Timing Advance, Extender/Trans + , and WOT/PE Questions...
Got a question on timing advance….
I have an extender chip with a Trans +, programmed for 98 octane (23 wot timing in low gears/21 high gears). I set the base timing switch on the trans + to E (I think its E) which retards timing 4 degrees…so I should end up with 19/17 timing. First question: the timing advance p’logger shows should correspond to the timing in the chip right? If the chip is set at 17 timing WOT in Third, p’logger should read 17 right? Question #2: Does the extender chip, gather its information on what gear you are in by the shift linkage /switch on the steering column? or by another means? Question #3: If you are in Power Enrichment, you are in WOT? or the ECM at least sees it as WOT? Thanks, Nate
Current projects: 1982 Cutlass -355 chevy 1985 GN-hot air 1985 WH1 w/astro roof 1963 studebaker avanti |
I spoke with Mike, here are the answers for any future folks with the same questions...
Answer #1: Any timing adjustments made by the trans+ occurs after the ECM, so you will not see the "actual" timing adjustments on your p'logger or scan tool Answer #2: If i understood correctly, The steering column picks up park/neutral, and the pressure switches in the tranny tell the ECM 1,2,3 or 4. 3rd and 4th gear boxes will both be checked when in 4th in p'logger Answer #3: Power Enrichment = WOT. Nate
Which is why it's SO IMPORTANT to always know where those two switches are!!!!!!!! Don't ask why this is important :-( But yes, that's the neat part, one chip can be race or street just by manipulating those two knobs (timing base, timing wot) Quote:
As far as the Translator is concerned (I assume that's what you're asking about), it assumes WOT at anything over 3200 rpm (maybe 3400, I can't remember).
TurboDave EWCS(SW) USN (Ret.) My Photo Gallery Email Us Sevierville, TN TranslatorPro MAFless fuel, spark and boost management 86 GN(TranslatorPro/ExtenderPro on speed density w/boost & fuel pump control,PLX-WB) (original owner) 87 GN (second owner) 84 L69 Z28 (original owner) 01 Excursion LTD 7.3L PSD(Power Stroke Diesel), Turbo, 4X2 08 Honda Accord EX-L, 270HP 3.5V6, AT |
as always... Thanks Dave! I am slowly getting the kinks worked out of this...chasing a backfire at around 4G's right now...
Nate
| Spark advance in Extender Extreme? | Not Avg 6 | Computer Chips 101 | 8 | September 5th, 2004 08:55 PM |
| CAM TIMING Advance or Retard????? | turboN4thGen | Hot Air (non-intercooled) Tech | 1 | November 27th, 2003 03:02 PM |
| Timing advance | FromaBuick6 | Computer Chips 101 | 5 | June 9th, 2003 04:20 AM |
| Those w/ trans +, extender chip & alchy: tuning questions | The Darkside | General Turbo Buick Tech | 1 | December 31st, 2002 07:04 PM |
| Advance,Straight up or de-advance timing | Whitettype86 | General Turbo Buick Tech | 4 | November 23rd, 2002 10:48 AM |
