T-Top and Window Trim Plates
How do the center trim parts where the T-top glass locks into come off?
Looks like that must be removed before the metal trim can be removed from the rear area of the door glass and rear edge of the t-tops. Got the screws out but it feels glued in. Looking up at the T-top bar from inside, it looks like there is at least one screw near the rear of the center trim part but not sure how to get to it. Any ideas? TIA
1986 Grand National - Original Owner. 40 Over, Forged Pistons and Crank, 218/212 .498 Hydraulic Roller with 885 Lifters, Harland Sharp Roller Rockers, Fully Ported Stock Heads with 1.77 Intake Valves, Double Roller Timing Set, junk Silver Seal HV Front Cover, Port Matched Intake and EGR Tower Milled to the floor, EGR Blocked, PCV Blocked, Breather in each Valve Cover. Turbonetics 60-1 Hi-Fi, FMIC, 50 pph, 3" Down Pipe, Ported Stock Elbow, 3500 Stall, ALKY Control, TT Chip. No Times on new Set-up. Body under Construction. On Turbo Buick dot Com since 1998. Started Posting as Steve6332 Glad to Participate. |
Here are some PICS since I am not sure how good a job I did on describing the parts I am talking about. The center sheet metal trim and the beam on top of it, and the metal trim that it T's against on the roof.
OK 3 downsizing attempts (smaller and smaller) and now I think I got it - New camera takes bigger pics then the last one I used
trying to get high tech here
Thanks Turbonut
found them
| F/s T-top Metal Trim Plates | mario987 | Parts for sale | 1 | August 4th, 2008 05:03 AM |
| t top plates and chrome trim needed | regulz | Parts wanted | 2 | October 20th, 2007 09:19 AM |
| T-Top Metal trim plates & WO2 marker/turn light | 84c10 | Parts for sale | 2 | November 18th, 2006 11:50 AM |
| T-top Trim Plates & Weather Stripping | turbo_type87 | Parts wanted | 2 | February 14th, 2005 02:28 PM |
| How do i remove the window trim/moulding around windshield and rear window? | GS70350 | General Turbo Buick Tech | 4 | September 12th, 2002 10:10 PM |
