Old July 3rd, 2008, 09:44 PM
FreeJack's Avatar
Steering column part question
Greetings,
My horn is not working. There are two parts that I need a little help finding. One is the wire with the spring and the second is the flat round piece that the other part fits into. Any ideas where i can get these? I thin I saw the flat round one at auto zone but the wire with the spring I can't locate.
Thanks!!!
Dale Hutchinson
1987 Turbo-T
ATR 3" DP, Accufab Fuel Pressure Regulator, Commander Chip, 60LBS Mototron Injectors, Walbro 340 Pump hotwired
Old July 3rd, 2008, 10:38 PM
87Regal3.8SFI's Avatar
V6 on steroids
The wire and spring....most any aftermarket steering wheel adapter comes with one, but you could probably hit up the local boneyard and "steal" one for free. The boneyard workers probably wouldn't even care. I believe almost all GM w/o airbags are the same.
FWIW I took the Grant steering wheel off my old Regal and put it on my Nova, I reused the original spring and wire supplied with the steering wheel kit, it fits both cars.
Old July 3rd, 2008, 11:06 PM
FreeJack's Avatar
Good tip.
Will look for a junkyard in my area.
DH
Dale Hutchinson
1987 Turbo-T
steering column question... FJM568 General Turbo Buick Tech 3 March 24th, 2008 01:31 PM
column shift steering column buickbert Parts wanted 1 August 28th, 2007 12:54 AM
steering column help ryanclem74 General Turbo Buick Tech 1 December 20th, 2006 08:24 PM
Painting the steering column plastic part gnfanatic Show Car and Restoration/Body Repair 6 August 10th, 2005 10:30 AM
Dont know where to post this, but steering column part ProjectWE4 General Turbo Buick Tech 5 November 24th, 2004 09:15 PM
