Old March 10th, 2008, 04:08 PM
Stainless headers
Hello, Got a question about headers. Are the headers you see on ebay for anywhere from $125 to $150 any good? There must be a dozen sets of them. Can they really increase your horsepower in a fairly stock application? Will they work with a 3" downpipe without crowding and without alterations? I got a bad header on the passenger side and was thinking about replacing the headers with a set of these. I don't expect to do any major race applications. I have 33# injectors, pitbull chip, and 14" K&N air filter. Your opinions are very respected.
Old March 10th, 2008, 04:28 PM
you need to search a little harder on these forums!
REVolution Racing
We are the next generation
God drives a Turbo Buick
Some sort of snail shell fed by some pipes, cooled by some air, inhaled by a large mouth, deep throats well, drinks lots of gasoline,occasionally enjoys liquor, makes massive explosions, its computer thinks its fast, exhales through the alaskan pipeline, fat shoes, 4x4 flares, 4 different colors... wakes up the neighborhood.
Its a buick... its luxury!!! ... with 120+ trap speeds
Old March 10th, 2008, 04:29 PM
not unless you can weld and are willing to spend the time to make them fit properly
actually theres more than that and they all need work
if you can get them to seal up they would be better than stock cracked headers but otherwise no, stock work just fine into deep 10s
the ebay headers are an ATR copy so if your 3" DP is built for use with ATR headers then your pipe should work but for all others and stock elbow type downpipes no they wont work
passenger sides are the easy ones to find without cracks , post up in parts wanted or search the parts for sale
if you're just running pump gas lose the pitbull chip before you lose a headgasket or worse
paul...magnabuick.com NJ rep
86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1
1.42 6.57 104.9 10.4 129.8
now trying out lonnie diers th400 w/tbrake
87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57
fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver
all runs on quick chek 93 octane
alkycontrol.com progressive meth injection
turbotweak.com
Old March 10th, 2008, 07:28 PM
DCVING 6's Avatar
Stock headers can take you into the 10's without modifications. Stick with what you have and put that $150 somewhere else.
Glen
1986 GN- Garage Art.
Old March 10th, 2008, 10:58 PM
turbo nasty's Avatar
BOOST SUX MY WALLET
My bud has been round and round with 2 different sets of e bay headers ATR/KB style. Cut, weld, bent, leaks, v band ..you name it. He put the stockers back on and no worries.
He bought the Ebay headers since he was new to the GN's and thought it would be a great upgrade and the price lured him in.
USAF POWER PRO
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe.
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list still has warranty till 2010.FOR SALE
Old March 11th, 2008, 06:57 AM
boostingbuick's Avatar
1984 GN Frame off resto. Full wieght with spare tire and jack. All opitions are in working order.
87 Harness and ECM, "484" block 4.1 J&E Pistons, Full floating stock rods, stock crank, Girdle, CHAMPION GNr heads fully ported, T&D shaft mounted, Comp 218-212 roller, 70mm tb, sheet metal upper, 4 inch inlet pipe, Turbonectics 72mm BB q-trim 4 bolt turbo, P.S. intercooler, atr headers, 3.5 dp, custom dual 2.5 stainless exhaust with utralflows
BRF 200r4 built with alto reds, Billet servo, Transgo shift kit, Forward drum, CK's 3600 9 inch nlu, custom pan with rear sump.
GTA fronts with LS1 front brakes and Baer rears. Chrome moly custom upper and lowers with 3.42 gears and moser axles.
Old March 11th, 2008, 07:00 AM
Ebay stainless headers
Thanks to everyone that had advice about the headers. I knew you all had experience.
Old March 11th, 2008, 07:02 AM
How does that answer my question about ebay headers?
Old March 11th, 2008, 07:05 AM
Than you for the reply and good advice
Old March 11th, 2008, 07:26 AM
The pitbull chip was in my car when I got it and after first joining this site I saw that It wasn't good for my application. Do you recommend the TT-chip? Or what chip would you recommend and where is the best place to get it?
Old March 11th, 2008, 07:27 AM
devils advocate
I seem to remember the "original" guy who bought these headers, modified them to fit BUT, picked up 2 mph with no other changes in the 1/4. Soooo, if you have the time and skill, 2mph is a good improvement over the stockers Mine are literally hanging on my living room wall
Ross
86 SVO. Spearco, p/p big valve head. et 13.7 @ 103(2.2 60')
86 GN 55K. ESP front mount, TA-49,SMC progressive,Jay Jackson 62 mm tb, Lubrant chip, 42.5#,THDP, Hooker cat back,RJCPP. 12.1 @112(22psi) on drag radials.
91 Syclone. 27K, all stock.
00 Wrangler, daily driver.
86 Sportster (stretched/raked/rigid)
Old March 12th, 2008, 08:12 AM
eric marshall
TurboTweak Home
turbotweak.com
new headers in stainless? turbocaddy1982 Engine Tech 2 August 19th, 2007 11:23 AM
Who wants Stainless Headers? quicker6 General Turbo Buick Tech 54 April 20th, 2007 12:01 PM
stainless headers beermoney Parts for sale 9 April 16th, 2006 06:03 PM
Stainless headers V6POWER General Turbo Buick Tech 8 November 15th, 2005 03:03 PM
Does anyone make stainless headers with stainless flanges? Turbo1dr General Turbo Buick Tech 4 June 27th, 2005 12:45 AM
