Old June 5th, 2008, 06:05 AM
86 T-Type
Looking at Amsoil 5w-30 diesel (ZDDP)???
Hello
I Emailed the Amsoil tech line yesterday. I Told them I have a 400hp stock block GN mostly street driven. His answer was.
"The HDD will work great in this application, the HDD has high levels of ZDDP and will protect the flat tappet cams. HDD Series 3000 Synthetic 5W-30 Diesel Oil 1266 zinc1379"
Is anybody using this grade? any input would be helpfull.
Thanks
Old June 5th, 2008, 06:57 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Too thin, you are paying alot for synthetics. Why not use rotella or other dino oil and some ZDDP plus from the vendors. Save you some cash.
FWIW my 87 has never used synthetic and its all stock (timing chain and valve springs) and has 168 k miles on it and still pounds low 12s all day
USAF POWER PRO
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe.
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list still has warranty till 2010.FOR SALE
Old June 5th, 2008, 08:17 AM
Rototella is not what it used to be. Amsoil is the only company I contacted that adressed our oil concerns.
Here is a link in V8Buick that has the pdf they sent me (would not attach here.) Amsoil ZDDP info - V8Buick.com
Viscosity needs very from motor to motor. If you have over 11 psi per 1000 rpm at all temperatures then you have good oil pressure. My GN has great oil pressure with 5-30, the GSX is a little happier with 10-40.
Doug Gorton
70 GSX
87 GN
73 Ski Nautique
Old June 5th, 2008, 08:41 AM
BOOST SUX MY WALLET
Correction what I meant was except Valve springs and timing chain
USAF POWER PRO
05' Harleys
Old June 5th, 2008, 09:05 AM
BOOST SUX MY WALLET
True but I was reffering to Rotella or whatever oil WITH the ZDDP ADDITIVE.
Here in the south its hotter than a 4 balled tomcat in the summer so 5w30 IMO is to thin on a DD with A/c in bumper to bumper IMHO. I prefer a thicker oil.
USAF POWER PRO
05' Harleys
Old June 5th, 2008, 09:20 AM
Got hotair?
If you're going with a 30wt, use their ACD straight 30 instead. It's classified as a straight 30 since it has no VIIs but could be classified as a 10/30 since it flows well when cold. In fact, the label says 30/10-30. It has tons of ZDDP, just under 1,400ppm if I remember. I use it in my daily driver TL year round.
84 GN. 4.1L girdled with 8.5:1 JEs, 212-212 Comp Cam, GN1s, Ported stock intake, Ford FM IC, 6765DBB, KB headers, Cotton's 3" DP, Innovative Turbo Systems external gate, 60lb injectors, Turbo tweak chip, and a few misc things. No times with new combo yet.
06 Acura TL daily driver.
Roller cam and ZDDP BlackoutDrunk General Turbo Buick Tech 3 February 26th, 2008 05:20 PM
Interesting Article I Got With My Case Of Zddp. Read About Diesel Oil! LEGACY_GN Texas Area 13 February 20th, 2008 04:34 PM
ZDDP question Brian Mc Engine Tech 82 November 5th, 2007 05:38 PM
Amsoil has ZDDP sailbrd General Turbo Buick Tech 11 October 6th, 2007 08:40 PM
Oil ZDDP supplement Sal Lubrano General Turbo Buick Tech 33 September 22nd, 2007 06:20 AM
