Old August 19th, 2008, 07:30 PM
What ALKY fuel to run?
What type of fuel do you run thru your alky injection kit? Is any better than others? VP has a few choices, M1 (straight) M3 with lube added and M5. I ordered Razors kit yesterday and he spent a good 10 minutes answering my questions and somehow i forgot the fuel question. I decided to ask you guys tonight casue he may be busy due to the weather or the new bride. Should i stay away from alky with lube? Has anyone had bad results using a specific brand? Thanks.
I hope the kit arrives by friday (weather premitting)
Old August 19th, 2008, 08:29 PM
PaCemkr86's Avatar
WFO Racing
pretty much any of those will work great. even denatured alky from Home Depot will work
Phil Underwood
My Turbo Buick
Old August 19th, 2008, 08:31 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
BTW the alky section has this in it but M3 with the lube was recommended by Razor.
Mike
87GN T-Top down 423lbs.
Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Billet Drum/Input, PI 3400 5disc, T Brake, Inland 3.5" DS, KB Plenum/70mm TB, Razor's Post Turbo Alky Kit, Devils Preturbo Alky Kit, TT Chip, 60lb Inj, Denso 280 Pump,-8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, ATR SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, QA1 Shocks, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs
Old August 19th, 2008, 11:16 PM
M1 (no lube)
Old August 20th, 2008, 06:46 AM
87Regal3.8SFI's Avatar
V6 on steroids
I run methanol when I can, if not that I take a trip over to Ace/Lowes and pick up a can of denatured alky.
Old August 20th, 2008, 09:18 AM
Straight Methyl Hydrate from any store like Home Depot.
87 LTD owned since May 88 No hood ornament from the factory!
Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49!
New combo is roller & 6776 Turbo. Track times coming!
Got in 1 pass at 11.30 & then blew up the tranny. It will do much better than that! High 10's here I come!
Old August 20th, 2008, 11:46 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
We cant get that stuff (Methyl Hydrate) here in the states at least not around here in the armpit
USAF POWER PRO
Bang Bang Buick
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe, Chrome thunderstar wheels. FOR SALE
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list both bikes still have warranty till 2010.FOR SALE
Old August 20th, 2008, 01:12 PM
gossamer's Avatar
FWIW, I'm using the VP M-1. So far, no problems.
1987 GN Astroroof
Precision 6131BB, BGC 23 row stretch IC, 60lb inj., 212/212 Comp roller cam, T&D rollers, TT Akly chip, Razor's Alky kit, Billet main caps, Speed-Pro forged pistons, port & polished heads & intake, 70mm T/B, Edge 10" 3000 stall L/U, trans built by mikestertwo with PTS parts, 3" THDP, Poston headers, PTS aluminum radiator, etc., etc.
Old August 20th, 2008, 05:58 PM
ChevMCarlo84's Avatar
+1
'86 GN: Up next: Paint.
CPT-65, 55# inj w/ TT chip, Alkycontrol, Powerplate, Hybrid Boost Controller, 3200 stall, Shift kit, Hotwired 340, 3" THDP -> 2.5" ATR SS, Line lock.
Old August 20th, 2008, 08:55 PM
daily driver's Avatar
I get Methanol from Smiley's racing on the Mannsfield-Kennedale BUSINESS Highway. About 3 miles down on the left south of I-20. I think it was 4.25 / gal last time. Since you are in Aledo that is not too far from you. just bring your new fuel container and get a bottle of the redline "fuel lube" to mix in it. He sells that there too. Unless your new pump and kit can take the straight methanol and you do not need it?
86 GN, Big Mouth CAI w/ K&N, 3" GMSS MAF+Translator, TA49 @ 22psi, CAS V4, Hotwired WB340, MSD 50# inj., Accufab adj fpr, stock engine now at 137K, only timing chain and vlv springs replaced, TH 3" DP, hi-flow cat, 2.5" SS Duals, TT alky chip, SMC progr. on meth, Lonnie Diers built 2004R w/ 3000 LU conv = 8.11 @ 86 mph in 1/8th, 0 boost launch/90 degree day.
Old August 21st, 2008, 12:46 AM
Dailydriver- Thanks!! I actually stopped by the race track at kennedale today about 4 pm. Of course i did not know i was going to be in the neighborhood and did not have a jug with me. It was priced at 4.50 a gallon for VP M1. I would rather find the VP M3 but no big deal. Maybe i can find some banana flavored lube to mix in the M1. Thanks for the heads up on Smiley's and i will call them thrusday.
More fuel or more alky? Mike70gtx Alcohol, Nitrous and Propane Tech 17 November 23rd, 2007 06:50 PM
more fuel or alky? blackmonte Alcohol, Nitrous and Propane Tech 8 November 16th, 2007 12:53 PM
add fuel or alky CanGN General Turbo Buick Tech 2 June 16th, 2007 01:07 PM
more alky? or add fuel? SIXBANGR Alcohol, Nitrous and Propane Tech 2 July 22nd, 2006 06:32 PM
More fuel or alky? northern87gn Alcohol, Nitrous and Propane Tech 17 October 11th, 2005 05:50 PM
