87 GN, BB66,3000 westcoast stall,hotwire,walbro,DW,210/215 roller,4340 crank,65lb injt,homemade alky,Scan2.1. ect. |
cool thanks
once i get my boost to where i want and then do i add moor timing or take a way fuel? thanks again
was a 1984 now 87 divetrain with intercooler hot wire walboro fuel pump 3" down pipe single shoot exhaust 275/50/15 mt drs tt 110 chip power plate rjc boost controller big mouth new eaton posi stock turbo and intercooler and a cam 3 years in the making |
I would start with leaving the timing alone, where Eric has it in the chip with no correction. Add boost and fuel, shooting for O2's in the hi 700's, until you start to get a teeny bit of knock. Then you can play the more boost and fuel/less timing game. Depends what turbo you have (whether you are going above it's 'sweet spot') and how much boost you're running. Typically, unless your running a ton of boost (like 26+ psi) you should make more power with higher boost/more fuel/lower timing strategy. Again, depends on the turbo.... most of our commonly used turbos will become very inefficient above 26-28 psi, and you might make more power at that level by increasing timing/fuel and not raising boost any further. That's how I would approach it...
Brian MacKinnon Guntersville, AL 86 T-Type, mostly stock |
| tunning help | mikeneedacar | General Turbo Buick Tech | 0 | December 11th, 2004 07:49 PM |
| need some tunning help | 96SCTA | Performance ECM Upgrades | 14 | August 5th, 2004 02:41 PM |
| tunning | fasaz6 | Great Lakes/Canada Area | 1 | May 21st, 2004 09:48 AM |
| help with tunning on ls1 & translator | Turbo317 | General Turbo Buick Tech | 4 | April 13th, 2002 11:38 AM |
| tunning help | a.j.hogan | Hot Air (non-intercooled) Tech | 1 | September 6th, 2001 11:15 AM |
