please help!! my car is cutting off in the middle of traffic!!
has anyone had the same problems im haveing? tonight i drove my car into town, about a 40 min drive by interstate. the gn drove and ran out fine on the interstate. but once into town and into bumper to bumper traffic, red light stop and go, i noticed the car wasnt pulling its normal amount of vaccum it usually did, which is 16 in. hg. it was around 11 to 13 in. then the car started idling rough and it choked down, i couldnt get it started back so i then procceded to coast into a parking lot and let the car sit for about 40 min. i then tryed starting the car and it started right up and ran for about 4 more miles then it was the same thing all over again. as soon as i could get it to start again i tryed driveing it home. once i made it on the interstate after it cut off again i finally started back home. on the interstate it would cruse just fine. i could keep a constant 70 easy. once home i tryed flooring it and the car felt much weeker although it read 0 knock. please help me i have no clue where to start. thanks for any advise!!
1987 gn: 77,000 org. miles, hot wired walbro 255, fmic front mount, cut out cat, k&n, auto meter piller gauges, scanmaster 2.1, taylor 10.4 mm race wires, Alky control and TT alky chip but cant find meth anywhere !!!1963 ford unicab: lowered 6in., BB429, lunati cam, cj intake, holley carb, headers, 4 speed. 1997 dodge 2500 4x4: cummins 12 valve, 2in. leveling kit, 35in. nitto terra grapplers, k&n. 1993 lexus gs300: 300000 miles and still runnin strong |
You need to start by giving us some readings. Sounds like the idle air control valve is stuck since it only happens at idle. But What is the tps reading? Go down your scanner and write down what you see and post it up.
PT-67 (.63A/R, P-trim) 10" WestCoast converter 3800 rpm stall, Eastern FM, 3.5" Maf, Translator plus, 3" THDP, Hooker Cat back, 3" Cat, Mototron 60/65 lb/hr injectors, comp cam 206/206, Adj fuel reg, Extender Extreme chip, SMC Alky, Holley 255 LPH fuel pump hot wired, KN air filter, RJC power plate, Air bags, UMI Lower control arms, Metco driveshaft loop, Eaton Posi, Poston's crossover pipe, Dual 11" Spal fans, Arizon GN Radiator, Powerlogger and Scanmaster II |
possibly an EGR valve that is sticking in the open position.
bw jones
GNis4GoodNews 1978 AMC Pacer Wagon w/woodgrain siding 1979 Mercury Zephyr 4-Door Sedan 1974 AMC Matador X Coupe 1985 Yugo GV - low miles (won't run) 1965 AMC Rambler Marlin 1983 Renault LeCar JUST KIDDING!
these are my readings after driving it around the block. i got on it twice in third. it had knock both times. so i let out both times. first it was at 3.3 retard degrees and the second time it had 6.6 retard degrees.
these are my readings in park once i got home.. af 06 l8 39-42 bat 13.3 int 119-130 bl 105 mph 00 clt 175 ats 140 r 775 tps .40 iac 56 cc 05-215 mal 00
BLM says your real rich. IAC should be lower also. Might want to pull the IAC clean it well and and also clean inside the port where it screws in with TB cleaner. Might have some gunk in there. Also pull your plugs...they might be fouled due to being rich and it loading up on you. Start there and let us know.
87GN GT6776bb, 206/206 roller, 60# inj, PTE Stock Loc. IC, Tranny built by B. Hofer, PTC 10" 2800 Conv, Turbotweak, 93 octane & Alkycontrol No track times with new converter/engine combo...yet. |
You are describing the same situation I had once. Turned out to be a bad cam sensor. The cam sensor would kill the engine, and after short time, would start up and run for a while. Eventually, the car would not start at all.
When my car died when hot it was either Maf of Coilpac going out when hot.
Try to get readings when it starts choking & if the Maf is good, take a look at the coilpac. Open it up & look for goop starting to melt out!
87 LTD owned since May 88 No hood ornament from the factory! Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49! New combo is roller & 6776 Turbo. Track times coming!
I have seen a maf do this and it would read only one gram difference. I would borrow a maf and see if that does it. Also check your fuel pressure. Oxygen sensor too can cause thiss. When they fail they leave a lean signal to the ecm causing it to richen the mixture.
where could i buy or borrow a maf sensor to see if thats my problem. is there any kinda way to check the maf and see if its good? and the same with the coil pack is there a way to check them? a link with step by step instructions or alittle guidance would be very appreciated!!! i need all the help i can get
| Traffic Camera | TURBOTWIN2 | Turbo Lounge | 0 | September 27th, 2006 10:27 PM |
| What are we doing in the middle east? | weester87 | Political Views | 2 | March 24th, 2006 01:27 PM |
| in middle of PM install, help please :) | Papa John | General Turbo Buick Tech | 2 | March 13th, 2004 01:09 AM |
| crazy GN driver in middle of traffic video???? | fireberd350 | Turbo Lounge | 2 | May 5th, 2003 10:23 PM |
| No more Traffic CAM | Wilson | Hawaii Buick Enthusiasts | 3 | April 11th, 2002 02:10 PM |
