Old January 15th, 2008, 09:03 AM
TRCM Author
Looking for experiences with Double Pumpers
I'm kicking the tires on buying a Double Pumper. I'm fairly sure that I'm right on the edge of what my single Walboro 340 can handle. The car can slip into the very high 11's on my street chip (Extender Extreme) now using pump gas, and I've never even tried the race chip (another EE). I have the boost set as low as it will go (18 psi) and still see 1600+ EGT's (and then quickly get out of it). I never think to check the A/F ratio on the LM-1. To boot, the sending unit in mine is so bad, it will read "10" when I first turn the key on [which seems fairly close] but then when I start the car it shows "F"
Anyhow, I'm trying to talk myself into this. Part of me thinks that this setup is tricky to tune, causing a rich spike as the 2nd pump kicks on. Those that run this, please chime in on your experiences. Also, what PSI do you choose for the 2nd pump? This is a 99% street car. Mods in the signature.
Jack Bilger
87 GN 11.774@113.55 (street chip w/ full exhaust)
GT67, 83's
RJC Intercooler, AD Power Plate, Girdle, Valve Cover Extenders, Pulleys...
Old January 15th, 2008, 11:41 AM
RUQWKNF27's Avatar
Got one here! 2nd pump starts @ 15lbs. No problems in 1.5 yrs!
http://www.cardomain.com/memberpage/637073/2
Current pics:http://www.turbobuick.com/forums/sho...d.php?t=168306
87T-Te-45a/V1/72"s/DP/Girdle/Je's/70TB&DH/3400 911/CenturyTrans/PortedIrons/TAFrontCover/4"SingleShot/4"CAI/Ari.GN Rad/Hrparts.upsanlows+ more...10:82@124 @23LBS With 1.73 60ft more http://videos.streetfire.net/video/A...BA3DA9822F.htm New Exhaust>>
http://www.turbobuick.com/forums/sho...d.php?t=194282[url]
BURNOUT http://www.turbobuick.com/forums/turbo-videos-picture-library/201365-small-burnout-other-night-lowes.html Razors Dual Nozel Alky via 26 lbs!
Old January 15th, 2008, 10:01 PM
like said the second pump is run off a hobbs switch activated by boost and comes on at 15# boost or so , you can get an adjustable hobbs and start it even sooner , mine is an adjustable hobbs
as for 1600 egt thats where mine usually goes a little faster , i normally run 1585 with an 11.2 AF , Im running wideband correction so second pump turnon really isnt an issue
you shouldnt need duals yet at your level . single pump should support 600hp and should have no problem supporting mid- high 10s
normally you dont need to consider twins till 10.5
with alky a single 340 has gone 10.10
could be other things causing high egt
too rich - fuel being burned in the exhaust
do you see 1psi per 1 lb boost increase in FP when under boost ?
with 45 base FP psi (line off) you should see 63 psi FP(line on of course) at 18# boost , and it needs to stay at 63
oh and 83# injectors and that turbo you need dual pumps (or external race pump) to reach their potential ,about the most a single pump will support to 100% duty is a 55# injector, but even with 55s and one pump you could be doing mid 10s unless you're way rich on the fueling
paul...magnabuick.com NJ rep
86gn bone stock shortblock ,ported irons ,71Q 75# ,212/208 flat tappet,CAS V2,ATR 3" HKS, ATR dual340m , 200-4r stageright, AC9"NL , TTWB 6.0, razor dual,msbc-1 ,LC-1.. 1.43 6.57 102.8 10.4 126.9
now w/ lonnie diers th400 w/brake, vig conv ,cometics 1.48,6.62,103.4,10.46, 126.9
87GN , duttneck, hipro,, 62TB ,PTE65 + PP, protorque 10.5" 2800, hooker duals, razor alky (dual), TTchip.
stock unopened w/TA49, 50#..1.57, 11.45, 117
now 030, steel mains, dutt cam ,msbc-1 ,LC-1 ,Cottons 3"DP Tial gate ,ported irons/intake ,turbosaver ,TE44,75#inj, 4" zo6 maf , bad 60' .1.63 .92.91 ,118.36 11.50 22psi
all times on 93 octane
big thanks to
julio at alkycontrol.com
eric at turbotweak.com
Old January 16th, 2008, 12:11 AM
Powered by Murphy's Law
Yep, my single pump isn't done yet, no wideband issues or leaning out past 140mph, this is with alky though. If you are running racegas and are over 130mph it would be a very smart move to upgrade...
86 TR
Leather,column,astroroof
T-netics 66BB S-trim, ME-R
Razor dual nozzle alky, 75lbrs, Powerstroke IC
210/215 roller, Forged stroker, TA headers, HR Bar
Lonnie Diers Stage 2, PTC 9.5 N/L
10.71 at 129mph 6.9 at 102mph 1.67 60ft
10.79 at 114mph 6.8 at 102mph 1.58 60ft
3700lbs w/driver
Old January 16th, 2008, 08:24 AM
GSX-PKV's Avatar
We have an ATR Doubel Pumper and have had no problems at all in 5 years of mostly street use.
WE4-Original owner street car- 10.71 @ 126 on DOT radial tires, through the exhaust on 93 octane w/ice cold AC - GN1 heads & intake, Garrett GT67 turbo, roller cam, JE pistons, PTE front mount, Double Pumper, Alky, complete stainless exhaust. Backup car: A yellow 70 GSX, Stage 1, 4 speed car.
Old January 16th, 2008, 09:54 AM
daviss's Avatar
I've got one also and it's hooked into a Hobbs @ 15psi. Wired in an led in the pillar pod to know when it comes on. Now with the alky and the shift light, when ever I get into boost, it looks like christmas.
Shouldn't have a fp spike when the pump comes on. Pressure will still be regulated. Just keeps the regulator fed so you don't go lean. It was on the car when I got it so I haven't messed with it but I wouldn't see the need for your level assuming your still seeing adequate fp with reference to boost.
I also had the relay go bad for #2 pump and still went mid 11's.
Hope this helps
Steve
'84 Regal w/ '87 combo- TE-60, 009's,ATR headers/DP,Ebay FMIC w/homemade pipes, Razor's alky kit, Autometers everywhere, 375rwhp/420rwtq @18 psi and no tune. New best- 11.34 @ 120. Guess it's time for a roll bar.
New addition: 3400 9/11 (I think I'm gonna break something soon!)
New toy: 2007 Yamaha Rhino 660
Old January 16th, 2008, 10:49 AM
Razor's Avatar
Forum tech Advisor
Single 340 and alky have already gone 9.9 at 138.
For 120 MPH Buick.. waste of money.
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
http://stores.ebay.com/ALKYCONTROL_W...eNameZl2QQtZkm
Old January 16th, 2008, 10:52 AM
TRCM Author
I do have alky injection. I'll try to get the car out for a run soon to check FP psi, and A/F ratio.
Jack Bilger
GT67, 83's
Old January 16th, 2008, 10:54 AM
Razor's Avatar
Forum tech Advisor
Then aside from the bum sender.. I would say leave things alone.
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old January 16th, 2008, 11:04 AM
You sound like you have a digital dash, and if so, then the double pumpers sold out there will not work as fas a sending unit is concerned. I have not been able to find a new digital dash sending unit anywhere. If anyone else has an answer, please chime in.
Ken B.
Old January 16th, 2008, 11:55 AM
TRCM Author
Someone wrote a detailed pictorial guide on how to fix the sending unit. I have it printed out at home, but have been too lazy to try it. That's strange that GM would use 2 different sending units. I do have a digital dash.
Jack Bilger
GT67, 83's
Old January 16th, 2008, 02:22 PM
Survivor
Ken,
Even John Spina @ Casper's Electronics
doesn't have one and/or knows no source for one?
Old January 16th, 2008, 02:27 PM
Survivor
Question What Would Be The "Ideal" Method & Device For 2nd Pump Activation?
Beyond the Hobbs switch,
What are the various other ways to trigger the 2nd pump? TIA!
Old January 16th, 2008, 02:46 PM
Jack, Give me a call. I have some experience going much much faster with a single pump. I've also been able to repair a few sending units.
Scott Atkinson / White 87T 109: Performance Transmissions LV; ALKYCONTROL.com; MAXEFFORT "R"; Full Throttle Speed
Old January 16th, 2008, 06:00 PM
What about the second pump on a manual switch? Just turn on the switch after the burnout?
I have a fear of a Hobbs switch failing. Don't know why...
Chris Campbell
Engine Machined @ Jackson Cylinder Head by Geoff Burroughs
Engine Built @ Alexanders Automotive by Randy Alexander GN>Girdled 109 , TRWs std bore , 218/212 roller , T&D 1.65s , 70mm TB/plenum , ported irons, intake and exhaust (Randy A) , PTE FMIC , te45a , stuff to make it all work.....10.84/125-stock MAF
TurboTweak chips...thanks Eric!
06/01/08 update...CruzMissile in the works....
TTA..."wifes" car
Old January 16th, 2008, 06:20 PM
Slow91z's Avatar
Turbobuick.com Helper
Trader Rating: (6)
The problem with that is if you manually turn on the pump at idle your fuel pressure will run wild...Car will go rich and best case scenario will spool worse.
Collin Hundley
87 GN - 6.85@99 1.47 60'
86 T-type Primered with bench seat OH YEAH!!!!! 11.70@116 with a sucky 60' But the car has gone 7.03@96 in the 1/8th with a 1.47 60' - Parted out
Old January 16th, 2008, 06:53 PM
The regulator can't control idle fuel pressure with both pumps on?
Chris Campbell
TTA..."wifes" car
Old January 16th, 2008, 06:57 PM
Slow91z's Avatar
Trader Rating: (6)
The problem isn't the regulator it's the return line, it's too small.
This is the whole reason for the 2 pump setup is so you can turn on the 2nd one at higher boost when you are using more fuel so less needs to be returned to the tank...That and it works nicely with the stock tank...Other wise it would be easy to just throw a Big ass pump on there and roll.
Collin Hundley
  #19 (permalink)
Old January 16th, 2008, 07:04 PM
Slow91z's Avatar
Trader Rating: (6)
Oh BTW I'm sure you could run the 2nd pump off of a RPM switch and a relay if you really don't like Hobbs switches.
Collin Hundley
  #20 (permalink)
Old January 17th, 2008, 11:27 PM
