Old June 29th, 2008, 07:09 PM
Question Which SLIC works best??
Can anyone provide some feedback on the Precision or G-body parts slic? Im not sure which one to buy..And for you guys that have used them will I have to modify my upper radiator hose?
87 GN,,62,000 miles,, TE60,,60# inj,,Pats 3200 Stall,,SMC alky kit,,comp cams beehive valve springs,,everything else is stock,,,best et to date 13.114 at 105.00,, 23# boost no knock on pump gas in 100 degree weather..
Old June 29th, 2008, 07:15 PM
lpaulabbott's Avatar
i got one fron gn1 performance and i tell you it is an awesome piece. it is the same one mark huffmann at TR Custom Parts 84-87 Turbo Regals, 94-6 Impala SS, 93-up F Body Cars, Olds G-Body Cars, Late Model Corvettes, S-10 Blazers is
1987 Buick Grand National.BoostJunkie 30 over 109, Forged Pistons, 204/214 cam, BB.TE-60, 50# MSD Inj., Razors Progressive Alky kit, 24 Row Stretched Intercooler, Chrome THDP. LS-1 Maf ,Translator. Dynomax Ultraflow exhaust. Hotwired Walbro 340, Billit Regulator, Rjc valve and plate, BoostJunkie 200r4 with a 12 inch 2800 Stall, 93 Alky Tweak Chip. Vacuum Brakes with S-10n's, Alum. Brake Drums. Poly Body Mounts. Front/Rear Braces. New Front Suspension, Red UMI Tubular Rears. Crager Street Stars. Mickey Drags 275 60's. Rear Air Bags best ET ON TA-49 IS 11.62@114.00. 1.609 60' 25# of boost 27/24. 93 octane and alky 9# launch. Brian Roman
Old June 29th, 2008, 07:19 PM
Thats good because I was looking into that one and the price is right on the money..Is there enough clearance for the sway bar and upper hose?
Old June 29th, 2008, 07:30 PM
86 TR's Avatar
Work In Progress
I bought a Precision piece from Cal Hartline. I got a pretty good deal on it and its awesome. last year all I added was a TE60 turbo, Precision Stock Loc. I/C and downpipe and that took my car from a 12.70 @ 107mph to 11.30's @ 119mph at 22psi boost.
Fits good, looks great and it must work! Any of the intercoolers offered by different vendors are good. I guess it all depends on your budget.
2000 Ford Crown Vic. daily driven beater, 1986 Buick Regal T-type Dk. Blue Metallic, tan leather interior, column shift, TE60, ported irons, intake, 212-206 hydraulic roller, HS 1.55 roller rockers, Precision Stock Loc. intercooler, RJC valve cover spacers, 60lb.motrons, red's 93 street chip, trans. built by Jimmy's Transmissions, orange stripe converter. No new track times with new combo. Old combo went 11.30's @ 119mph.
Old June 29th, 2008, 08:02 PM
Project TNX's Avatar
I haven't run mine yet, but I can tell you that the Gbodyparts.com one mates right up and clear the sway bar with no problem.
Brent
1984 WH1, 87 drivetrain, 204/214 cam, AFR, Walbro 340, hotwire, 60# inj, Razor Alcohol Inj, RJC powerplate, stock turbo, gbodyparts stock location stretched I/C, 3" gbodyparts downpipe & test, 2.5" Hooker exhaust, TurboTweak alky 93 chip, Pats 2800 stall, (times and turbo pending)
Old June 29th, 2008, 08:07 PM
t-typex1's Avatar
Is that stock long block ( no head work,stock cam,etc...)???
Just a lil V6, Stock long block, with bolt ons
Old June 29th, 2008, 08:10 PM
i have a gbody one fits great ,noticed a big difference after install, no numbers with combo yet other issues not related to it...
87 GN - updated bottom 206/210 roller cam, 61mm p trim bb turbo,adjustable acctuator,60lb injectors,75mm tb ported plenum,Ported stock irons big valves,ported intake,Turbosmart manual boost controler,RJC power plate & pullies,accufab afpr,255+hotwire,maf translator (6.25),4 inch big mouth intake with integrated sensor, Gbody 21 row stock mount intercooler,3.42 gears,2800 stall,shift kit,3 inch torque tech exhaust,3" tig masters down pipe,poston headers,razor single nozzle progressive alky kit,tt alky chip, scanmaster,powerlogger,28" radial, was original....
92 TY
Boosting the dark side off things
Old June 29th, 2008, 08:37 PM
86 TR's Avatar
Work In Progress
Sorry, its a .030 over 109, stock freshened heads(not ported), 210-205 flat tappet cam, RJC power plate, stock TB, stock upper intake.
Old June 29th, 2008, 08:45 PM
t-typex1's Avatar
Thanks. I was just seeing how close we were to each other, as low 11's to 11.00's is my goal
Old June 30th, 2008, 09:44 AM
TR Custom Parts's Avatar
Mark Hueffman - Owner
No clearance problems with the one we sell.
Intercoolers -Stock Location
Mark Hueffman - Owner of TR Custom Parts
1987 GN - List of Mods - http://www.buickgn.com/Features.htm
mhueffman@snet.net
VISIT OUR WEBSITE BY CLICKING THE BANNER BELOW.
Old June 30th, 2008, 09:52 AM
Buick "RICER"
Trader Rating: (14)
Precision's is a very nice quality piece Ill let ya know some #s when it gets cool again
Dan
Old June 30th, 2008, 12:21 PM
86brick's Avatar
It's just a V6 Brick.....
The Precision SLIC has already been in the 9's on Orlando's car without the aid of alky~
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
It is definitely a quality piece with the high efficiency Garrett bar&plate core and the main advantage I see over the competition is the 3" inlet/outlet especially on the cars that are really looking to push the limits with the SL.
I would say for cars that are mid 10's or slower any good aftermarket SL will work fine and especially if you are also using alky injection to further drop the charged temps.
87 Turbo-T, bolt-ons....
Old June 30th, 2008, 12:46 PM
I have a Precision & will say they sure a Pretty Lookin & have the 3" in & 3" out! Some others dont & to me it was important. With all the other makes on the market coming out lately, I would guess that performance wise they are all pretty similar. I mean, most of us are in the 10-12 sec range so will one make you that much faster than the other?? I Doubt It!!
The Precision fits great, quality peice & they are one of the originals out there. I am happy with their Turbo's & happy with the SLIC they sell. I think they are a good company & been making us parts a long time, so take it from there? I will say again, they sure look great & fitment is Perfect!!
87 LTD owned since May 88 No hood ornament from the factory!
Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49!
New combo is roller & 6776 Turbo. Track times coming!
Old June 30th, 2008, 01:46 PM
Buick "RICER"
Trader Rating: (14)
we are just trying a few things to see if we gain anything.. Ours is a street beater.. 650 miles last week and prob the same thing after driving it all over hell this weekend .. I have seen Orlando's car in action
Dan
Old June 30th, 2008, 05:24 PM
86brick's Avatar
This is on Melissa's car, right Dan? If my memory serves me correct you guys were previously running the CAS V4 SLIC. Will be interesting to see if you see any gains especially from going from the 2.5" inlet/outlet to the 3" on the Precision. That is why I personally like the SLICs, they work great on true street cars and there is also the stealth factor considering everyone usually expects a fast turbo car to have a big FMIC or one of them ice boxes.
Old June 30th, 2008, 06:51 PM
Buick "RICER"
Trader Rating: (14)
Thumbs up
ya that V4 got the job done for us for a long time .. hell she had that when she was running mid 11s I like the "look" to .. Plus ya don't have to worry about overheating sitting in beach traffic
Dan
Old June 30th, 2008, 08:23 PM
SloGN's Avatar
dumb a$$ racing
no heating problems here before and after a FMIC. even with the a/c on
" Make the best of your circumstances, No one has everything and everyone has something of sorrow intermingled with the gladness of life. The trick is to make the laughter outweigh the tears. Don't take yourself too seriously. You can't please everybody; don't let your neighbors set your standards, do the things you enjoy doing, but stay out of debt. Don't borrow trouble. Imaginary things are harder to bear than the actual ones. Since hate poisons the soul, do not cherish enmities, grudges. Don't hold post-mortems. Don't spend your life brooding over sorrow and mistakes. Don't be one who never gets over things. Do what you can for those less fortunate than yourself. Keep busy at something. A very busy person never has time to be unhappy."
Old June 30th, 2008, 10:06 PM
ckmm's Avatar
six shooter
Gmbodyparts
i put gmbodyparts stretched slic on 23 row polished almm. . went from a fmic to this . could fell the diff. quicker off the dropped the temp. down 170 with the air on .the temp. of the air going to the motor stays around 100 115 deg. . the temp comeing out of the turboat 150 to 160 thats at 70 to 75 mph. when i would get on it the temp out of turbo would max out the scanmaster but temp. going in the motor would be about 190 befor the alky . big diff. in temp love the ic looks great and work better .
86 BLUE T with t tops ported heads a gbodyparts stretched 23 row polished sli intercooler love it atr down pipe down turbo tweak chip t 6769 turbo large ajustable waste gate,remaned tran all new parts 3200 lock up stall. 42 lbs injector and alky lowered 3 "on 17"amerc. racing whells 3" stainless steel exhaust 3 1/2 "ele. cutout
  #19 (permalink)
Old July 1st, 2008, 05:38 AM
Buick "RICER"
