Old September 16th, 2008, 12:04 AM
meanchicken's Avatar
Will beg for quarters...
Outside Door Sill Weatherstripping
These are the weatherstips that squeegy the window as it goes up and down.
Who's a good source for them?
87 Grand National: Czarnota built V6 (208/208 cam); 3200 billet 10" lock-up stall; street/strip 200R4 courtesy of Lou and his guy; TT Alky chip with 60# inj; Hotwired Walbro; ScanMaster 2.1; Adj WG actuator; AFPR; 160* stat; RJC Power Plate; Alkycontrol; TRC Big Mouth cold air kit; Eastern Performance FMIC; Hooker cat back with test pipe; Direct Scan; and a boost gauge Otherwise bone stock.
www.turbolou.com
68 SS Camaro: ZZ502; TKO-600; Moser 12-bolt (3:73 TrueTrak); Global West tubular control arms, QA1 coil overs; SSBC power disks all around; quick ratio steering; Hotchkis sway bar; solid body mounts; Be Cool radiator; Pertronix ignition; other stuff; I don't have the timeslip to prove it yet...but...I bet you a dollar it does 11's.
Old September 16th, 2008, 12:35 AM
turbo6mike's Avatar
Trader Rating: (34)
Kirban and gbodyparts sells gm originals.
Mike Ruminski 1986 Grand National TA49,Precision intercooler,55lbs,Weber heads,stock TC,ATR SS Exhaust,Hot Wired XP Fuel Pump,Volt Booster,Best Time 11.52@118 w/1.65 60ft/New Combo 6152 Turbo,Janis Trans with Pro-Torque,Weber motor with 212/206 Billet Roller
Old September 16th, 2008, 06:01 AM
Bought mine from Kirbans awhile back.
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm. cross drilled slotted rotors, vacuum brake conv. Kirban GNX style rims,48k on car, 93 Turbo Tweak chip, 2.1 scanmaster,knock guage, 3" LT1 Maf w/translator, VDO guages,manual boost controller.
Old September 16th, 2008, 03:08 PM
Thanks!
Any trickery involved in swapping them?
Looks like the interior door panel has to come off...what about the window? Looks like some of the screws are still obstructed by the window when it's all the way down.
www.turbolou.com
Old September 16th, 2008, 03:31 PM
I didn't have to take the window out when replacing the dew sweeps, I did this last year, I started out by lowering the window all the way down, then I took off the upper door panel, loosened the side stops, then I took out the center bolt at the bottom of the window so it would drop down a little bit more. Next I pulled the window back and I used an angled phillips head screw driver to get screw out, and don't forget to spray the screws with some PB blaster.
Old September 16th, 2008, 05:52 PM
TType84's Avatar
cookin with propane
turbojd,
not sure if you're talking about the same thing i am
but if you remove the lower door panel, there is an adjustable window stopper that limits the travel of the power window. if you remove the bolt holding this in and let it fall into the door (dont worry, theres plenty of room to get your arm in to reattach it, then you can lower the window all the way down and dont need any type of angled screw driver.
it takes all of 5 minutes.
nick b. | turbosix.net
8.6@79 . 13.6@98 . 1.91 60ft - JC93 street chip & 17psi
currently:
hofer trans . pats 10" 3k stall . limit engineering stg 3 cheetah . curb weight : 3125lb
Old September 16th, 2008, 08:08 PM
TType84, Thats what I was talking about the window stop, and your rightI was using the angled phillips head screwdriver before I decided to take out the window stop and let the window drop down some more, then it was a piece of cake.
Old September 16th, 2008, 10:48 PM
Bad Buick's Avatar
GN owner
These dew sweeps are mighty expensive these days.I saw a set on EBay for $125!
1987 Cdn.Hardtop Grand National
2006 Impala SS (Wife's Ride)
2006 Chevy Colorado
Old September 17th, 2008, 05:55 AM
Yeah I paid $100.00 for my dew sweeps about 5 years ago from Kirbans, had them sitting in the garage for a few years until I needed them last year, the old ones were really cracked bad.
Old September 17th, 2008, 10:36 AM
My interior door panels are cherry originals. How exactly do they come off without damaging them?
www.turbolou.com
Old September 17th, 2008, 10:58 AM
I used a tool made for popping out the door panel clips, if some break while doing this you can get replacements at any auto parts store. It's not a big deal to pop the panels off without the tool I used, I've used a screwdriver too.
Old September 17th, 2008, 03:52 PM
Postons Buick also has them.
Use a phillips screwdriver that has a 90 degree bend in it and put a rag or tape on the window glass to keep from scratching it.
Follow directions already posted, take your time and you should not have any problems. Takes maybe 1 - 1.5 hours per side start to finish.
Just did mine about a month ago and all of the above mentioned tips really helped.
Door Sill improvement URSPANKED Show Car and Restoration/Body Repair 1 December 18th, 2005 04:43 PM
Outside Door Sill Weatherstripping p&d Show Car and Restoration/Body Repair 3 September 8th, 2005 09:44 PM
New Door Sill Weatherstrip 455 Regal Parts for sale 3 August 21st, 2005 11:13 PM
Door sill kickplate kshef Show Car and Restoration/Body Repair 1 July 7th, 2004 06:49 PM
door sill plates, still available??? Yedi Turbo Lounge 17 March 3rd, 2003 05:38 PM
