Old July 20th, 2008, 02:55 PM
Misses @2000 and no load, fine under load??
A new problem has arose, and I am started to do some trouble shooting... These symptons are new, and I haven't changed anything (although i have just started putting miles on the car, since i got it all together)....
The car know backfires through exhaust after a WOT pass in 3rd... no knock... The car is very hard to keep running on a cold start up...backfires, thorugh exhaust/stalls. It takes several times to get it started... Once the car warms up, starting is not an issue and idles fine with no indication of an issue. If i keep the car in park, bring the rpms up to 2100 or so the car will miss and stumble. If i put the car in drive, stand on the brake, and bring the rpms up to the 2100 rpm or higher, no miss or anything...
I would have thought putting a load on the car would make the problem worse...
So i am going to start checking a few things out, wasn't sure if anyone had any pointers... (i already swapped out the coil pack/mod...same symptons...
Thanks,
Nate
Current projects:
1982 Cutlass -355 chevy
1985 GN-hot air
1985 WH1 w/astro roof
1963 studebaker avanti
Old July 21st, 2008, 10:16 AM
Anyone have any ideas? I am going to try to get it out on the road tonight to see what it does while driving it normal and WOT.
Thanks,
Nate
Current projects:
1985 GN-hot air
Old July 21st, 2008, 10:58 AM
TurboBuRick's Avatar
I just make it look easy
Trader Rating: (10)
I would suspect crank sensor
Take a look and see if it's loose or been hit. Check the balancer. Make sure it's tight.
Make sure your pulley bolts are not too long. I have seen where they have pushed the timing ring and caused issues.
I suggest these things considering coil pack, module, plugs and wires have all been ruled out.
Good luck!
Rick
**87 Buick GN**
109 block steel crank/mains
Ported Irons roller cam/rockers
Ported intake/acufab plenum PT front mount
70GTQBB 83lb injectors Razor alky
Maf T Pro Fuel, spark and boost management LC-1 Wideband Tracking
Old July 21st, 2008, 11:04 AM
Thanks for the reply... I put a "better looking" interrupter ring on the cam sensor, the orignal didn't look as "nice"..a little corroded. I did that a week or two ago... I didn't adjust the cam sensor, only the new ring. But since i had my hand in there, i'll look again and inspect...
The weird thing is that the miss/stumble seems to go away under load and starting is not an issue when everything is warmed up...
I haven't pulled the plugs yet, but if it was a fouled plug or wire, I would expect it to be worse under load...
Thanks...
Nate
Current projects:
1985 GN-hot air
Old July 21st, 2008, 12:29 PM
Trader Rating: (10)
Thanks...
Nate
I was talking crank sensor..
**87 Buick GN**
Old July 21st, 2008, 12:39 PM
my bad...i was going to check out the crank sensor too...I used the credit card trick to adjust that the other week as well...so i had my hands in there too, so it won't hurt to double check that either...
Thanks!
Nate
Current projects:
1985 GN-hot air
Old July 21st, 2008, 08:10 PM
Found the problem!! the interrupter ring in the cam sensor was loose, the screw evidently wasn't as tight as i thought or it worked itself loose...
Thanks for the sounding board and troubleshooting ideas...
Nate
Current projects:
1985 GN-hot air
Stumble and misses under load TURBO 6 General Turbo Buick Tech 2 November 10th, 2007 03:07 PM
Locking up only under a load? VadersV6 General Turbo Buick Tech 8 September 21st, 2005 02:57 PM
rpm/load specific tap? next_level General Turbo Buick Tech 5 March 2nd, 2005 09:02 PM
shutting down under load ROBERT HAYDEN General Turbo Buick Tech 14 January 11th, 2005 07:57 PM
Breaking Up Under Load!!!! boostmaster General Turbo Buick Tech 4 October 29th, 2003 09:07 AM
