Old May 16th, 2008, 08:26 AM
86canadaGN's Avatar
Door Lock Relay
Could anyone let me know the wiring schematic for the power door locks and where the relay or control module is located inside the car.
86 GN, 109 block, 65 lb injectors, 70 mm TB, FMIC, TE63, 9/11 Convertor
Old May 16th, 2008, 10:03 AM
MISSING 2 CYLINDERS???
The door lock actuator is located in side the door. If it has power when you hit the switch then it is most likely bad and needs replacing.
Scott Lambert
87 GN 32k Original Owner
GT6131e, Crane Billet Roller 212/210, 3" SS THDP, 9" Art Carr, 57lb inj, 22 Row Thunder Fab, Hooker Cat Back, Hot wired Fuel pump, Adj fuel reg, Bell Mouthed TB, Stock location K+N w/ Postons base lid, Scanmaster, Ported Big Valve Heads- All Studed
86 T-Type Now a Parts Car
87 Turbo T Astro-Roof Chrome Trim
87 Turbo T Solid Roof White w/ Blk Trim-Mama's New Toy
Old May 16th, 2008, 03:43 PM
If you can't read this, let me know. I can email a clearer scan. The relay is mounted to the sheetmetal behind the ECM.
David
87 GN-39k T-Top's
98 ZR2 Blazer-Daily Beater
Body Screw for attaching Door Lock Relay Morbid Before Black (non-SFI) Tech 1 December 30th, 2007 05:39 PM
Where to find Power Door Lock Relay Morbid Parts wanted 6 December 23rd, 2007 05:46 PM
door lock relay 87gn? the wrath General Turbo Buick Tech 1 April 2nd, 2007 07:53 PM
Power lock relay jpratt General Turbo Buick Tech 3 January 25th, 2005 07:38 PM
Door Lock Hard To Operate gets stuck and key unable to open door eddiedellz General Turbo Buick Tech 1 February 28th, 2004 10:18 PM
