| General Turbo Buick Tech Technical discussions |
LinkBack (1) | Thread Tools | Display Modes |
| Sponsored Links |
I'm no expert by any means....
How a car transfers weight matters. The "Shock" to the car when it launches, and even the stance of the car could have an effect. Power level can be taken into consideration but is not the key to it. I was always told the yanking a tire was bad because the time spent twisting the car to pick that wheel up adds time to heading towards the finish line. Looks cool, though.
Much Thanks to: Eric Marshal, Grumpy, Russ, Razor, WickedV6, Dr.Boost, RUQUKNF, TurboT990, Kevin B, Bison and a host of others!! 85 T-Top GN(LC2) 109, Iron Heads, Alkycontrol, Stock Suspension, Scanmaster, Stock ECM, and Stock Wheels 1/4 E.T MPH
"Yanking the tires" AKA: pitch rotation, is reaction to the acceleration of the vehicle. Once the ft wheels are off the track, wt transfer is at the max. Stand it up 45*, and it gets no better.
As for the HR bar comment... Not true. That device helps to more evenly plant the tires. Feel the need for "yanking them"?. Add a loose converter, no ft sway bar, a set of Moroso springs, and loose shocks... That should pretty well do it..[Assuming the engine is not a mutt.]
Chuck ![]() Injector inspector Madison, Ga. USA |
I always thought yanking 1 tire was also a partial direct result of the factory triangulated rear suspension set up.
![]() 1987 Regal LC2, hot-wired, Walbro 255 lph fuel pump, blue top injectors, Accufab adjustable fuel pressure regulator, Turbo Tweak chip, GN110T cam, TE-44 turbo, Alkycontrol, 3 inch mandrel bent Dynomax exhaust, Scanmaster, OD lockout detent plate, trunk braces, jounce braces, 145 mph speedo, RJC power plate and RJC boost controller Quote:
Audie1 1987 GN 2010 Shelby Cobra |
audie nice combo. what are you turning at the track?
![]() '87 grey T - sold '87 metallic light blue T - sold/traded '87 GN - alot - sold '87 White Limited - 11.14 @ 123.xx -------------------------------------------------------------------------------------- downsizing - a TR, 70 chevelle, 68 velle SS (for sale), 77 deville, '82 C20, '86 Sierra 2500, '03 Silvy 2500HD |
oops
Yanking 1 tire usually is the result of the chassis twisting, and the rt rear side of the axle being pulled up into the body by torque reaction on the r&p.[Look @ Nick Micales pic of his T-type!!]
A couple "cures": A well thot out roll bar/cage. Antiroll bar, such as HR. Correct shock settings. Audie: I think the loose shock deal could be: Cheapo shocks. Worn out shocks. Good shocks that are adjusted loose. justa 6.. Yep, the t/b would be another good idea, assuming the rest of the drivetrain would hold up!!
I use the HR adjustable uppers and tubular lowers, nothing exotic or complex about getting the factory 4-link set up to work.The pic below is just after I "added" about 300 HP with my TA alum motor. Big difference going from mid-10's to mid-9's. It now picks up the front end past the 60' mark with almost no air under the front tires, and can easily run 1.35 60' times. Video on my web site shows how it leaves now. Also, Chucks advise on chassis set up has been very valuable over the years on many cars we have done.
Nick Micale 3334 W. Marconi Ave Phoenix, AZ 85053 602-866-9908 Home of the world's fastest stock block Buick! www.arizonaGN.net arizonagn@q.com
They dont? Have you ever seen TSO or TSM cars launch? I doubt it. Yanking the tires doesnt do **** for acceleration once all the weight is the rear tires any further lifting of the front of the car is wasted power. Hard core heads up racers dont care how high they "yank" the tires. They care about going fast. If you look at the fastest passes the wheels usually just come up a little and the car shoots out like a bullet.
www.ottosperformance.com |
When you say low 11 mid 10 sec cars, do you mean turbo regals?
I wonder myself about the variation that turbo regals have in there suspension setups and chassis stiffness. I haven't seen a turbo regals in the low 11s pull a front tire. I have watch in person my friends 2001 TA pull a front left tire about 5" with 1.62 short time, 11.60 quater time. I know that he does have some suspension mods for tracktion sake. I doubt those low 11s second turbo regal cars have adjusted there Instant Center point.
Pullin' like a freight train, Flyin' like an airplane, Been drinkin' gasoline, And honey you can make my motor hum... |
good question. i was gonna point that out but was in a rush to post. mainly i'm talking about chevelles. i know they have a different weight transfer and all....my buddy has a 71 grand prix that was running 11.7 - 11.80s and he yanked his left front tire. and a mid to low 10 second 70 chevelle i saw yanked them like 2 feet in the air. and i know a magna member with an '87 gn that went 11.19 and his front left tire is off the ground, not sure about the right. here's a gn from the tb home page. it says 10.6 and it looks like he's got them yanked.
Thanks...........actually I don't know what she will run after I put the CPT-66BB,SMC Alky, and a Cotton's fmic on, (just ordered them). They closed down Cooper River Drag Strip, which was close to me. There is one other 1/8 mile strip (Dorchester) (it is pretty getto, I would not want to put a hurting on some crack head)....
....so I don't go there. The last and only time out with this GN I made one pass, blew the tires away and ran a 7.6 at 99mph in the 1/8th at 20 psi with a TE45A, some good gas, and a little Kenne Bell fmic . I have done some work on her to help with the traction........ With 25 psi and a decent launch and the new mods, I'm hoping to run maybe a 6.8 in the 1/8th mile, that is my goal anyways. Guess I'll have to go to the "Crack Strip" and find out what she will do.
Audie1 1987 GN 2010 Shelby Cobra Last edited by Audie1; January 4th, 2009 at 05:45 PM. |
The first one on the left is with an H&R sway bar and the second pic is with a stock sway bar...Claude.
1987 Buick llllllGrand Nationalllllll 10.51 e.t. @ 129.53 mph 2002 Ford Thunderbird 2008 Ford F-350 "King Ranch" Crew Cab Dually Pickup 2006 Ford Five Hundred SEL 2001 Saturn SL2 |
Without a t-brake it will be hard to hold the boost. You could get air realy easy with just slicks and a t-brake with a hard boost launch. Foot brake it will be hard. You will need a good converter to spool that 66 quick enough to get air.
Scott 89 TTA#299 STOCK 34,000 MILES * Vanna White * 89 TTA#1397 small turbo waiting on a tune 87 GN Black Plague 6768DBB Billet turbo / Stock Long block with the regular BOLT ON'S 10.97 with a $hitty 1.66 60ft no cage ![]() and acouple slow v8's http://i92.photobucket.com/albums/l6...Picture367.jpg http://i92.photobucket.com/albums/l6...Picture443.jpg ![]()
I was told that in this vid, my GN picked up the tires a few inches off the ground. I've got a little bit of suspension and a trans brake.
my car has the factory brakes and i can hold 20 lbs of boost at the line. i put the pedal to the floor and have a stock converter. i use the parking brake. who needs a tranny brake? lol
ok ..back home here. here is Melissa's 10.10 @ 132/133 with a 1.47 short time (I think) Foot braking it!! .. car just took off.. after the run she left the track and drove to Dunkin Donuts for her morning coffee
We are goin to work on her short time this year (I hope).. Still goin to keep reg street tires on the front.. but we are not goin to do a 2 foot wheelie's
Dan He who dies with the most toys, is still nonetheless dead ![]() 86/87 GN and 89 TTA .. tons of parts !! Stuff has to go !!! email ttastage2@yahoo.com |
What I've seen done to some "home brewed" (ie: lowbuck, redneck) racers is that they would install a short length of chain between the a-arms and an upper mounting point. It would basically limit the amount of travel for the wheel to drop. What would happen is that when the rear squatted enough the slack came out of the chain and it would "snatch" the front wheel off of the pavement theoretically giving more weight transfer and better bite to the rear. I've seen it on more than one car but like I said they were racers. I would be very hesitant to trying anything like that, especially on a streeter.
1944-The F4U-1 Corsair, known to the Japanese as "The Whistling Death" 2005-The WE4-T "Corsair231" still known to the Japanese as "The Whistling Death" 87 WE4T-Big mouth cai,TE-60,dutt neck cooler, Razor's alky, NOS (for show only ), hemco, 42.5's, FTS 208, Poston headers, 3" THDP, Hooker 2 1/2 , holley afpr and pump, hot wired, mild ported irons, ".030", forged speed pro. Still tuning.
The geometry of the rear suspension will ultimately dictate whether the car wants to pick up the front tires.
If you were to project the imaginary lines formed by the rear control arms forward into the car, the point where they intersect is called the Instant Center. The location of the IC changes with the location of the control arm attachment points and ride height. The "Neutral Line" is an imaginary line drawn from the rear tire contact point thru the Center of Gravity out toward the front of the car. IC's that fall above the Neutral line and near the CG will cause the front to lift. Knowing where the IC is located will help you tune the suspension for a "bigger hit" or "softer hit" and will control or cause wheelstands to happen.........but it is surely not the only factor involved with big wheelies. Take a look at the video below..........Huge wheelies. Right? I know exactly where the IC is located. A few small changes, (torque converter and tires) caused my car to do violent wheelstands. Another small change (front suspension travel limiters) calmed the car down with no other changes....and the car now is in the 1.28-1.30 sec 60' range. The car will leave with about 2 feet of air under both tires and great traction. If you really want to understand what is happening with your car and suspension, buy the Doorslammers book by Dave Morgan and his 4 link calculator software. If you can digest this information, you can then start effectively tuning on your suspension. Tuning your suspension without good information is a waste of time and money, IMO. Dave
1985 GN 9.68@139.....1.30 60' 270 Stage 2 |
Too much launch RPM/Boost, no limiters on front, and aggressive rear suspension.. Learned a lot that year..
Big Wheelie from Need2Speed's Dead Hookers II at B- Video
Jason White Thanks Hartline Performance, Don Cruz, DLS Engine, HRPartsNStuff, & Twisted 6 Racing convertors Pine Tree Posse member #0909 9.09 @ 149 and their is more left in it Can it go 8's with a hydraulic roller??
Here is some of mine.
87 GN with T-Tops. And a 87 GN T-Top car, 109 Block, Speed-pro Bank to Bank with 84 lb Delphi Injectors, Bowling Green Intake with a 70mm throttle body, DLS 218 Billet roller cam, GN-1 heads with T&D 1:65 rollers, J&E .030 pistons with ATR Rods, PTE70GTQ dbl ball bearing turbo ATR 3" dual Stainless exhaust with Pit bull muffs , Jack Cottons front mount with a CAS three pass radiator with a Ramchargers Dual fan, Fiberglass hood and MSD Distributor 7AL-2, ATR Stainless Headers and 3" down pipe with HKS external wastegate from header into downpipe. Ready to be tuned!!! New dyno results Street Stuff 10-18-08. 606 rwhp 580 torque. |
Another
The test pipe slipped off the down pipe.. Have V-band clamps now.
hey rodger
heres a wheel up pic for you on an 11.98 pass stock turbo, stock sway bars , footbraking on a D5 converter
paul - MAGNA NJ rep the 86GN bests 1.41 6.57 105 10.41 129.8 bone stock shortblock ,71GTQ, msbc-1, V2, ported irons ,tt6.0wb 75# ... now extremeauto th400 w/brake , vig converter, FAST, 83s =cracked #3 piston the 87GN , 11.31 ,120.9 TE44, duttneck, weber CNC raceport irons w 1.65 T+D, msbc-1, tial38, hi-pro,protorque, TT 55# through aerochambers big thanks to julio at alkycontrol.com eric at turbotweak.com A little fun with the GNs at Atco video |
Clint 87 Turbo Regal
| Bookmarks |
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/general-turbo-buick-tech/272707-question-about-yanking-tires-during-launch.html
| Torque - TurboBuicks.com | This thread | Refback | March 27th, 2009 01:09 AM | |
| Launch question | vader87 | General Turbo Buick Tech | 6 | May 30th, 2006 05:41 PM |
| Commander chip launch question? | fc227 | Computer Chips 101 | 5 | September 25th, 2005 07:54 AM |
| wheels, tires, and lowering question | SpoolinUpGN | General Turbo Buick Tech | 1 | January 19th, 2004 08:44 AM |
| Yet another launch question | JeffW | Drag Racing Techniques | 1 | April 21st, 2003 11:21 PM |
| Question on launch | Buick Beginner | Drag Racing Techniques | 7 | January 12th, 2003 02:14 PM |
