Old June 5th, 2008, 01:18 PM
GP Black Pearl's Avatar
Oil Pump Problem ?? 87 Gn
Gasket for oil pump was leaking, so installed new gasket. Now I can not get oil preasure. Filled filter with oil(nothing) tried injecting oil down turbo oil line (nothing) removed cam sensor, hooked up drill to prime pump (nope) what am I missing? OH had 70 psi. before. Thank's guys for your time and help.
ED
Old June 5th, 2008, 01:24 PM
wrench turner
take it back apart,look at pressure valve to see it move .....
Old June 5th, 2008, 01:53 PM
PAck pump gears w/ grease. that way the pump primes
Old June 5th, 2008, 02:17 PM
gossamer's Avatar
+2 pack the pump with white grease or vasaline.
1987 GN Astroroof
Precision 6131BB, BGC 23 row stretch IC, 60lb inj., 212/212 Comp roller cam, T&D rollers, TT Akly chip, Razor's Alky kit, Billet main caps, Speed-Pro forged pistons, port & polished heads & intake, 70mm T/B, Edge 10" 3000 stall L/U, trans built by mikestertwo with PTS parts, 3" THDP, Poston headers, PTS aluminum radiator, etc., etc.
Old June 5th, 2008, 06:18 PM
Don't need vaseline...remove top oil cooler line from radiator...need a small funnel...put it in the cooler line...slowly pour oil in until it's near top of funnel...spin the oil pump backwards(counterclockwise)...you'll see the oil from the line being sucked in...go slow...jusy spin it a little...do it maybe 3 times...then hook the cooler back up...now spin the pump clockwise...should feel the drill start to drag...should have pressure...
Scott
87 GN - Street/Show Car (orig owner - 41K miles)
87 T - Street/Race Car(10.46 - 131.68 MPH) - TSM setup
possible fuel pump problem? tb3 Hot Air (non-intercooled) Tech 7 April 12th, 2006 07:47 AM
shurflo pump problem dsg Alcohol, Nitrous and Propane Tech 6 June 29th, 2005 10:21 PM
Pump mounting problem Paul Clark Alcohol, Nitrous and Propane Tech 6 June 15th, 2005 09:20 PM
fuel pump problem Lbraucht General Turbo Buick Tech 2 March 4th, 2003 07:34 PM
fuel pump problem gn79 General Turbo Buick Tech 1 November 5th, 2002 02:35 PM
