General Turbo Buick Tech Technical discussions
Old May 31st, 2009, 08:02 PM
meanchicken's Avatar
gallo vicioso
Installing rear bumper fillers
OK. I'm about to start pulling things apart to remove my original fillers and replace them with G-body parts fiberglass fillers.
Help me save some time.
I'm about to start this job.
I looked under there and it's obvious the rear bumper needs to come off, and also the gas door, but do the tail lights need to come off?
Any tips for fitting them properly?
Thanks!
Sponsored Links
Old May 31st, 2009, 08:08 PM
pacecarta's Avatar
yes tail lights need to come off
only tip is be generous on the holes when you drill them, they are easy to see where they need to be drilled out
I also like to drill large holes on the depressed area under taillamps so that water can drain out
paul - MAGNA NJ rep
the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston
the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers
big thanks to
julio at alkycontrol.com
eric at turbotweak.com
A little fun with the GNs at Atco video
bagged84regal's Avatar
Thanks!
I think it would prob make it a little easier to take them out and put in b/c you would have more room...and worse case you take them out and its only a few of them wing nuts that need to come off and back on each side...
Old May 31st, 2009, 08:19 PM
gallo vicioso
thanks, guys.
Is there a seal or gasket behind the tail lights that I need to replace?
87 Grand National: Czarnota built V6 (210/210 roller); ported heads; port matched intake; 3200 billet 10" lock-up stall; street/strip 200R4 courtesy of Lou's guy; Precision TA-61 (Thanks Spoolfool2); 3" Terry Houston DP; TT Alky chip; 60# inj; Hotwired Reds XP; ScanMaster 2.1; Adj WG actuator; AFPR; 160* stat; RJC Power Plate and boost controller; Alkycontrol; TRC Big Mouth; Eastern Performance FMIC; Hooker cat back ...with test pipe and open dump on race day; Direct Scan; and a boost gauge Otherwise bone stock.
www.turbolou.com
68 SS Camaro: ZZ502; TKO-600; Moser 12-bolt; Global West tubular control arms, QA1 coil overs; SSBC power disks; quick ratio steering; Hotchkis sway bar; Be Cool rad; other stuff.
Old May 31st, 2009, 08:25 PM
pacecarta's Avatar
no seal
paul - MAGNA NJ rep
big thanks to
Old May 31st, 2009, 08:27 PM
Originally Posted by pacecarta View Post
no seal
X2....Extremely easy to take them off...
Old May 31st, 2009, 09:46 PM
gallo vicioso
OK...I got the gas tank out of the way and the control arms loosened up....what next
Kidding....
Everything is out of the way.
I marked up the spots I need to drill and am about to start drilling the new fillers
www.turbolou.com
Old May 31st, 2009, 11:24 PM
gallo vicioso
This is taking longer than I expected.
I got the driver side on there, but need to do more tweaking on the filler. There is some interference at the panel that goes behind the gas door. The filler will slip behind it, as I assume it should, but it bumps into that panel and also on the nut that the gas dooe bolts to. Due to that interference, the gao between the tail light and the filler gets larger as you get closer to the centr of the car, and the top of the filler on the side does ot line up very well. with a little clearancing....I should be able to make that better.
So I need to pull it back off and grind away more filler.
to be continued tomorrow...
I'll take some poix and post them also...should help others who are thinking about going fiberglass.
www.turbolou.com
Bookmarks
BB code is On
power antenna,bumper fillers(rear) (rear)wheel well trim tntdiablo Parts wanted 12 October 19th, 2009 09:22 AM
Rear Bumper Fillers F/s!!! 3.8L V-8 eater Parts for sale 7 March 30th, 2009 12:40 AM
Help installing fiberglass bumper fillers Sal Lubrano General Turbo Buick Tech 9 May 9th, 2008 01:30 PM
Need Rear Fillers/Bumper Fillers Saladin45 Parts wanted 0 April 20th, 2008 08:50 AM
Just finished installing S&K Industries bumper fillers...pics inside justabuickv6 General Turbo Buick Tech 1 July 4th, 2005 06:26 PM
