maf
Here we go again with the maf question of the day. My mechanic did the tap test and it ran rough enough till it died. the second time nothing happened. My scanmaster shows 6-7 @ idle--850 rpm. I took it out and punched it to wot--255 on the button--it sceamed. Before I invest any more money on a new maf&translator should I try and clean the old one? I have some c.r.c. maf sensor/cleaner. Any suggestions would be welcom.
so raretommy g87 GN purchased September 2005 from Mark Evans in Akron Ohio.24,000 miles.Stock paint & interior. 61 turbo,55psi injectors, Terry Houston 3" downpipe and full stainless exhaust system,xp plus fuel pump,new valve springs,adjustable waste gate and fuel pressure regulator,big neck intercooler and 106,modified speedo that goes way past 85mph,kn air filter and the intercooler pipe to throttle body,tcc switch in ash tray.
you could try and clean it with the CRC maf cleaner, but I would keep an eye on it and repeat the tap test again, it might be on it's way out slowly and be intermittent.
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm. cross drilled slotted rotors, vacuum brake conv. Kirban GNX style rims,48k on car, 93 Turbo Tweak chip, 2.1 scanmaster,knock guage, 3" LT1 Maf w/translator, VDO guages,manual boost controller. |
maf
Thanks,will do.
