Old February 10th, 2008, 08:25 PM
GOT JCE's Avatar
Once you go Black........
Emissions Test in CT
I just recieved notification of my emission test.My cat has been gutted and she runs fairly rich. I know I will have to lean it out but should I also get a TT emission chip? Or just throw a Cat on it and be done with it since I also have an Electric cut out I was planning on throwing on. For some reason I thought this car would be exempt being over 20 years old.
1986 GN bought it completely stock with Ttops.Added kirban 100lb springs,walboro pump,Accufab FPR,TE60,big frontmount,scanmaster,Gen2 Translator,LS1 MAF,hotwire kit,65lb injectors,Art Carr 3000 non l/u converter & shift kit,RJC power plate,Razors Alky Kit, 3" DP,hooker 2 1/2" dual exhaust with electric dump,HD adj wastegate,Cold air intake,TT alky chip,Poly motor & tranny mounts,heated o2 sensor,lowered 1 inch,airbags,running 28lbs boost on M/T 275/50-15,interior totally redone,all the frame braces and back seat brace,
1989 TTA #830 Leather T-tops 10,509 miles stock
1989 TTA #1001 Leather T-tops stock
2005 Ram 1500 Hemi tow vehicle
1998 Lexus GS300 daily driver
Old February 10th, 2008, 09:04 PM
GNBRETT's Avatar
Helms Deep in Debt
Ur confusing inspection with emissions bud I think. All that really matters is what comes out the exhaust and registers on the computer which are online and linked to CT DMV to cut down on fraud. Fraud still occurs of course but not as often.
I know people who worked at emissions that payed their houses off in a few years from the shaddy things that went on there resulting in pay-offs from those that could not pass. Depending on where you go they will look for a cat but unlikely they will inspect whether its gutted or not. There are other places to go vs. DMV.
Brett
Otto's Performance Tuning. (Specializing in F.A.S.T)
Bridgeport, CT.
(203) 521-6003
1987 Black Turbo T, Stage II, F.A.S.T XFI, 76mm Turbo, Champion GN1-R Heads, Champion Race Ported Intake, PTC Converter, MSBC-1 Boost Controller, RJC Polished FMIC, RJC Pulleys, RJC MAF Pipe, Godzilla BOV, Rzrs Dual Alky Kit, Lonnie Diers Billet 2004r w/Elect TB, HR 224/224, ATR's, 3 in DP w/ Tial WG, Oil cooler, Deep Oil Pan, 83# Lb. Inj, Aeromotive Fuel, Callico Coated Bearings, March Perf. Billet Alt, Girdle, Savitske Stainless Upper/Lower Control Arms & Ball Joints, Metco Upper/Lower Rears, ATR Sway Bar, Aerospace Brakes Front/Rears, SBC Springs, Hydratech, 3.5 in Custom Exh, 6 Point Chromoly Bar, Custom Bogart Welded R/T's w/ MT DR's, Bilstens, Working A/C, Eclipse. Tuned by Otto.
Old February 10th, 2008, 10:14 PM
You won't be exempt till it is 25 years old. Put a stock chip that matches your injectors in it and put a cat on it (it will fail nox with no cat). Tell the emissions station you have studded snows and they will do a two speed idle test and you should pass.
Old February 10th, 2008, 10:59 PM
Wink
Hi,
Yes, unfortunately, without a CAT,you wont pass emissions.Standards vary from state to state,but generally, you will have to beat 1% CO and be under 150PPM Hydrocarbons to pass.Only a converter can get it that clean. CT is a pretty state,so I understand where they are coming from.Here in Texas, only certain areas are tested,like Houston, where I live. My Regal just passed the limit, at 25 years old,but I'm still running the cat,trying to run clean,and fast,if possible. Good luck with your testing!
***83 Buick Regal TType***
'87 drivetrain and all associated stuff.
Fresh rebuild with Stock block,ARP studs installed with stock caps,align bored to ensure proper fit.Sealed Power forged pistons,stock rods,resized for ARP bolts,stock heads with low cost stainless valves,206/206 Comp flat tappet cam, TA49 turbo,009 injectors,hotwired Walbro 340, Hooker cat back exhaust,K&N filter in stock airbox,Spearco water injection, pretty stock otherwise.
***89 Pontiac Turbo TA***
Walbro 340, Flowmaster muffler, otherwise stock.
***96 Buick Riviera***
3.6" blower pulley,otherwise stock.Runs 15s on a hot day at 4000 plus pounds weight, with the A/C on.
***84 Jeep Cherokee 2door 4x4***
87 Turbo Regal motor,thm700R4,rusty wild child,definitely a restoration awaiting progress.
Old February 11th, 2008, 12:13 AM
salvageV6's Avatar
Lightbulb
Definately get a cat. on there for the test.
I hook up my EGR pulser as well that runs the solenoids, since my regular TT chip and Extender Extreme chip have no EGR code in them so that helps pass the NOX test, a functioning EGR greatly helps NOX.
They will look under the car for a cat. and they can't tell it's gutted and probably won't care much even if it fails.
I guess if you have studded snows you may get a different test but I doubt they won't look at the tires first to check.
An emissions chip is a good idea if the car isn't running all that great with a regular one, especially if it has EGR code in it since most chips don't now, and the car runs better.
Change/clean the plugs and oil also if it needs it.
Old February 11th, 2008, 06:52 AM
TR Custom Parts's Avatar
Mark Hueffman - Owner
I have a cat that I throw on the GN every two years for about the 1 hour it takes to drive to emissions, get tested and drive back home. No other changes to the car and it always passes.
Mark Hueffman - Owner of TR Custom Parts
1987 GN - List of Mods - http://www.buickgn.com/Features.htm
mhueffman@snet.net
VISIT OUR WEBSITE BY CLICKING THE BANNER BELOW.
Old February 11th, 2008, 07:28 AM
1986 Grand National
I went though this two years ago. The registration came in the mail, but it said I had to get the car emission tested before they will renew (at the time the car was with out a tranny). So I sent a check to the DMV for the registration. They cashed it. When I got the tranny, I had to get temporary plates to bring it over to have it tested. I ran Eric’s Emissions chip, fuel set at 38#, But I did have a gutted cat. So it failed HC test (just barely). It failed, but right after the test, I brought the emissions test report over to DMV with my paid registration. And they renewed it. It had to be tested. It did not matter that it failed. It just had to be tested.
I guess you have the 30-day window for a retest, which you are considered “in compliance”. But I did get it renewed for two years. I never brought it back for a retest.
I am also due again this year.
Where in CT are you? I am in Guilford.
God Speed, Fred Carrado Jr.
"fc227@mindspring.com"
"http://www.mindspring.com/~fc227/.htm"
203-453-6571 ext 342
Moroso Performance
86 GN
Best ET: 12.252 @ 108.56 MPH
C16 & 20# of boost
TE44 turbo , 009 injectors, 2.5" downpipe , stage rite trans brake. 3K stall edge converter with lockup. BFG drag radials. comps 206 cam, ported heads.
Old February 11th, 2008, 07:44 AM
I would get a Emissions chip from TT for the 65's
If you need to borrow stock pipe setup with a new cat I have the setup.
84GN with built 109 0.30" over Forged pistons
BB6776HR, Comp 218/212 Roller Iron Champion ported heads TD 1.55 Rockers Ported Intake & Plenum 62mm TB,RJC plate,3"THDP,60lb injectors TT chip,Cotton's FMIC,Mark's Cold Air Kit, Protorque 2800 for the street
ALKY, RJC boost controllerElectric Cutout,Translator, MAF LS1
Old February 11th, 2008, 02:03 PM
GOT JCE's Avatar
emissions
I guess I will be buying a 3" high flow cat and I have the dump pipe/electric cutout ready to be put on.So I guess I will also buy the emission chip from TT. I sent in my renewel and my check already and recieved a notice saying my registration was payed for but not renewed until my emissions test was done.It's going to be a pain in the asz since the cat is welded right onto the down pipe.Oh well,complaining isn't gonna make it easier. Thanks for the responses. As for my location I am in Wolcott.
Old February 11th, 2008, 02:08 PM
GOT JCE's Avatar
Online
It's funny I just scrolled down this thread and everyone is online!!! Doesn't anyone in CT have a job. By the way I am at work.
Old February 11th, 2008, 02:34 PM
Remember that cats are designed for the engine - if they are too big they won't get hot, and if they are too small they will be a restriction.
If you are only installing it for the sake of passing emissions testing, then you're gonna pull it back off, I would err on the side of "too small" instead of "high flow".
-Bob C.
Old February 11th, 2008, 10:01 PM
Both of my cars pass with a cat on them. A running test (on the dyno) can be unforgiving, that is why you should test in the winter months (nov-apr) when you can do a two speed idle test. There are ways to help a borderline car pass if you fail your first test. Good luck.
87 gn - 125k bone stock daily driver
87 gn - 91k under construction for 1320ft trips
96 mustang gt - wifes car
02 ram2500 - tow vehicle
Old February 11th, 2008, 10:07 PM
Long Duc Dong
Trader Rating: (20)
AJ, you can borrow my community catalytic converter if you want. I have the elbow, dp, gasket and all hardware ready. All you have to do is remove yours and install mine. Its worked on at least 10 dfferent TR's around here. The block learn will need to be at or near 128 at the testing speed. It should not be below 128. The engine needs to be hot for the test. Request that they leave your car idling while setting up for testing. You need to keep the cat as hot as possible to work at its peak. Additionally you will need egr function. I have gone through with both of mine and no problems at all. Dont attempt it without a cat. The car is exempt when the model year is 25 years old.
Blue GN: Old combo 559whp/706wtq. New buildup to come with race ported GN 1 heads and intake .
Black GN:Stock 134k shortblock except cam ,KB 70 mm TB and plenum, ported irons 1.77in 1.5ex, RJC head gaskets, ported stock intake, 212-212 comp roller, 1.65 T&D's, RJC powerplate, 1" plenum spacer, 83 lb/hr injectors, double pumper, FAST XFI, G-Body FMIC, welded ported stock manifolds, 3.5 dp, T66BB GTQ, Dusty PTC 9.5", 200 4-R by me with billet shafted forward drum, input, and planet. 8.5 rear with Auburn and 28 spline Moser axles. Time with old combo 10.88@126mph. Stage II coming soon .WORK HARDER! THOSE ON WELFARE DEPEND ON YOU!
Old February 11th, 2008, 10:08 PM
Long Duc Dong
Trader Rating: (20)
Sadly i was at work
Old February 11th, 2008, 10:12 PM
Long Duc Dong
Trader Rating: (20)
-Bob C.
Nothing works as well as an OEM cat in my experiences and it has more cross section and length than any of the high flow units. Nothing even comes close to a known good stocker. There is no cheap aftermarket high flow cat that will flow the exhaust volumes an engine over 400 hp will be creating without causing a big restricion.
Old February 11th, 2008, 10:31 PM
Bison is correct,use a stock/factory cat and make sure the cat is HOT. I have a similar setup that I bolt on my cars every two years and take them off and put it in the shed. I left my egr on both cars for this purpose since at WOT they are not in use anyway. Lucky for you guys you can do this at work
Old February 12th, 2008, 12:28 AM
salvageV6's Avatar
Lightbulb
I never had any trouble passing with my Random Tech. Hi-Flow 3" cat.
Use what fits your exhaust system.
I doubt they are gonna leave it running in the winter but a 180 stat. may help you, I have passed all the tests with the 160 however.
A decent good running chip helps more than anything, dumping fuel for the sake of dumping fuel may work well on race cars, but did nothing but ruin my gas mileage and more quickly foul plugs going back to the kenne bell chip days.
EGR helps reduce NOX a ton.
If you need any help with your EGR I can loan you my box that gives 35% EGR pulsing over .55 volts TPS.
It installs rather easy inline to the TPS connector and to the factory EGR power and connectors.
They don't seem to care when I use it on both cars, assuming you don't have a chip with EGR code in it like an emissions chip would have.
If you have a good functioning EGR that would help.
Old February 12th, 2008, 12:56 AM
johnnyttype's Avatar
i know you guys are saying 25 years before the car is exempt, but i was wondering if CT is the same as maryland, in that since they dont make the regal anymore, discontinued, it is only 20 years til it is exempt. this past summer i put historic tags on my 86 ttype and have no more emissions to worry about just wondering?!
86 T-type: 234ci., 206 roller, o-ringed ported heads and intake matched, 6152E turbo, 3in. dpipe, poston headers, 3in. torque tech exhaust. walbro 340, hotwired, 60lb inj., rjc powerplate, kn filter, Lt1 Maf w/trans., qboost controller, forged pistons, rods and crank. billet center caps. adj. fpr., 3400 L/U PTC converter(NEW). 11.824/4mile @117.2, 1.82 60ft, 21-22psi. street tires and 93 oct. razor alky! my daily driver!
