Will HR bar work with 9"?
Thinking about upgrading to a 9" rearend. Will I be able to use my HR Parts rear swaybar? Thanks, Scott
Scott Atkinson / White 87T 109: Performance Transmissions LV; ALKYCONTROL.com; MAXEFFORT "R"; Full Throttle Speed |
Yes, you just need the correct axle brackets for tube diameter of your 9".
Grey 87 Turbo-T 11.07@125 (should be stage II by end of summer) White 87 Turbo-T (bought it apart, slowly getting it put back together) 86 GN (backhalf project) 89 TTA 02 Crewcab dually w/ the 8100 & 5 speed Allison auto. |
Wonder what's different? Aren't the axle tubes 3" on both?
How about with a back brace? Didn't see that addressed on Paul's site.
The standard bolt on bracket will not work with a brace.
You can weld the lowers on ( might need slight modification), but you will not be able to use the upper bracket with the back brace.
RICK ELAM 1987 TURBO-T (completly apart) 1987 Limited (stock..needs to be taken apart) 1989 Turbo TA (just back together) 12.0 at 124... 60ft is overrated...
| Does anyone here work @ Discount Tire?? Or have an "in" with them?? | NCTURBOS | Turbo Lounge | 5 | December 20th, 2005 08:09 PM |
| If my 275s rub with stock 4" BS, how could 4.5" BS work on wider rims? | 2QUIK6 | Brakes, Suspensions, Tires & Wheels | 8 | February 1st, 2005 02:04 PM |
| "Work Flow" for a show car refinish? | tom h | Show Car and Restoration/Body Repair | 16 | November 17th, 2004 06:32 PM |
| Some "work in progress pics" come see! | 1000MileStylez | Turbo Lounge | 2 | January 24th, 2004 10:24 PM |
| Will 12" 1-LE brakes work with and clear 15x7" and 15x8" CORVETTE RALLY RIMS??? | SSYNERGY | General Turbo Buick Tech | 8 | April 1st, 2003 10:02 AM |
