| General Turbo Buick Tech Technical discussions |
Tapping Noise
I have a T&D Rocker setup with my roller cam (212/212) on an 87 GN motor. Someone told me that I would hear a little rocker noise when I switched to a roller cam and these rockers. It isn't very loud.
Here is a video of it Turbobird Runs! - Video Fast forward to about 30 seconds in. I was just curious if this is normal with our motors when switching to roller rockers or if they need to be adjusted. Thanks.
![]() '91 Firebird - LC2 3.8, 6776S Turbo, Alkycontrol, S60 Rear, ProBuilt 700 467rwhp / 464rwtq @ 19lbs |
| Sponsored Links |
Slight tapping noise on mine too nothing load.
84GN with RPE built 109 0.30" over Forged pistons BB6776HR, Comp 218/212 Roller Iron Champion ported heads TD 1.55 Rockers Ported Intake & Plenum 62mm TB,RJC plate,3"THDP,60lb injectors TT chip,Cotton's FMIC,Mark's Cold Air Kit, Protorque 2800 for the street ALKY, RJC boost controller,Electric Cutout,Translator, LS1 MAF |
Can't really tell from the video. It's going to sound a bit like a sewing at idle machine, but proper adjustment of the rockers will help. You'll get used to it.
218/212 Comp roller cam, Cat stroker, RJC gridle, CPT66BB, PTE Stock Location IC, Champion iron, T&D roller rockers, 60# Mototron injectors w/Turbotweak chip, Monroe-ported throttlebody, RJC Power Plate, Jimmy-built trans w/Precision Vigilante converter, ATR SS dual exhaust, ATR rear sway, BMI upper and lower control arms, Edelbrock Performance shocks, Razor alky, Tinman cold air intake, MT street radials. |
What preload did you use on the lifters?...when adjusting T&D's a full turn of the adjusting screw is .050...I always do 3/4 turn which is around .037...my motor with roller and T&D's is pretty quiet...
Scott 87 GN - Street/Show Car (orig owner - 41K miles) 87 T - Street/Race Car(10.26 - 133.49 MPH) |
I do a half turn to .025
Put at least another 1/2 turn on your adjusters. Mine were pretty loud before I added more preload. It's down to a slight tick now and I'm at 1 full turn.
1987 GN Astroroof Precision 6131BB, BGC 23 row stretch IC, 60lb inj., 212/212 Comp roller cam, T&D rollers, TT Akly chip, Razor's Alky kit, Billet main caps, Speed-Pro forged pistons, port & polished heads & intake, 70mm T/B, Edge 10" 3000 stall L/U, trans built by mikestertwo with PTS parts, 3" THDP, Poston headers, PTS aluminum radiator, etc., etc. |
I think that .050 is too much preload. .025 to .035 is plenty.
I had a similar noise with my flat tappet cam using T&D's. In my case, it was too long of a set of pushrods. It caused my my adjusters to ride up high on the rockers, and that allowed the adjusters to contact the valve covers slightly, causing a noticeable tapping as you might imagine. Getting the correct pushrod length dialed in eliminated the problem. Counterman.
I'm at 1/2 turn rather have the slight noise than other issues
| Bookmarks |
| Tapping Noise | 86Nick | Engine Tech | 1 | March 17th, 2008 04:56 PM |
| Engine tapping noise - plz help troubleshoot | robk46 | General Turbo Buick Tech | 24 | September 11th, 2007 07:53 PM |
| Tapping noise in trans | 84HAGN | Transmission Talk | 8 | July 30th, 2007 02:02 AM |
| Tapping noise after 206/212 cam install. | mazdatech78 | General Turbo Buick Tech | 23 | September 9th, 2005 05:18 PM |
| tapping noise,please help | turbo grey | Transmission Talk | 0 | September 17th, 2003 02:13 AM |
