Old June 17th, 2008, 09:32 PM
buickrob's Avatar
What Turbo Should I Get?
So, with my current setup, see my sig below, what turbo would you get to try and run easy 11.8's?
Not sure I want to spend the amount needed for Ball Bearings though.
1987 GN hardtop, 6131e, ESP front mount, SMC progressive alky, Pat's Converter 2800 Stall 12", 50# Injectors, hotwired 307, THDP, 2 1/2" exhaust w/ ultra flow muffs, Turbo Tweak alky chip, adj fuel regulator, RJC boost controller HD wastegate, 9" K&N w/ 3" maf pipe, 160* stat, R42TS plugs & 8.5mm MSD's, Tubular Lowers, 15x8.5 GN wheels w/ 275/60/15 MT drag radials
Old June 17th, 2008, 09:42 PM
brand new precision 106mm turbo - Yellow Bullet Forums
Old June 17th, 2008, 10:28 PM
buickrob's Avatar
Originally Posted by LV GN View Post
might be a bit much
Old June 17th, 2008, 10:45 PM
V8Assassin's Avatar
100mi away ready 2 strike
My suggestion would be a 6152 dual bb unit. I ran the below time with alot less in the combo than you have (stock convertor, stock location ic ect.). With good gas or alky it should get you where you want to be with ease.
First pass 14.6 = Stock
Second pass 12.3 = Bolt on's
Third pass = New gun /New bullets, Times Soon!
** Just a little V6 with an attitude**
Old June 17th, 2008, 10:50 PM
buickrob's Avatar
That's the one I was thinking of, a 6152. I haven't run the car since putting on the downpipe, alky, TT chip or front mount. I might even be in that low 12 - high 11 range right now if I push a lot of boost. Just thinking I might want a turbo that doesn't have to work as hard as the 44 to do 11s.
Old June 17th, 2008, 10:57 PM
JimP's Avatar
With my non bb te-61 and a front mount at 18 psi I went 11.48's at 118 mph. Other mods in sig, with a bb unit should be no problems at all and will spool real quick. Been thinking of upgrading myself but my turbo only has about 2,000 miles on it. Oh yeah launched with zero boost as well for that e.t.
You'll be shooting for low 11's for sure.
How are the 009's working for you? I'd order up some 60#'s while I was at it.
1987 GN PP irons, TE-61, Cotton's Front Mount, ATR Double Pumpers, 60#'s, TT Chip, ATR Dual 3 inch exhaust. THDP, SMC Alky Kit, UMI Upper and lower control arms, Bilstein shocks, ATR Coil springs, ATR front and rear sway bars, Built Tranny with Pat's 10 inch 3,200 stall, Vacuum conversion, SS brake hoses, and what ever else I forgot
Old June 17th, 2008, 11:02 PM
V8Assassin's Avatar
I would probably go ahead and run it with the new mods before adding the turbo. Might make diagonosing any unforseen problems easier. I prefer the BB unit because of spool, I think you would be very happy with that turbo.
BTW those 60#'s are probably a very good idea!
Old July 11th, 2008, 08:03 PM
buickrob's Avatar
Well I got a 6152e and man it takes a lot for me to spool it. I knew it would take more than my old TE44 but didn't expect this much. Think I did something wrong or does it make sense that it might take a lot of throttle to get some boost with my combo? It doesn't seem to be spiking so I don't think I have an exhaust leak.
Old July 11th, 2008, 10:47 PM
What A/R did you go with? If you went with the .85 it will spool slower. Also did you get a BB turbo? If not it will spool slower. Is your DP matched to your ex housing? Check for ex leaks and vac leaks. Make sure that your wastegate is working properly and you have the correct spring installed. If you have a scan tool/logger, check your readings down on the low end for a/f and timing. A 3000 rpm stall should be plenty for that turbo. Good luck. HTH
Bryan
http://www.cottonsperformance.com/
87 GN moonroof with 43k
Stock block Champion GN1 14 bolt aluminum heads, ARP bolts, Cottons valve covers, Comp Cams 218/212 hyd roller, Scorpion rockers, Comp Cams double roller TC, home ported intake, Champion 1" plenum spacer, RJC PowerPlate, Turbonetics GT-K 850 BB, Turbonetics boost controller, Cottons 3" DP with external wastegate,Turbonetics Racegate, Cottons 4" cold air kit, Cottons FMIC, 72# inj, FAST XFI, ALKYCONTROL by Julio, Hooker cat back, Art Carr 9" NLU, Art Carr internals,Precision turbo saver, Metco adjustable uppers, Metco lowers, HR sway bar, 275/60/15 MT DRs
New stroker from RPE should be in soon
Old July 12th, 2008, 10:03 AM
GNAT87's Avatar
With not knowing much about the turbo and weather its bb or journal it could be a converter problem
87' Grand National-GT6776RH, F.A.S.T. XFI, Precision FMIC, Precision 3200 Conv, Alky Control, THDP, 83lb Injectors, Brians 2004R...
Old Combo-11.88 @ 114.00 1.80 60'
Currently Rebuilding
New Parts-Diamond .20 Over Pistons, Eagle Crank, RJC Girdle, Champion Race Ported Alum Heads, Champion Complete Race Intake, Cottons 212/212 Roller Cam Kit, PTC 9.5" 3400 Non Lock-up, Accufab Regulator, Accufab 70mm Throttle Body, TA Stainless Steel Headers, and much more!
New motor built by Geoff @ Jackson Cylinder Head
Jackson, Mississippi 601-353-1014
Old July 12th, 2008, 12:33 PM
You have more than enough turbo to go high 11's. I would try another converter. A 2800-3000 12 inch converter is borderline at best for a journal bearing 6152. Get yourself a good 3200-3400 9.5"-10" converter and you will see a difference in spool up for sure. A .63 exhaust housing would help greatly also, if you don't already have one.
Old July 12th, 2008, 02:52 PM
stroker V6
you need 3200 stall converter with this turbo ,I ran that turbo with 3200 stall converter and it spooled realy nice , it happens that I am looking for 9.5" none lock up PTC for my combo so I have my current 3200 stall 10" PTC lock up converter for sale if you interested , it's a perfect converter for 11 sec car ,let me know
109 block , stock crank /rods, girdled, JE pistons , GN1 heads,Champion intake , roller rockers ,212 roller cam,dual BB 76 GTQ , 83lbs injectors , double pumper , Fast B2B,70mm TB ,Precision front mount IC, turbo 400/trans brake with 9.5 NL converter , detroit locker 9" with 3.50 gears .....yes ,it's fast
Old July 19th, 2008, 09:31 PM
buickrob's Avatar
Thanks for the replies, I was away this past week.
The turbo is journal bearing and has a .63 Precision housing. No exhaust leaks but I'll have to check through for vac leaks. I replaced 90% of the vac hoses 4 years ago.
Bryan, what spring were you referring to? The wastegate is internal and seemed fine when I had the downpipe off installing the turbo.
Two things I'm thinking:
1. I had this 2800-3000 stall converter with a TE44 for years and it spooled up crazy fast. Maybe I was just really used to that. This turbo takes what seems like 1.5-2 seconds from a mash of the gas to reach 24psi or so. Once it has 5 psi it jumps right to 24 so it's just a matter of getting it to build. Maybe I'm over-reacting.
2. I've gotta get the cat out of the car. I know it is a 3" high flow but I'm sure it's not helping.
What do you think about the cat?
Old July 19th, 2008, 11:29 PM
My 6157 doesnt spool very well with a 2800-3000 stall either.As everybody else has stated i think something in the 3200-3400 range might work better.
Old July 20th, 2008, 06:42 AM
bad V6's Avatar
The smaller/lighter 3200 stall converter is what this turbo needs. I'm running a 9.5" Vigilante and it spools as soon as I touch the throttle. The problem now is getting traction, even though I'm running drag radials on the street. However it is a blast to drive and play on the street.
'87 GN
Stock unopened long block with a few bolt-ons:
GT6152E, Mototron 60#, Alky Control, MAFT Gen2 with Extender Extreme and LC1 WB, hot wired Walbro, AFPR, Cartek FMIC, Tomka CAI, Terry Houston DP, ATR 3" single shot, PI Vigilante 3200 L/U, RJC boost controller and power plate, Scanmaster, Direct Scan
Old July 21st, 2008, 09:22 PM
buickrob's Avatar
I got stupid for a bit and didn't realize what you were talking about when you said spring Bryan. I have an HD wastegate on this turbo.
Do I need an HD solenoid to go with that? I remember Poston used to sell those.
Old July 21st, 2008, 09:59 PM
I was speaking of the external wastegate. I must have been speed-reading your sig. Evidently I was being stupid. I now see that you have an internal wastegate. Sorry for the confusion.
Bryan
Old July 29th, 2008, 10:44 AM
buickrob's Avatar
Put 50# injectors on it and got a chip burned for the 6152e instead of using my TE44 chip with the fuel bumped up. Spools much better! Maybe I was way rich at the bottom end.
Difference between non turbo and turbo Regal fuel pump sending units? d0n_3d General Turbo Buick Tech 3 August 27th, 2007 12:01 PM
Race chips 55s, 3.5 chrome MAF & inlet bell, stock turbo, turbo shield tim87tr Parts for sale 18 August 1st, 2007 04:19 PM
1987 Turbo Buick T, 1983 28
