Old June 17th, 2008, 04:55 PM
Chrisk's Avatar
TurboTransAm.com
Whats the Filter on the vac line of Vac Brake Booster
Can someone tell me what the black filter I see on some cars that have the Vac Brake conversion? Is it needed or just straight hose?
Thanks
1989 Turbo Trans Am #836 w/8500 miles Sleeping.
1987 Grand National, 249" Stroker Built by Lonnie Diers of Extreme Automatics. 200R4 w/ TBrake built by Jimmy's in Mundelein. 9.5" NL Converter by PTC & Dusty Bradford. PTE 6776S DBB Turbo, PTE FMIC, Alky by AlkyControl, and the list goes on and on...
1996 Corvette Convertible White with Red Guts.
Turbo Trans Am.Com
Turbo Trans Am Registry
Old June 17th, 2008, 04:59 PM
notacarlo's Avatar
What the hell is bar?!
Keeps oil vapor and particles out of the master cylinder.
1987 Grand National 12.1 @ 108
Ferrari F430 Challenge Series Team Driver/Fabricator
Old June 17th, 2008, 05:08 PM
Chrisk's Avatar
TurboTransAm.com
Thats what I thought. Thank you!
Why is there not a filter on the TTA's?
Turbo Trans Am.Com
Old June 17th, 2008, 07:24 PM
87Regal3.8SFI's Avatar
V6 on steroids
It's not a check valve to keep vacuum in?
Old June 17th, 2008, 09:56 PM
Red Regal T's Avatar
Trader Rating: (13)
I don't use them. No issues. I just run vacuum to the booster through a 3/8" hose from the PCV line to the check valve on the booster.
JOHN DICARLO
PLEASE CHECK OUT MY ...
87 RED REGAL T, or my 87 DARK RED T and don't forget my 87 GRAND NATIONAL
Old June 17th, 2008, 10:06 PM
x2 - ....stealth.....
Brian MacKinnon
Guntersville, AL
86 T-Type, mostly stock
rear brake line from MC...thin or thick line? monte87LS Brakes, Suspensions, Tires & Wheels 3 June 9th, 2008 06:24 PM
brake booster? Buick T Hawaii Buick Enthusiasts 4 March 12th, 2006 11:47 PM
Can I plumb my boost guage into the vaccum brake booster line? 6pack General Turbo Buick Tech 2 October 10th, 2002 04:56 PM
brake booster copteaser General Turbo Buick Tech 1 October 9th, 2002 09:06 PM
RJC Biggie oil filter adp % Booster plate JFH General Turbo Buick Tech 2 July 24th, 2002 05:37 AM
