Ok so these are some pictures of my new injectors that have 1000 miles on them. As you can see they are covered in a black tar like goo! Very Very sticky!
Inside the fuel rail is clean. Inside the intake just has oil on it. No black tar goo. But Where the oil, air and the E85 start mixing at the injector tip. ( Its running on 100% E85 ) The black tar goo starts and goes on into the intake runner in the head. Im taking it that valvoline and E85 do not mix well. Yes the bottle of oil says its for gasoline engines. Also has a zddp bottle in with it. Is there a E85 safe oil? Has anyone seen this before? Any ideas of something else it could be please post it! The only other thing that I can think of is the egr is stuck open and the exhaust gas is going back into the engine all the time. But I figured if this was the case the black goo would be in the whole intake. The egr is always off, its programed that way in my turbotweak chip. Thanks
1987 WE4, "109" .040 over block, stock heads, bee hive valve springs, stock intake, Dutt Neck stock Intercooler, gt 61-63 precision turbo, 3 1/2" ls1 mass air, translator 6.25v, 3.5" THDP, 2 1/2 inch kirban crossover pipe, 2 1/2 inch pipes exhaust, 62mm TB, rjc powerplate, rjc boost controller, PTS Xtreme radiator, 3000 9/11 stall, built trans, 206/206 roller comp cam, turbotweak E85 chip, xp double pumper/hotwired, 79lb injectors, volt booster, scanmaster/turbolink, QA1 shocks front/rear, 36mm front swaybar, moog 5658 front springs/moog 5413 rear springs. Moser Axles, 3.42 gear, H@R parts rear swaybar, upper and lowers, motor mounts and trans mount. Best 60 ft 1.62, best ET 1/8 mile 7.69/89mph ( 21 psi, 23/21 deg timing) Running on 100% E85. 1987 Turbo T Limited Black WO2 Car |
1000 miles are on the injectors. The O rings are in great shape and look like new.
Seems like the O rings may be breaking down?
86GN "Sinfull" Corner Carving Stage 2. You want some?? No? I didnt think so!!!! 87 Limited - 57K blackout, moonroof, CSII stock show car in the making!!! 85 Regal daily driver until winter, then twin turbo V8 time, budget build GN clone. |
O Rings are like new. It would take a whole O ring to make the amount of sticky black tar thats in one intake runner.
I really think its the air/oil and E85 mixed with the heat of the engine thats making this stuff. I belive what ever is in that oil is not reacting well with E85.
Why would the oil have any thing to do with the problem? Alcohol and gasoline arent the best mixing fuels believe it or not. Looks like something that was in the fuel and may have deposited on there as the E85 probably vaporizes as it exits the injectors. Id suspect the fuel more than anything. I doubt its actually E85 anyway. Could be less according to their profiles. There is actually a range. 85% is the max amount of ethanol. Their not required to tell you how much ethanol is actually in the fuel. You never know what your going to get. EGR is inert gas and wont do much but waste volume and heat the intake charge if stuck open. Ive never seen a set of injectors look like that at 1000 miles. Its worth getting a flow test done to see if theres a problem inside the injector. Looks like it will have an effect on spray pattern. I wouldnt try to clean them till their flowed. Id do a leak down test too. Maybe your leaking compression past the valves.
Blue GN: Old combo 559whp/706wtq. New buildup to come with race ported GN 1 heads and intake . Black GN:Stock 147k shortblock except cam ,KB 70 mm TB and plenum, ported irons 1.77in 1.5ex, RJC head gaskets, ported stock intake, 212-212 comp roller, 1.65 T&D's, RJC powerplate, 1" plenum spacer, 83 lb/hr injectors, double pumper, FAST XFI, G-Body FMIC, welded ported stock manifolds, 3.5 dp, CPT 66BB GTQ, PAC dual nozzle alky injection, Dusty PTC 9.5", 200 4-R by me with billet shafted forward drum, billet input, billet ring gear and planet. 8.5 rear with Auburn, 28 spline Moser axles, and LPW girdle. 10.29@133.46mph .Time with old combo (stock ecm, p-trim turbo, and loose converter) 10.88@126mph. Stage II coming soon .
The reason I think its the oil is because there seems to be a lot of oil in the intake and the fuel rail inside before the injectors is clean as can be. No black tar in there. Oil is the only other thing in the intake besides air that would be mixing with the E85. The injectors that I was running in the car before on gas have 25,000 miles on them and they are clean as can be. I have been running the same oil in the car with both gas and E85. Switched the car over to E85 and the black tar appeared.
Could very well be fuel and im in no way saying that it is not. As thats the only thing I changed and it makes sence.
Im just wondering if it is fuel. Why the fuel rail, top of the injectors, fuel filter and lines don't have this black tar in them. Any ideas on that? Any chance its carbon buildup turning into this. I don't understand how carbon would make its way to the end of a new injector though. So the fuel makes more sence.
Plastic injector tips are not breaking down, but yes it looks like it in the pics.
I have noticed that it is using oil but I don't know if its burning it or leaking it out somewhere. Seems to always be leaking somewhere.
I see this on injs I clean/flow test. I think Spoolin is on the money..Loose int guides, or bad seals. The alky fuel has nothing to do w/ it.
**87 Buick GN** 109 block steel crank/mains Ported Irons roller cam/rockers Ported intake/acufab plenum PT front mount 70GTQBB 83lb injectors Razor alky Maf T Pro Fuel, spark and boost management LC-1 Wideband Tracking |
Exhaust reversion into the intake.
Lonnie Diers Cincinnati, OH Extreme Automatics 937-379-2233 9 sec 2004Rs New V-1 Intercoolers 87 GN Push Model |
