Old May 16th, 2008, 10:06 AM
Banned
Thumbs up Seeing is believing !!! PTS Xtreme RADIATOR !!!
I just can't believe this my car is running 30 DEGREES Cooler AND it's 30 DEGREES Hotter from where I was over my stock Radiator.I made Two 1/8 mile + passes and The car the Hottest I could get it was 170 Degrees.This was by far the best 500 I ever spent on a car ever !!! This RADIATOR came from Bruce Toelle @ PTS Xtreme in California.
GNXJAMES548
Old May 16th, 2008, 10:08 AM
Banned
Thumbs up Radiator
GNXJAMES548
I'm located in NJ if anybody wants to see for them self !!!
Old May 16th, 2008, 10:09 AM
What no Pics??
Did you get the oil coolers or leave them out?
87 LTD owned since May 88 No hood ornament from the factory!
Old combo went 11.80 with 1.75 60 ft & broken crank gear teeth with 95* weather on a TA-49!
New combo is roller & 6776 Turbo. Track times coming!
Old May 16th, 2008, 11:57 AM
Banned
Thumbs up Radiator
Yes it has both coolers in it.
Old May 16th, 2008, 06:05 PM
I ran a 5/8" tube three row copper brass radiator w/o the tranny cooler to under 170* in 90* + temps. Used the dual Ramcharger fans, external tranny cooler with cooling fan, and trans temps never ran above 185* after a hard run. I ran a FM IC and used the factory cooling circuit to run this set-up. I'm improving this on my next project car, 86TType. Tranny oil heat does heat the coolant temp a lot. This idea came from a BB Buick Car that only ran an external trans cooler. A lot of different ways to accomplish better cooling. Gene
Old May 16th, 2008, 06:44 PM
You replaced a 21 year old radiator you better see results!
I replaced my Radiator with a new non AL setup with very good results
New Cotton's FMIC New fans New AC condenser I run 162-167
84GN with built 109 0.30" over Forged pistons
BB6776HR, Comp 218/212 Roller Iron Champion ported heads TD 1.55 Rockers Ported Intake & Plenum 62mm TB,RJC plate,3"THDP,60lb injectors TT chip,Cotton's FMIC,Mark's Cold Air Kit, Protorque 2800 for the street
ALKY, RJC boost controllerElectric Cutout,Translator, MAF LS1
Fenders,radiator,Radiator Saddle jayt555 Parts for sale 1 July 30th, 2007 11:32 PM
F-Body Radiator + Dual Spal Fans + Cutlass Radiator plate= THUMBS UP! Scott4DMny General Turbo Buick Tech 8 April 16th, 2007 08:37 PM
radiator support, radiator, tranny cooler. CHEAP its turbo time Parts for sale 0 August 5th, 2005 08:03 PM
Need Help (bigtime) With Radiator Hoses For Aluminum Radiator TURBOGTA1 General Turbo Buick Tech 5 October 19th, 2004 12:08 AM
Turbo Buick radiator a Cadillac radiator? bishir Turbo Lounge 3 January 14th, 2004 01:09 PM
