Old July 15th, 2008, 09:51 AM
ckmm's Avatar
six shooter
oil, and tranny temp
Few question: what dose the temp. run on the oil , and the tranny . Can just put them in front of the radd. Will that work or shood i put them on a fan . my car runs at 167 to 175 with the air on . I putting a ext oil ,and tranny cooler i want to see what the temps. are . Can i use a reg. temp gauge ,like one for the water temp . If i put it in the pans drill and tap them
86 BLUE T with t tops ported heads a gbodyparts stretched 23 row polished sli intercooler love it atr down pipe down turbo tweak chip t 6769 turbo large ajustable waste gate,remaned tran all new parts 3200 lock up stall. 42 lbs injector and alky lowered 3 "on 17"amerc. racing whells 3" stainless steel exhaust 3 1/2 "ele. cutout
Old July 15th, 2008, 11:10 AM
salvageV6's Avatar
Lightbulb
Oil temps. on my car run 180 tops in the winter to 230 when run hard in the summer, usually 200 or so with the A/C on cruising on the highway at 72.
They make specific gauges for oil temp. and tranny temp. but the mechanical ones are similar if not exactly the same as a water temp. one.
However the gauge itself will say oil and transmission oil on them so you won't get confused.
I only run the stock cooler for oil, tranny cooler is on the X support one one car in front of the condensor/radiator, other car the tranny cooler is behind and stuck on the radiator, never measured those temps. however.
I used brass 1/2" NPT fittings to T my mechanical gauge into the oil cooler line near the filter B-9 Baldwin with V4 intercooler bracket.
Bulb is large on a mechanical gauge but fits right into the oil stream with this setup.
Old July 15th, 2008, 11:33 AM
jevans's Avatar
Fluid Temps...
I don't monitor my oil temp, but I do have a transmission temp gauge and auxiliary trans cooler. My trans temp normally runs 160 to 180 during normal city driving. In busy traffic or after spooling up the turbo a few times, it will climb to the 200 range. I have a electric sending unit tapped into a deep aluminum pan.
Yeah "My other car is a Mustang"
Tranny temp 87TIGN Transmission Talk 5 March 26th, 2008 04:22 PM
Tranny temp sending unit in tranny return line at tranny end or radiator end? ratboy Transmission Talk 0 September 8th, 2004 12:00 PM
Higher tranny temp kymover Transmission Talk 1 August 30th, 2004 12:07 AM
Connecting Tranny temp gauge and oil temp gauge? Quick questions. V6UnderPressure General Turbo Buick Tech 5 May 5th, 2003 12:01 AM
tranny temp junkyard t Transmission Talk 0 June 23rd, 2002 07:05 PM
