Old July 20th, 2008, 02:32 PM
Jerryl's Avatar
Don't show your smell!
AC compressor or just clutch?
Well, was on the highway cruising, 60 mph with the 1984.
Suddenly, I smell smoke, like en electrical fire. (****)
I pull over and there is smoke pouring from the AC compressor clutch.
Unhooked the power, Started the car ...... Head spins freely, belt does not "squeak" ........ Closed the hood and kept going.
70 Miles later, no issues, except "No Ac" in this 97F weather!
Lots of questions;
Not sure If the unit is still ok and maybe can just replace the clutch(??)
If not, .............
What is the best place to purchase a good AC compressor? PN appears obsolete at GM. (??)
Looked for "Savanah Air", but could not locate them.
Chips By Turbo Tweak -"Simple And VERY Effective"
Sometimes what counts is "That which you DON'T do"
Nobody likes the "Smell of @$$", so don't show yours here.
My Best Buddy has a giveway - FREE!! - Click here
84 Pics here; It's only slow because it's stock and missing 2 cylinders!
In GOD we trust, all others must provide data.YES, Already replaced that too, TWICE! .
Read on the future of "World Peace"
Old July 20th, 2008, 03:41 PM
87Regal3.8SFI's Avatar
V6 on steroids
Also wondering, as I may have to end up replacing my compressor too....or go a/c delete.
Old July 20th, 2008, 03:50 PM
zues1's Avatar
member
a/c clutch
more than likley when clutch smokes (gets hot)it gets front seal in compressor i think i can get a compressor kit (delphi comp factory spec new)with drier orrfice tube orings flush oil everything needed for about 350.00 if you would like i will check tommorow let me know mike
1986 Grand National- 6131 turbo,60lb inj,rjc plate,rjc boost control,alky inj,power log,gen2,baileychipextender extreme,patsconv 2800
1987 Grand National- Caged, A/C delete 61 turbo front mnt pres cooler port hds tt chip trans ls1mas 3" rjc plate accu fuel reg thdp rjc under drive 60 inj.westcoastconv
1984 T-Type (Rosewood)87 drivetrain
1987 Grand National- All original, bringing it back to life project.
1987 Grand National- Primered, 25,000mi car.
Old July 20th, 2008, 08:00 PM
Jerryl's Avatar
Yeah, probably right about the seal.
What do you think of these units?
1984*Buick*Regal*A/C Compressor from DiscountAcParts
Old July 21st, 2008, 01:46 PM
Get a new compressor. If it got that hot than most likely the shaft seal needs to be replaced. Add in the cost of clutch,bearing and shaft seal replacement and you're money ahead by replacing the compressor.
Eric Fisher
OEM Parts Specialist for GM Vehicles e-mail me at efisher@billheard.com
1997 SCCA Regional Champion. 1986 Grand National #38 ESP
86 Grand National
84 Riviera T-Type
82 Regal engineless
Old July 21st, 2008, 04:09 PM
Jerryl's Avatar
Agree, UR still DA MAN!.
Called the local dealer
PN 88964871 - $408.66
GMPartsdirect $212.50 + handling charges
Old July 21st, 2008, 06:00 PM
zues1's Avatar
member
all the compressors i seen on there are reman i would stay away from reman i put 4 on a car one time before i got a good compressor lost my *ss on labor only use new now my 2 cents
A/C Compressor Clutch salvageV6 General Turbo Buick Tech 3 April 10th, 2008 10:23 PM
How to lock up the AC compressor clutch with car not running? TR Custom Parts General Turbo Buick Tech 5 June 18th, 2006 01:48 PM
A/C not working...compressor clutch not kicking in MSDGN General Turbo Buick Tech 8 April 19th, 2006 03:14 PM
Possible A/C Compressor/Clutch Problems rb68rr General Turbo Buick Tech 1 June 5th, 2003 11:42 PM
AC compressor clutch rattle GNandTTA Turbo Trans Am Tech 2 August 7th, 2001 09:40 PM
