General Turbo Buick Tech Technical discussions
Old June 23rd, 2009, 05:43 PM
86Nick's Avatar
Not your Grandpas' regal
Trader Rating: (19)
TA Performance headers
Just bought a used set of Stainless steel header made by TA. They look good for what I paid for them, but one pipe has a crack in to the flange on the passenger side header. Anyone know if TA does any repairs on there products? If so how is the customer service? Here is a pic. I have a cheap camera so pic may not be very good.
86 t-type
30 over stock block with billet caps and ARP studs, mildly ported stock headswith ARP studs,PAW cam,Garret Te-44,55lb Inj, SMC Alky, MAF Translator,LS1 Maf,RPE ported and polished intake, Precision 70mm plenum and 70mm Accufab TB ,ESP front mount intercooler,3"Terry Houston DP,Poston Headers, Hooker 2.5 exhaust, Dynomax bullet mufflers,UMI lower control arms,ATR rear swaybar,RR airbag, Extended pinion snubber,TR 3.5"MAF pipe, Pete Tomka Coldair kit,scanmaster 2.1, Turbo tweak chip,Turbolink,B&M linelock,Ramcharger dual fans,TCI converter,Kenne Bell air dam,Casper fan control,AVC GNX dash,Greddy Boost control,Robotron LapTop mount.
Sponsored Links
Old June 23rd, 2009, 05:50 PM
chrisgarrett's Avatar
Registered Member
I've had a lot of success with their customer service. I've been considering a set of TA headers for a while, so I'm sorry to see that they can crack like that.
218/212 Comp roller cam, Cat stroker, RJC gridle, CPT66BB, PTE Stock Location IC, Champion iron, T&D roller rockers, 60# Mototron injectors w/Turbotweak chip, Monroe-ported throttlebody, RJC Power Plate, Jimmy-built trans w/Precision Vigilante converter, ATR SS dual exhaust, ATR rear sway, BMI upper and lower control arms, Edelbrock Performance shocks, Razor alky, Tinman cold air intake, MT street radials.
Old June 23rd, 2009, 05:59 PM
rmar's Avatar
10 SEC GN
Images: 4
Sorry, They can not be fixed.....
But I will give ya $100 for them.........
Ronnie Martin
87 GN, 25K, 10 sec.
(Will work for Parts) No seriously I will
Powder Coating and Performance Coating
WWW.MyPowderCoating.Com
WWW.TurboTweak.Com
It's always the Tuna (Grumpy)
This forum requires that you wait 45 seconds between searches. Please try again in 18 seconds.
Old June 23rd, 2009, 08:28 PM
Heavy,Black and Handsome.
LOL.
Old June 23rd, 2009, 08:57 PM
V6RACER's Avatar
2008 TSM Champ Finally
Call them. I'm sure they will fix you up.
Jason White
Thanks Hartline Performance, Don Cruz, DLS Engine, HRPartsNStuff, & Twisted 6 Racing convertors
Pine Tree Posse member #0909
9.09 @ 149 and their is more left in it
Can it go 8's with a hydraulic roller??
Old June 24th, 2009, 10:07 AM
pacecarta's Avatar
looking at the pics the tubes are welded around the outside of the pipes ,
hate to say it but from what ive seen those arent TAs , they are the china knockoffs.
paul - MAGNA NJ rep
the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston
the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers
big thanks to
julio at alkycontrol.com
eric at turbotweak.com
A little fun with the GNs at Atco video
Old June 24th, 2009, 10:28 AM
Registered Member
What I want to know is, why did you have your headers in the bathroom?
Old June 24th, 2009, 01:50 PM
86Nick's Avatar
Trader Rating: (19)
better lighting
86 t-type
Old June 24th, 2009, 01:53 PM
86Nick's Avatar
Trader Rating: (19)
I don't know about that The China knockoffs have a different side passenger header. The crossover on the China's do not bolt up to back of header the bolt up mid way up on the header nearturbo flange like the Kenne Bells.
86 t-type
Old June 24th, 2009, 02:01 PM
pacecarta's Avatar
ther atr-kb knockoffs dont look like the TA but there are TA knockoffs (do a search) the ta knockoffs look alot like them as far as tube layout , but not at the flanges , TA uses mild steel for the flange to head , yours look stainless , ta welds the tube from the inside of the flange , yours are definitely welded at the outside same as all china headers
like i said looking at just what you have to see they look like the knockoffs
and mark huffman sells a TA 'style' header that he calls a SE style header , http://www.buickgn.com/headers.htm
paul - MAGNA NJ rep
big thanks to
Old June 24th, 2009, 02:41 PM
86Nick's Avatar
Trader Rating: (19)
and mark huffman sells a TA 'style' header that he calls a SE style header , HEADERS STAINLESS STEEL
I just called TA and your right about the welding. I guess a got taken on these. I paid less than Mark sells them for though. I thought for sure they were TA. OH well live and learn I guess. I think they will look and hold up better than the stockers. Thanks for letting me know, but damn you put a black cloud over me now.
86 t-type
Old June 24th, 2009, 02:47 PM
rmar's Avatar
10 SEC GN
Images: 4
If they fit, weld them up and go. Won't hurt a thing.
Ronnie Martin
87 GN, 25K, 10 sec.
WWW.TurboTweak.Com
Old June 24th, 2009, 03:59 PM
TR Custom Parts's Avatar
Mark Hueffman - Owner
The ones you have are NOT the ones we sell.
Mark Hueffman - Owner of TR Custom Parts
1987 GN Bling & Sting Test Vehicle
6262 BB Turbo / Bison-Built 2004r/ PTC 9.5 NLU Converter/ Razor Alky / 60 lb injectors / TT 6.0 chip / Big Mouth Cold Air & 4" MAF pipe / Z06 MAF sensor / SE FM Intercooler / KB style Headers / Dual 3" stainless exhaust / Electric exhaust cutout / Powerlogger
mhueffman@snet.net
Sale thru 2-16-10 on 6 piece aluminum pulley sets $50 OFF!, stroker cranks $125 OFF!
VISIT OUR WEBSITE BY CLICKING THE BANNER BELOW.
Old June 24th, 2009, 04:15 PM
86Nick's Avatar
Trader Rating: (19)
What makes you so sure? The pic only show partial pipe not even a whole header or crossover. Not trying to relate my cracked junk to your headers or hinder ant sale for you, but for what I seen on your site and what I have they look the same
86 t-type
Old June 24th, 2009, 04:19 PM
ummm, maybe because they just came out.
mhueffman@snet.net
Old June 24th, 2009, 04:39 PM
Nice Monte is that an SS
The TA headers have their name engraved on the head flange.
Old June 26th, 2009, 08:15 AM
86Nick's Avatar
Trader Rating: (19)
Had crack welded up. Anyone want to buy them? I want to sell the knockoffs and get the real ones. Any interested PM me.
86 t-type
Old June 26th, 2009, 08:36 AM
dr_frankenstein's Avatar
Mad Scientist
PM sent.
http://www.youtube.com/watch?v=ykgDNjeTa0g
Almost Complete: 79 Buick LUV, 6-71 Supercharged 274ci Stage 2.
Just Starting: 79 Buick LUV, Draw Thru Turbocharged 231ci Stage 1.
Bookmarks
BB code is On
ATR or TA Performance Headers ?? 87LtdT General Turbo Buick Tech 27 August 30th, 2008 09:32 AM
TA Performance Headers?? NCTURBOS General Turbo Buick Tech 17 April 25th, 2008 01:50 PM
GN1 Performance New Headers 1991syclone General Turbo Buick Tech 100 November 15th, 2007 02:08 PM
Who has TA performance headers on their car? jsta6 General Turbo Buick Tech 17 April 24th, 2007 02:29 PM
TA Performance headers? Downpipes? Qwerty1634 General Turbo Buick Tech 8 March 26th, 2007 09:10 PM
