Old July 20th, 2008, 03:02 AM
87Regal3.8SFI's Avatar
V6 on steroids
What size bolt?
I noticed on the rear of my stock intake, there is a place where a bolt goes to hold down the big wire loom that goes across the fire wall. Does anyone know what size bolt it takes?
Thanks!
Old July 20th, 2008, 09:12 AM
Mine is the same size as the turbo shield bolts: M8 x1.25 and they are about 3/4 inch in length or less. Try one and see...Jimmy.
`87 GN T-tops, TE-44, Bluetops, Dutt neck stock IC, 3" DP w/electric cutout, Hooker exhaust, 206 Comp cam, GSS340M/Racetronix wiring, AFPR, Underdrive pulley, Powerplate, TTA wires, HR motor mount, Transgo shift kit, Trans cooler, Drag shocks, Boxed lowers w/poly, F&R body braces/front swaybar delete, Air bags w/spacers, `Glass bumpers, OfficeMax IC scoop, Autometer/VDO gauges, 145 speedo, LT-4 starter, Prostars, MT DR's, Sunoco 94, TurboTweak/Alkycontrol SAC/methanol
topjimmy@bex.net
Old July 20th, 2008, 11:04 AM
V6 on steroids
Yeah if I can ever manage to even get a bolt down there. It's one of the hardest things I've tried.
Old July 20th, 2008, 11:45 AM
Still plays with cars!
just wait........
if you think thats difficult.......
when you get married, and want some lovin, ha ha ha ha
just a bunch of cars..
Old July 20th, 2008, 11:56 AM
Believe me, after 2 marriages, the bolt will be MUCH easier!
topjimmy@bex.net
Old July 20th, 2008, 12:09 PM
Remove bolt on coil/mod bracket same size as wire loom bolt.
Old July 20th, 2008, 12:40 PM
Next time the motor is out stick a stud in there. So much easier to pop on the loom & throw on a nut!
87 LTD owned since May 88 No hood ornament from the factory!
Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49!
New combo is roller & 6776 Turbo. Track times coming!
Got in 1 pass at 11.30 & then blew up the tranny. It will do much better than that! High 10's here I come!
Old July 20th, 2008, 12:48 PM
V6 on steroids
Already am married.
Yeah I am thinking I'm going to have to remove the coil pack to get in there.
I see it's held on with one bracket, what else needs to come out?
Old July 20th, 2008, 10:51 PM
That loom boss is the best place to route the ground wires. I use that boss to mount all the ground wires to. I also do not install the loom on it, either. It makes removing the drivers side valve cover easier, too.
The correct factory original bolt is a 8mm X 1.25 by 3/4" and it has a 10mm head size. (typical 8mm bolts have a 13mm head size)
Ken B.
Old July 21st, 2008, 05:19 AM
Love those LC2/ Y56 cars!
This site will help you identify those missing bolts.
Click here: http://perfauto.tripod.com/indexpage.pdf
Evans Ward
Macon, GA
87 Buick Turbo-T, LC2/Y56 Regal, TA49, RJC AD PP, Bluetops, bstC boost commander, SMC Alcohol Injection, Neal's Racing Trans, Pro-Torque 2800 D5 converter, TT Alky chip, hotwired Walbro 340 FP, Mease 3" DP, Eaton posi, Dutt big neck stock IC, 2 3/4 cat back duals w/test pipe, air bags, cold air kit w/K+N, all braces, white w/factory heavy padded dark blue landau vinyl top, T-Top, cornering lights, chrome package, polished T wheels, Scanmaster 2.1
1970 Buick GS455: matching #'s car, Poston GS112A cam, 1786 heads w/Stage 1 valves, John Osborne prepped Q-Jet, MSD 6A, VP 400 (switch pitch) transmission w/PAE 3000 stall convertor, harvest gold ext w/gold vinyl top.
Old July 21st, 2008, 05:50 AM
V6 on steroids
Thanx got it fixed.
Old July 21st, 2008, 05:55 PM
Thanks for the link Evans, I couldn't find it
topjimmy@bex.net
bolt size stock87 General Turbo Buick Tech 1 June 5th, 2007 11:10 AM
200-4R Bolt Size bccan Transmission Talk 1 April 24th, 2007 08:14 AM
Fuel rail thread size? Ground bolt size? NothinYet General Turbo Buick Tech 2 April 2nd, 2007 11:51 AM
Bolt Size??? Woody General Turbo Buick Tech 5 February 8th, 2006 02:00 PM
What size T-Bolt Hose clamps for a stock size up pipe?? Chrisk General Turbo Buick Tech 4 August 25th, 2005 03:13 PM
