows nothing wrong. The inj are ready to ship, just have not heard from Chuck yet.
it has studs right now. For some reason I have never had good luck with them.
again double check that head seats all the way down on block without the gasket in place...
just checked, it is perfect.
And too late to re-torque it. being its number 1 and not 3,, its probably from not enough tq on the stud. 85 ft lbs is what most of us use.
![]() Matthew 22:37-39 37 'Love the Lord your God with all your heart and with all your soul and with all your mind.' 38 This is the first and greatest commandment. 39 'Love your neighbor as yourself.' http://stores.ebay.com/ALKYCONTROL_W...eNameZl2QQtZkm |
85 here and re-tq after first startup....You have Pauly in your corner....what does he say about the failure
#6 looks like it was going to go next. When I looked at the plugs a few days be for, 1 and 6 looked rich.
and when I researched it 3 months back it was 50/50. So i went with 70 figuring I could always go more. It's like head bolts or studs. About 50/50 there also.
One of my buddies goes 85 on the top and 80 on the bottom. His feelings.. Its always better to blow the gasket down than up. Then you get X amount with oil and X amount with ARP lube. I lube the threads, washers and three steps to 85. 40/60/85 But thats just me
When I asked Dan @DLS about stud torque he told me 70ft/lbs on all the studs. That is with ARP lube.
