It's more like 3.15" A 3" silicone turbo hose "will" work, but it is a VERY tight fit. The Accufab 70mm TB also has a VERY short clamping area. I just had to grind the T-bolt clamp down just a bit to get it to fit between the lip and the lower area of the IAC boss. They could have made it .15 longer and would sure help things out. Also, I used a 3.25" hose to join the 3" up pipe to the larger than 3" Accufab TB.
As a side note........Be SURE to remove the throttle blade screws and re-install them with RED loctite. They have been known to come loose. I also stake the screws in place, too. I clamped a 10" long 3/4" shaft in the vise, and then placed the blade screw heads (one at a time) on the smooth shaft end. Then I used a center punch and taped it with a hammer to stake the center of the threaded end of the screw. That way they can NEVER fall out, even if the screws come loose a little. One of those little screws can really mess up your day.![]()
Ken B. |
Thanks for the info. I have some extra 3" hose laying around that I will try to make work. I'll be sure to loc-tite the screws, too. Jim |
| What size down pipe should I go with? | 87Regal3.8SFI | General Turbo Buick Tech | 19 | February 7th, 2008 01:55 PM |
| RJC 70mm Throttle body-What size coupler do I need for upper pipe to TB? | BetMinesFaster | General Turbo Buick Tech | 2 | August 29th, 2007 05:14 PM |
| WTB: 70mm tbody and hemco 70mm upper | Turbo Steve | Parts wanted | 0 | August 20th, 2007 01:25 PM |
| intercooler pipe size? | Tim Barnum | Stage II Tech | 1 | May 15th, 2006 09:49 PM |
| What size T-Bolt Hose clamps for a stock size up pipe?? | Chrisk | General Turbo Buick Tech | 4 | August 25th, 2005 03:13 PM |
