Need information.
How does a faulty Fuel pump act? My car seems to hesitate/buck now and it happened right after trying to fix the fuel pump..
Thanks. Last edited by 86gndave : May 15th, 2008 at 02:14 PM. |
filter
Had a clogged fuel filter do that to me once in a '89 chevy PU, start with the simple stuff
'87 GN, astroroof, digital dash, 39K miles, Pypes 2.5" cat back + cat on a diet, 60lb FPR, 009s, home made cold air, hot wire, RJC power plate, RJC boost controler, more to come.
I changed the fuel filter 2 month ago, and the car was in repair, i only played with the fuel pump to try to fix the gas gage, but there was wires that were needed to be weld dont know if that did something to it. It dosen't work still
pump noise
when you turn the key to run does the pump power up? There is a lead right by the alternator (white wire with male connector I believe) hanging out of the plastic shielding. That is a fuel pump lead, connect 12V and the pump should run.
So you got power to the pump, that's good. While the engine is running listen to the pump for a couple minutes, kneel down behind the bumper. It sould be steady no variation in pitch. If you hear any the pump could be bad or as you said faulty connections. A fuel pressure gauge would be much easier, you can mount one on the fuel rail or better yet get an extension from caspers and tape the gauge to the winshield. When the car bogs watch the pressure.
You bet, lots of things can cause those issues. I think some of the more common causes are the MAF or the coil but thats assuming you've taken care of the basic tune up stuff.
| Information On Gnx 293 | BUICKGNX | GNX - The fortunate 547 | 0 | February 5th, 2007 11:45 AM |
| Need information | GogglesPisano | Turbo's and turbo related parts | 3 | December 17th, 2006 01:09 PM |
| BOV information | NC87GN | Turbo's and turbo related parts | 3 | November 13th, 2003 04:29 PM |
| Looking For Information | Dennisk421500 | Turbo Lounge | 1 | April 4th, 2003 03:55 AM |
| Information | tech69 | Hawaii Buick Enthusiasts | 1 | June 18th, 2002 10:06 PM |
