Old July 23rd, 2008, 11:50 AM
Removing Old Paint from an Intercooler
I want to remove the old paint from my original intercooler and repaint it. How do you guys remove the old paint? Any tips would be appreciated.
I'm going to paint it with Eastwoods - radiator satin black.
Thanks, Craig
Old July 23rd, 2008, 12:27 PM
you could use paint stripper
Tony
Victory Trans
87 Regal, BBC w/ blow thru turbo setup on the way!!
Old July 23rd, 2008, 01:45 PM
I would probably have it hot tanked at a radiator shop. That would also clean it internally.
Old July 23rd, 2008, 10:42 PM
A hot tank is a REALLY bad idea. The factory intercooler is sealed with epoxy internally, and a hot tank will eat the epoxy away, causing leaks.
I use two cans of spray "gasket remover". (available at any autoparts store) Coat the intercooler (I/C) with one can of gasket remover and let it sit for about 20 minutes. Spray it off with high pressure water and repeat the process. It takes some final cleaning with a pair of tweezers to get all the paint flakes out of the fins. THen give it a light coat of Eastwood radiator paint or just plain flat black paint. A light coat will not act like a heat blanket.
It'll take a few cans of brake clean to clean all the oil residue out of the inside of the core, too.
Ken B.
Old July 24th, 2008, 11:35 AM
Yes - getting it dipped at a radiator shop isn't the thing to do. Thanks for the ideas. Craig
Old July 24th, 2008, 12:22 PM
Sorry for the bad advice. I did not know about the epoxy. Thanks for correcting me.
Does this also apply to aftermarket IC's, including a V4? I have used gasoline and paint thinner (wash grade) to clean the inside. Is this a problem?
Thanks
Old July 26th, 2008, 09:41 AM
High Tech Redneck
Soda blaster or 80 grit glass beads. I did mine earlier in the year with soda and then used underhood black Powder coat.
Alan Minga
Lacey's Spring,AL
Old July 26th, 2008, 01:32 PM
Thanks
On the inside brake clean, carb clean, gas, varsol are fine if you just slosh around for a bit then empty it out. Do it a couple times & then I rinse with water. Then I hook up a big shop vac to one end with some cheese cloth on the other end & let it go for a hour! I turn it upside down while doing it. Some blow air thru as well but the shop vac can shoot dust & crap sometimes so be careful. Then a good air dry for a day or two & ready to go!
You can also fill with water, let sit for an hour & see if there are any leaks at the same time.
87 LTD owned since May 88 No hood ornament from the factory!
Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49!
New combo is roller & 6776 Turbo. Track times coming!
Got in 1 pass at 11.30 & then blew up the tranny. It will do much better than that! High 10's here I come!
Old July 30th, 2008, 07:05 PM
Excellent detailed procedure. Thank you for taking the time to explain.
Old July 31st, 2008, 04:05 PM
NVRL8's Avatar
Huge Member
I have done a couple with glass bead. I did not blast the fins though. Just covered them (you can't see them when the intercooler is on the car anyway). I also used the Eastwood radiator paint. Used Satin. Matched very well.
'87 GN, 6157BB, TT WB Chip, Razor's Alky, CAS V4, Moto 60's, Tomka CAI, RJC PP and controller, 3" DP, Hooker Exhaust, Jimmy's Trans, HR Bar and Arms, 11.98@110
Removing water spots in paint 87 GN TRFanatic Show Car and Restoration/Body Repair 2 July 28th, 2006 10:54 AM
lacquer paint. what wax is best for removing oxidation? ulose2av6 General Turbo Buick Tech 5 May 16th, 2006 04:23 AM
Able to strip paint without removing original black primer Brad Zeidler Show Car and Restoration/Body Repair 0 February 21st, 2005 10:52 PM
Removing grille, bumper trim and mirrors for paint 87gninpa Show Car and Restoration/Body Repair 7 June 3rd, 2004 06:46 AM
Advise on removing something on paint Steves87 Show Car and Restoration/Body Repair 5 May 31st, 2004 08:45 AM
