Old August 23rd, 2008, 09:11 PM
GRAY86T-TYPE's Avatar
Exhaust System
Looking for a new exhaust system. My two choices are the Cottons 3" Single shot, or the pypes 2.5" SS exhaust with Race Pro mufflers. Does anybody have sound clips.....becuase that would really make it easier to decide. Pics are also great. My exhaust is loud now, and I like it being loud. Just don't know too much about it. Want to replace it with something that flows good. Thanks for the advice
86 T-Type: TE44/ATR FMIC/50 lb Injectors/TRW .20/Billet Mains/Blueprinted Motor/204-214 Edlebrock Cam/Ported and Polished Heads with Matched Intake/3" THDP/TR Custom Parts Big Mouth and MAF Pipe/TT Chip/Translator 6.2 with 3" LT1 Impala SS MAF/Accufab FR/RJC PP/C2 Gauges/Scanmaster/Dynotech Trans/Pats 10" 3000 Stall Converter/3.42 Gears(now)/Taylor 409 Wires/UMI Upper and Lower Control Arms/Front and Rear Suspension....All NEW!
Old August 23rd, 2008, 09:53 PM
87Regal3.8SFI's Avatar
V6 on steroids
Single shot 3 inch here with Dynomax 17229 Ultraflow muffler:
YouTube - 87 Regal turbocharged idling p2
Also running a 3 inch THDP and a dump pipe, with it capped off.
I don't think you can do any better than this.
Here's all the parts I used to do the job....
Good luck finding the DP, the muffler came from Summit ($79), I purchased the pipes from Grumpy but I believe Kirbans sells this cat back straight shot exhaust.
Old August 23rd, 2008, 11:04 PM
meanchicken's Avatar
Will beg for quarters...
I'm pretty slap happy with my Hooker....
...uh....
Exhaust system that is....
87 Grand National: Czarnota built V6 (208/208 cam); 3200 billet 10" lock-up stall; street/strip 200R4 courtesy of Lou and his guy; TT Alky chip with 60# inj; Hotwired Walbro; ScanMaster 2.1; Adj WG actuator; AFPR; 160* stat; RJC Power Plate; Alkycontrol; TRC Big Mouth cold air kit; Eastern Performance FMIC; Hooker cat back with test pipe; Direct Scan; and a boost gauge Otherwise bone stock.
www.turbolou.com
68 SS Camaro: ZZ502; TKO-600; Moser 12-bolt (3:73 TrueTrak); Global West tubular control arms, QA1 coil overs; SSBC power disks all around; quick ratio steering; Hotchkis sway bar; solid body mounts; Be Cool radiator; Pertronix ignition; other stuff; I don't have the timeslip to prove it yet...but...I bet you a dollar it does 11's.
Old August 24th, 2008, 07:36 AM
Thanks.....87Regal3.8SFI......this helped alot
Old August 24th, 2008, 12:30 PM
Yeah dynomax is a good muffler,Im in the process of fabing me a 3.5 single shot with a dynomax bullet muffler.
Stock 109 block, GN1ported heads , RJC frontmount intercooler, PT-61 precision turbo, 4in cold-air kit with translator, trannie built by Brian Hofer, 275-60-15 BFG drag radials 3.5 inch downpipe 3.5 inch single shot dynomax bullet muffler
Old August 24th, 2008, 07:46 PM
The dynomax does sound good. Anybody have an opinion on pypes?
Old August 24th, 2008, 09:11 PM
Is the Dynomax quieter than the ATR singlehot with their Pitbull mufflers? Just trying to get a quiet 3" muffler for my singleshot!!
thanks.. dave
(87 GN - stock 20k
86 TType - accident prone
87 Limited - new toy-stock)
exhaust system Turbo Steve Parts wanted 0 June 9th, 2007 08:00 PM
Exhaust system SCD General Turbo Buick Tech 14 April 8th, 2007 12:58 PM
ATR 3'' exhaust system incharge Parts for sale 12 April 7th, 2007 08:39 PM
New exhaust system turbofabricator Turbo Lounge 11 August 24th, 2006 10:29 AM
Exhaust System 87bigcut General Turbo Buick Tech 3 May 30th, 2005 10:21 PM
