1st, I've found from noodling with manual boost controllers that keeping the adjustable rod tighter and letting out the manual helped spool up. I generally let out the manual's screw until I know it's not doing anything, then screw it in to get a few lbs of boost to put pressure on the spring and adjust the wastegate arm from then on for more boost.
Anyways, it spikes now because the factory solenoid bleeds off pressure so it never hits as hard unlike the manuals and need to bleed off that pressure all of a sudden. The cure is the take off the downpipe and open up the wastegate hole on the turbo's exhaust housing. There are a bunch of tech tips on it but stay inside the carbon ring around the hole and use a shop vac to suck out the debris. Smooth out the inside of the housing and then watch the spikes disappear with maybe a 1psi at most.
Mike 87GN T-Top down 421lbs. Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Stageright, PI 3400 5disc, KB Plenum/70mm TB, Razor's Alky Kit, 60lb Inj, -8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs |
Thanks.
I'll give the controller adjustment tips a shot. When backing the nut out on the controller....how far is too far? Just wondering if there is a minimum thread engagement before I start leaking at the controller..... The exhaust elbow porting has been suggested to me before. In fact one of these nice gents has offered to trade me his ported elbow for my unported one....
87 Grand National: TT Alky chip with 60# inj; Hotwired Walbro; ScanMaster 2.1; Adj WG actuator, AFPR; 160* stat; RJC Power Plate; Alkycontrol; TRC Big Mouth cold air kit; Duttweiler neck IC; Hooker cat back; Direct Scan; Czarnota V6 and a boost gauge Otherwise bone stock.68 SS Camaro: ZZ502; TKO-600; Moser 12-bolt (3:73 TrueTrak); Global West tubular control arms, QA1 coil overs; SSBC power disks all around; quick ratio steering; Hotchkis sway bar; solid body mounts; Be Cool radiator; Pertronix ignition; other stuff; I don't have the timeslip to prove it yet...but...I bet you a dollar it does 11's.
Hey mean chicken just went through this, I was getting about 3-4lbs of boost creep on the stock setup. So I bought the RJC controller and ported the wastegate hole with a dremel tool....problem solved. There are good posts here on how to do it, pretty simple. Hardest part is getting the bolts out of the exhaust housing without snapping 'em off. Now she shoots right to 17lbs and stays there all the way through third. That is the lowest setting I could get the RJC controller too. I cranked the top screw all the way out, turned it in 3/4 and locked it down. 17lbs is a little higher than I wanted to be to start, wastegate rod set to stock length/preload. I haven't tried tuning the boost controller but I would imagine I could compress the spring a little more to give less preload. But the boost hits hard now....it was a little scary at first but it's a blast to drive.....kind of like an e-ticket ride at disney. LOL
'87 GN, astroroof, digital dash, 39K miles, Pypes 2.5" cat back + cat on a diet, 60lb FPR, 009s, home made cold air, hot wire, RJC power plate, RJC boost controler, more to come.
So my advice Tim, when you get ready to remove that elbow is to hold your breath...lol na prolly stick a little heat on at least the top 3 bolts then quick nudge on the tight side then back em out...of course I always tighten old bolts first then loosen I sold that real pretty elbow I ported for ya..lol but i got another sitting here ready for clean up...lemme know And quick note: the porting thats being mentioned is the wastegate hole, not the elbow itself although that does help with flow Last edited by mcasteel2112 : May 10th, 2008 at 05:47 AM. |
+1....great advise
I would check to see if the wastegate doesnt have a hole in the diaphragm, also loosen up the wastegate rod to lower the boost. I noticed in your sig, you have a adj wastegate, is it a heavy duty wastegate????
Start with the basics, it shouldnt spike. Did you buy the RJC valve from RJC? BW
BRYAN Eric Marshalls Turbo Tweak Chips Timeslips for white car TA61/009 Inj Under hood shot of white limited ![]() ![]() Proud TTA owner |
Like mentioned, the ported elbow won't fix this problem, porting the turbo's exhaust housing is the needed porting.
Dremel and a shop vacuum = No more boost spikes ![]()
Did anyone mention shooting little PB Blaster/kroil/Rust Buster or some other penetrating liquid on those four elbow bolts a couple times, a few hours before you give 'em He!!? Might save you some headaches later. Yeah- Port the wastegate hole. I never had creep, until I installed the RJC. Never had it again after I ported the housing. But then- That spike may represent a different issue.
'85 GN- sold 'cause it had t-tops / '87 Turbo-T: TA-49, TH 3"DP, Mease stretch cooler, green stripes,Holley 12-903 FP(hotwired), Accufab reg, RJC PowerPlate & boost control, Comp 260H-12, Vigilante 3200, alum bumper supports & brake drums, S-10 cylinders & long shoes, ATR 2.5" SS duals, sway bar & cold air kit, Dynotech alum shaft, BFG Drag Radials, 4 GTA fronts(nice & light), Scanmaster 2.1 / "I refuse to tiptoe through life, only to arrive safely at death"!! Last edited by rodman99999 : May 10th, 2008 at 07:50 PM. |
I was going to quote your first post, but again, too much wastegate spring pressure will always equate a boost spike.. Its all in fun working on these cars, its a stock turbo, so its not the puck hole that is the problem.... I really think, start with the basics, rjc valve from rjc? is it a heavy duty waste gate by accident? Is the diaphragm leaking? no leaks on the new 7/32 hoses for the valve? Just trying to help, i try to help.... BW
OHHH- Stock turbo? I think Quick6 is right in it not being the wastegate hole. Aren't you supposed to adjust the actuator rod so it just has a slight shake to it(just barely holding the puck against the housing)?
'85 GN- sold 'cause it had t-tops / '87 Turbo-T: TA-49, TH 3"DP, Mease stretch cooler, green stripes,Holley 12-903 FP(hotwired), Accufab reg, RJC PowerPlate & boost control, Comp 260H-12, Vigilante 3200, alum bumper supports & brake drums, S-10 cylinders & long shoes, ATR 2.5" SS duals, sway bar & cold air kit, Dynotech alum shaft, BFG Drag Radials, 4 GTA fronts(nice & light), Scanmaster 2.1 / "I refuse to tiptoe through life, only to arrive safely at death"!! |
Thanks, guys.
Great advice. Quote:
The nudge to the tight side is a great idea. Thanks mcasteel! I can relate to busting bolts....When I was removing my driver side header a couple months back, I busted one of the cross over pipe bolts in the header, so I had Lou drill it out for me when he was welding up the crack at the #5 primary. When I was prepping the bottom end of my ZZ502, I opened up the oil pump to prime it a little by dumping some EOS into it, when I was putting the cover back on, I over torqued and snapped one of them cover bolts so had to take the pump out and go get the bolt removed.... Quote:
Yup, it's a new RJC controller straight from RJC. Quote:
I squirted a little penetrant on each elbow bolt and also on the down pipe bolts. I'll let it sink in for a day and go back and soak it again tomorrow and probably once or twice more this week. If I get a chance next weekend, I'll pull the elbow and port the WG hole. I don't think I'll port the whole housing just yet....It's my understanding doing that will improve the flow to the point of adding 1-2 more lbs of boost...I'll wait until I get alky on this car before I start trying to add more boost. Cali's 91 octane just aint very boost friendly.... Thanks again guys! Oh...are there gaskets between the turbo and exhaust elbow and between the exhaust elbow and DP?
Tim,
Ya know I never checked the numbers stamped on it but I would be its not a H/D after sleeping on what happend to me last night, IM drawing conclusion that I had a major spike last night and boost went from what i launched at to 25#s in one sweep. Although I have my boost set at 24# max, it shot with nothing inbetween and about killed me |
are you using an stock actuator or an HD acuator
87 GN RJC girdled block motor by Cotton's PT-67, 60lb mototrons,, Pat's 10" 3500 stall PTE superstock loc. IC, DIY Alky, 210/210 roller champion ported irons/Intake Turbo Tweak chips, RJC power plate 11.8@113mph w/old combo, stock eng. TA49 69' Camaro SS 355ci, 4spd, 3.73 12b alot less wires, but sounds great |
