| General Turbo Buick Tech Technical discussions |
went to the track last night and WTF
i went to the track last night and i cant make boost on the line to save my life. No burnout (since i dont have line lock), aluminum drums, s-10 brakes, i even tightened them up a little bit before i went. i have tried holding the brake and just stomping the gas, rolling into the gas, half throttle.... thats only the beginning. i was also having a horrible stumble coming into boost in first gear. i have a dual nozzle alky kit so i pulled the alcohol back a little bit and that didnt help. when i rolled into in on the way home it was fine, could it be loading up with fuel from being held WOT for 5 seconds before slowly rolling off the line with 0 psi?
87 GN girdled 109, JE pistons, stock crank/rods, ported gn1's, 214/210 roller cam, 1.65 rocker's, PTE-70 GTQ, pte front mount, 75# injectors, lt1/translator+, welded stock headers, TH 3.5" downpipe, 4" cold air kit, rjc pulleys, double-pumper, champion intake, razor alky, dynotech built 2004r/ ptc converter, UMI upper/lower control arms, HR rear sway bar and lot of other "little" stuff. 630rwhp/630rwtq on 91/meth 26psi 25/23 2005 ram srt-10 quad cab, k&n, roe racing tune, magnaflow exhaust(thats all i can afford to do )2008 trailblazer SS, my wife wont let me touch it!! |
| Sponsored Links |
its a twisted6 (dusty) PTC 9" NL (2004r) spec'd for similar combo to his (gn1s and 70CPT ,3600lb car only that car had a bigger 224/224 cam ). it was sent back to Dusty to correct (was a little loose) before it ever saw the track . if i had to guess its what he calls a 3000 which doesn't relate to any other converter as his typically spool well and couple even better at the big end
.. that converter went 1.41 on a 5lb footbrake launch (manual brakes , turbonetics external racegate with MSBC-1 controller) running only 20psi on a TT alky chip and then before it was run again was installed into his car .... only has maybe 8 passes on it and went 10.18 129 at that boost in the other car
paul - MAGNA NJ rep the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers big thanks to julio at alkycontrol.com eric at turbotweak.com A little fun with the GNs at Atco video Last edited by pacecarta; May 2nd, 2009 at 05:58 PM. |
update on the stumbling issue: ok, so when i punched it off the line it would cut out, and not come back to life till i let off the gas. but it also does it free-revving too
im thinking bad MAF? if i roll into boost its fine afr's dont get above 10.7
Bad MAF did it to me, or your TPS? check the value readings
1985 Buick Grand National: 78,000 miles. New 109, Intercooled, complete engine back ceramic coated ATR Stainless Exhaust, TA-49 turbo, UMI suspension,TRW forged STD pistons, 204/214 Cam, Ported: heads/intake, 42.5# inj., 3.5"intake/K&N, 3.5" LS-1 MAF& translator, 87 ecm, heater/AC delete, hotwired Walbro 340, elect. fans, Eric Marshal chip, Brian H built Trans with brake,3100 stall L/U Art Carr, deleted smog, ARP studs, To much little stuff to list.. Old Combo 11.97@110 / 1.6 60' 1999 GMC Sierra Z71: EFI Live Programmer, small mods. 1992 Plymouth Laser RS: Palm Logger, 16PSI, No Balance Shafts. |
Untitled Document
1987 GN, 87 TR, 2002 Sebring convertible, one happy insurance agent My email is rudydog33@comcast.net Please don't PM me. Newest addition-1986 GN with 25k miles. Garage Queen to the max!
paul - MAGNA NJ rep the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers big thanks to julio at alkycontrol.com eric at turbotweak.com A little fun with the GNs at Atco video |
good call its a possible reason but doesnt explain the free reving issue sinc eno boost should be present
he added dual nozzles since he got it , lot more fuel being dumped in when i went duals on my 86 with a std tt chip it would bog an die coming out of the hole ,little embarassing having to back up and try again . i had move the alky turnon to above my launch boost knowing i didnt want it hitting that hard while i was spooling , but it still knocked the car right down... ended up hooking the alky reduction wire on the pac while i was on the brake . when i went wideband correcting the chip would correct i also only run my alky gain knob at mid point or little less and thats been good enough for running 27psi no kr on iron heads but wasnt comfortable at that level for the full 1/4 on stock bottom end , does it build boost .....are the ic hoses still connected ?? oh one other thought comes to mind , not knowing when the alky kit was built and i know the t+ isnt the latest version chip. contact razor about hotwiring the translator as there were issues with it being used with alky causing maf dropouts because the translator and the alky pull from the same fuse and the older alky kits were noisy
paul - MAGNA NJ rep the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers big thanks to julio at alkycontrol.com eric at turbotweak.com A little fun with the GNs at Atco video Last edited by pacecarta; May 3rd, 2009 at 09:35 PM. |
WWW.CFGNT.COM (1987 T-Type).T.S.M built-109blk(thanks,87gta-turbo)8pt roll cage,precision72 turbo/.85ar,rjc girdle/crank scraper,weber 218 billet roller cam, ported/polished heads 1.77valves ported to stage2 specs,70tb/pl,rjc pp,83lbinjectors,7th injector,zo6 maf sensor,4" maf pipe.040 pistons,double pumper,3.42 gears,th400,art carr 9" converter from Cal Hartline,tony dequick v-2 frontmount from Louie Lopez.Drivetrain built by me...Special thanks to Central Fl Machine and Speed,Hartline Performance,Murrey's speed shop,Automotive1 speed shop,Precision Turbo,Full Throttle speed,G-body parts,postons enterprise,esp products,kdk performance,Lkq salvage,summit racing,cotton's performance,Kenny Wells Performance,Pro-Tree Customs Paint/body, Louie Lopez and Ace Hardware(lol).
as to the stall #.... ill just say dusty does things different and this one was on the mark
hot wiring the translator may be the way to go, the scanmaster is picking up and reading the maf, but do you think the razor kit would still interfere even when the pump isnt running?
if its not running its not going to be in the picture so.. no
Not to sound like a stupid but could it be a bad coil pack?
87 WE4-factory radio delete, pwr windows, rear defrost, pwr antenna, that's it! Is this thing EVER gonna get finished ...and a 93 t/a hartop FOR SALE!!! Leather, six speaker stereo, auto, good condition. Excellent driver. Well maintained. |
| Bookmarks |
| Track NIGHT!!!!! | gn86randy | Hawaii Buick Enthusiasts | 5 | February 18th, 2006 12:35 AM |
| Really Bad Night At The Track | XLR8 | General Turbo Buick Tech | 1 | June 23rd, 2005 09:21 AM |
| Bad night at the track friday night | Turbojorge | General Turbo Buick Tech | 0 | October 6th, 2002 12:25 PM |
| Had a bad night at the track last night | d0n_3d | General Turbo Buick Tech | 6 | September 14th, 2002 08:19 PM |
| Saturday night Track night? | gokada | Hawaii Buick Enthusiasts | 4 | January 20th, 2002 07:15 PM |
