Old July 21st, 2008, 07:42 AM
bobbyw
Knock Sensor Location
Hi Fellas,
I've been riding around in a 87 GN over the past year, and haven't had any time to study up on it due to it's reliablity so far and my consant maintainance of my other 1980's wrecks.
Sunday the GN stranded the old lady I figured it ran outta gas, however that wasn't the case and I barely managed to coax the car home the few miles.
It's pulling a code 43, however I could not manage to locate the Knock sensor on this car. Where the hell is it? Also, I see the big box car part joints do not stock it. Rockauto has it online, however is there anything I need to know about buying a replacement sensor?
Thanks,
Bob
Old July 21st, 2008, 08:22 AM
The knock sensor is located at the back of the block under the coil pack but that's most likely not your problem.
1987 GN, 1986 T, 1984 Hurst Oldsmobile with 1987 GN drivetrain
Old July 21st, 2008, 09:08 AM
chrisgarrett's Avatar
Registered Member
Code 43 addresses the ESC which is located on the ps fender next to the map sensor. Check it for a faulty connection. I agree that it is most likely not the knock sensor and ESC modules rarely fail. So check the connections and check the ecm-ign fuse.
2008 build, Comp roller cam, Cat stroker, RJC gridle, CPT66BB, PTE Stock Location IC, Champion iron, T&D roller rockers, 60# Mototron injectors w/Turbotweak chip, Monroe-ported throttlebody, RJC Power Plate, Jimmy-built trans w/Precision Vigilante converter, ATR SS dual exhaust, ATR rear sway, BMI upper and lower control arms, Edelbrock Performance shocks, Razor alky, Tinman cold air intake, MT street radials.
Oh, and Russ Merritt spark plug wires.
Old July 21st, 2008, 09:12 AM
Registered Member
Here's a pic.
Old July 21st, 2008, 09:17 AM
HMBTurboT's Avatar
Try Kirbans or ***********. May want to also read: Tuning
Mike
1987 Turbo-T - Original Owner - Stock but being upgraded.
Old July 21st, 2008, 10:09 AM
bobbyw
thanks for details and pic Chris! I think I have a extra ESC from a 3.8 Bonnieville laying in the spares box. I'll get out in the heat after work with a few brews to check the wires and do a parts swap!
egt sensor location? TA49-WE4 General Turbo Buick Tech 4 April 6th, 2008 02:26 PM
Knock Sensor Location? PsYcHo GN General Turbo Buick Tech 17 October 5th, 2007 04:40 PM
knock sensor location xxninja General Turbo Buick Tech 1 October 9th, 2003 10:55 PM
Location of Knock sensor? Roc87 General Turbo Buick Tech 1 May 31st, 2002 09:22 AM
Knock Sensor Location Buicksandrail Before Black (non-SFI) Tech 2 September 30th, 2001 10:18 AM
