Old April 6th, 2007, 07:31 PM
scot w.'s Avatar
27psi on pump gas!
Trader Rating: (6)
GM testing Methanol in T-types?
A good friend of mine has a 87' buick regal that was said to be a GM test car for methanol. it's got a huge 30gal stainless steel gas tank with in-tank dual pumps and -8 feed/ -6 return lines and also had a box under the hood on the drivers side that was wired into the fuel pump that went to the injector harness for use with methanol, i guess you hooked it up to use methanol and then un-hooked it and pluged the injector harness into the stock plug for use with reg. gas. ALL FACTORY! Any info about these cars?? please let us know. Thank you! Scot w.
1986 T-Type, White, black out trim- TE-44, streched S/L Intercooler, 55lb inj, 9" Art-Carr N/LU conv.,Walbro 340, Hot wire kit, RJC powerplate, 3" TH down pipe, ATR Stainless Steel 3" dual exhaust, Southside uppers & lowers, Carrilo rods, JE forged pistons, powdercoated & polished GTA rims.. Daily driver!!
1986 GN-set up for (Autocross/roadcourse/drag). 6.76 @ 103.8mph 1/8th on 93 pump gas & Alky. Sold..
Digital LED Tail lights
Contact me for info
www.alkycontrol.com
www.rjcracing.com
www.fullthrottlespeed.com
Old April 6th, 2007, 07:40 PM
garyk1970's Avatar
Captian Electrical
ive got one.where all five blue/blue like mine??
1 OF 5 METHANOL TEST CAR
LOTS OF BOLT-ONS TO MAKE IT GO SLOWER
SOME INFO ON MY CAR;http://www.turbobuick.com/forums/gen...l-t-types.html
Old April 6th, 2007, 07:57 PM
scot w.'s Avatar
27psi on pump gas!
Trader Rating: (6)
So there were only 5? and all GM test cars? My freinds was blue! 60-40 bench, colum shift? his is silver now with a custom interior and ALOT of up-grades!!! . here is a pic.
Contact me for info
www.alkycontrol.com
www.rjcracing.com
Old April 6th, 2007, 08:04 PM
garyk1970's Avatar
Captian Electrical
yep.the only options mine has is tilt,rear defrost,ac. no cruise p/w,pdl,etc.
factory lightweight(fancy way of saying they were ordered striped)
Old April 6th, 2007, 08:06 PM
scot w.'s Avatar
27psi on pump gas!
Trader Rating: (6)
factory lightwhieght
Exactly the same as his!
Contact me for info
www.alkycontrol.com
www.rjcracing.com
Old April 6th, 2007, 08:09 PM
garyk1970's Avatar
Captian Electrical
the story is they were ordered by the gov for the methonal testing.then donated to tennesse college....auctioned off in 1999? i believe. mine only has 47k miles still.
Old April 6th, 2007, 08:29 PM
Mongoose
Buick was ready to release a turbo & methanol (non-intercooled) car for 85 production.The car was never released for 2 reasons.1) The methanol bottle was in the front of the car (attached to the upper tie bar ) and considered as fuel.I don't think NHTSA liked the idea.2) Engine damage was possible if the user neglected filling the methanol jug.I'm sure GM did not wish to own a "by design" warranty situation.I have driven such cars at Buick Engineering.I thought the methanol car was quicker than the early intercooled cars.We also had a variable geometry (variable vain) turbo driven by a dedicated Motorola controller.My T type is also a factory test car which is light blue with 60/40 bench.
Big Mouth,ls1 maf, xltr+,Ta61,PTE s/l inclr,62mm t/b,matched stk plenum,RJC pp,Razor Alky,port int manif,port cyl hds,shim gaskets (8.55:1),port exh manif,Mease 3" d/p,straight shot,msd 50,KB fpr,volt boost,double pump,stock cam,worked trans,B&m trans clr,9.5" A/C 3000 n/l,HR susp sys,No Hops,boxed uprs & lwrs,bags,trunk braces,etc,etc....
Old April 6th, 2007, 08:41 PM
garyk1970's Avatar
Captian Electrical
that makes three.theres two more out there....maybe reunite the cars at bowling green?
Old April 6th, 2007, 08:45 PM
scot w.'s Avatar
27psi on pump gas!
Trader Rating: (6)
Thumbs up
turbolc2, please post a pic of your test car. it would be nice to see them.
Contact me for info
www.alkycontrol.com
www.rjcracing.com
Old April 6th, 2007, 08:46 PM
any pics of the meth box
87 WE4 stock block,stock crank, stock rods, 224-224 cam,70mm plenum, stock turbo, stock stretched intercooler, stock throttle body, Kenny bell headers, THDP, 009s, adjustable fuel pressure reg, adjustable waste gate, translator plus, 3'' LT-1 MAF, turbo tweek chip, SMC alky, turbo 400, 3000 stall, strength and honor
Old April 6th, 2007, 08:52 PM
garyk1970's Avatar
Captian Electrical
its a 30 gal stainless steel tank.they (gov?)took out the spare tire well to accomadate the larger tank.also,theres an access plate in the floor of the trunk to access the pumps and the sending unit.
Old April 6th, 2007, 09:13 PM
no im sorry i mean the box in the engine bay that controls the meth or really any pics of the set up would be great
Old April 6th, 2007, 09:30 PM
Mongoose
The actual vehicle number of my car back in the day when it was parked outside of product engineering was 46GF143.I still have a parking sticker on the car.For whatever its worth.
Old April 6th, 2007, 10:58 PM
EightSecV6's Avatar
MDBL
Jim Dotson had one, he bought it at the auction after the college was finished with it, I am 99% sure it was dark blue too.
Bill Anderson
Anderson Performance Automotive
8209D Rosebank Ave.
Baltimore, MD 21222
410-282-9335
gettin tired of it...quick!
Old April 7th, 2007, 12:33 AM
Underboost's Avatar
Put Da Evidence In Da Cah
This is pretty cool.
Old April 7th, 2007, 07:28 AM
garyk1970's Avatar
Captian Electrical
the setup
the mods that i understand are;
1)30 gal s.s. fuel tank w/two pumps.
2)large aircraft grade fuel lines.
3) dual fuel filter setup
4)injector impendence (balance?)box that was mounted on the drivers inner fender well.
5)boost/vaccum switch on pass fender well to activate the second fuel pump (i tested mine and it kicks in at 4 psi)
6) nickel plated fuel rail
7) my car had a pad lock bracket riveted to the trunk and quater.
8)methonal only stickers on the gas door and on the gas guage dash bezel.also a note taped to dash not to reset the tripometer.
9) i believe there was some kind of other chip installed-i found one in the glove box,not sure what it is.
10)you can still see "federal methonal fleet" on each c pillar where this decal used to be.
ill take some pictures and post monday if anyone is interested.
Old April 7th, 2007, 08:44 AM
RUQWKNF27's Avatar
My buddy SMOKINTTYPE on this board had one but it got in a accident and was bought form some guy in the carolina's. I think he still has all the meth stuff that came off it. It had the big stainless tank. He didn't like it cause he always had to put lots of race gasin it. Car was blue with bench and column shift. Just like one above. I think he got it in Georgia or Tennesse. I know the guy he got it from had others just like it. He's a big Buick racer "GS's" from what I remember.
http://www.cardomain.com/memberpage/637073/2
Current pics:http://www.turbobuick.com/forums/sho...d.php?t=168306
87T-Te-45a/V1/72"s/DP/Girdle/Je's/70TB&DH/3400 911/CenturyTrans/PortedIrons/TAFrontCover/4"SingleShot/4"CAI/Ari.GN Rad/Hrparts.upsanlows+ more...10:82@124 @23LBS With 1.73 60ft more http://videos.streetfire.net/video/A...BA3DA9822F.htm New Exhaust>>
http://www.turbobuick.com/forums/sho...d.php?t=194282[url]
BURNOUT http://www.turbobuick.com/forums/turbo-videos-picture-library/201365-small-burnout-other-night-lowes.html Razors Dual Nozel Alky via 26 lbs!
Old April 7th, 2007, 09:30 AM
scot w.'s Avatar
27psi on pump gas!
Trader Rating: (6)
Thumbs up
With only 5 built from GM for testing metanol this is looking to be the rarest of regals!! so we got four cars listed here running and one wrecked that's only four out there running!! wow! Jim dotson runs at Knoxville dragway alot maybe i could find out if he still has his, to confirm #4..
Contact me for info
www.alkycontrol.com
www.rjcracing.com
  #19 (permalink)
Old April 7th, 2007, 10:09 AM
