Old April 4th, 2007, 04:02 PM
Formerly Scott4DMny
F-Body Radiator + Dual Spal Fans + Cutlass Radiator plate= THUMBS UP!
So I decided to go with the F-body radiator due to the weight savings and the price. I removed my AC and wanted to get a radiator plate without the brackets for the AC lines. In comes the Cutlass radiator top plate which bolts right on and has two bolts flush against the front so I still have something for mounting my spal fans. The Spal fans I got are the popular 11" dual fans. I put soft weather strip on the part of the fan touching the radiator to keep from any damage. After that is done, I went to Home depot and picked up strips of aluminum that are 3/4 inches wide. They are also very durable. And get this (where my happiness comes from), the holes in the spals line up perfectly with the two bolts on the front of the cutlass radiator plate. The metal strip will lay flat against the plate while fitting perfectly underneath the holes for the fan. I will be using screws with lock nuts to hold the fan onto the strip and will be using the bolts from the radiator plate to bolt the strip to the top. Have yet to get to the bottom but I am sure it will be as easy. I will keep all of you updated with pictures to follow once she is in!
Scott
New '87 GN E85 Pro-Touring project in the works. Getting ready to flex my fuel.
Old April 4th, 2007, 04:14 PM
graza002's Avatar
Nucking Futs
Thumbs up Sounds Great
Please let us know the temp numbers once you run the car. Also can you upload some pics!!!!! TIA
Andrew Graziani
1987 Buick Grand National
Lou's Auto Service
www.turbolou.com
1963 Cushman Truckster
2006 Acura TSX Daily Driver @ 31MPG
Visit My City http://turbo-6.myminicity.com
AND http://turbo-6.myminicity.com/ind
Old April 4th, 2007, 06:43 PM
noahzark's Avatar
any part number and price for the dual spa fans?...do you think the fit will be as good with the f-body rad and the stock rad plate?...are you installing your own high/ow switch/relay or getting it from caspers?...thanks noah.
Old April 4th, 2007, 06:49 PM
Formerly Scott4DMny
I got it from this guy. Part number 30102052.
eBay Motors: DUAL 11" ELECTRIC FAN SHROUD 2800CFM SPAL 30102052 (item 300097622519 end time Apr-11-07 11:38:32 PDT)
I am not sure about the fit on a GN cover, but I can tell you I got my olds cutlass plate for a buck at the local u-pull junk yard. Yes I got the wiring from caspers.
Oh yeah, and I kid you not I got the fan a day after I paid. Now THATS fast shipping!
Old April 5th, 2007, 08:14 PM
S10xGN's Avatar
Finally Roadworthy!
That's a great price! According to my records, I got my SPAL fans from a "group buy" here (sponsored by Dennis King) 05/21/2001 and they were $193.00. I've not ever seen a price lower than that until you posted that auction!
* Russ Selkirk; Port Neches, TX -> GN powered S-10 <- 12.17 @ 115.6 on pump gas!
* * * * * * * * * * * * * Click HERE to check out my thermal-printed stickers page! * * * * * * * * * * * * *
* GN powered '96 S-10 fleetside * +.030 TRW's * steel caps * ARP studs * Comp billet 215°/210° roller * full-port iron heads
* JetHotted "Hayden" ported headers * 50# MSD's * "TurboTweak" chip * PTE 52 turbo * "Jay Jackson" 62mm throttle body
* CAS front-mount IC * "TurboMike" ported elbow: 3" downpipe: 3" DynoMax Raceflow * Walbro 340 * Vigilante 3400 converter
* B&M megastick * Ford 8.8" 3.73 trac-lok * Hoosier QT's * CalTrac bars * Razor ALKY * BsTC controller w/dual solenoids
* and a whole lot of custom-made pieces!
Old April 5th, 2007, 09:29 PM
Register Member
junkyard F-body fans work great, cheap too!!
86 GN Limit-45a, 3"dp, Walbro 340 hotwired, 50lb injectors ,TT street chip,65mm TB, 3.5 MAF, big mouth CAI, Accufab afpr, atr 3" dual exhaust, ceramic coated headers and dp
Old April 5th, 2007, 10:07 PM
Louie L.'s Avatar
Habitual Line Stepper
This is the same combo i was using on my S2 260ci combo . This car never got over 170 even on the transbrake and 2 step at the track. On my best pass listed below , again never got over 170 deg !!!
As a side note , the fans in the pic appear to be spals. But beware there are many knock off spals out there right now. Some can be spoted by the different fan motor backing plate. The others do not have as many vents as the originals.
http://community.webshots.com/user/10secv6
Turbo V8 in progress. Dart 400ci SBC, PTE106,PTE 2000 liquid IC,FAST XFI, Wolfe-TRZ rear suspension,PTC Powerglide and converter
1989 Pontiac TTA
Old April 5th, 2007, 10:14 PM
Formerly Scott4DMny
Thanks for the input Louie. For the record, these are authentic SPALS!
Old April 16th, 2007, 08:37 PM
Formerly Scott4DMny
Here is a pic of the Oil cooler I mounted in between the front mount and radiator (my AC is removed). I custom made brackets using the aluminum strips and "L" brackets from home depot. I used self tapping screws to hold the top of the cooler just under the top of the support. You can also notice where I mounted the tranny cooler underneath the support. See pic below.
As you can see in the next pic, I custom made a mount for the fans using three aluminum strips cut to size. You can see on the top of the fan the two little holes at the top of the strips. Those holes fit the two screws from the upper radiator plate. Across the bottom, I used some GM 10mm screw clips in the holes I drilled to match up with the holes on the bottom. The result is that if I ever needed to remove the fan assembly, I would only have to remove 4 10mm bolts. Even though I measured thoroughly, it appears the radiator support is a bit slanted on the bottom hence the pics. Nonetheless, its not an extreme amount of difference! Will post more pics when installed.
Fm intercooler and Dual Spal fans Sal Lubrano General Turbo Buick Tech 2 January 7th, 2006 08:13 PM
f-body radiator + dual fans GNBeswick Hot Air (non-intercooled) Tech 3 January 17th, 2005 07:32 PM
Mounting Ramchargers dual fans on F-body radiator d0n_3d General Turbo Buick Tech 0 July 4th, 2004 10:56 PM
F-body radiator + Ramcharger dual fans=...... Pitbozz General Turbo Buick Tech 2 July 24th, 2003 04:50 PM
Dual SPAL fans installation lvnlg General Turbo Buick Tech 6 July 22nd, 2002 07:26 PM
